High idle / fuel injector noise?
Discussion in 'General Tundra Discussion' started by Chase1, Jan 5, 2019.
  1. Jan 5, 2019 at 7:09 PM
    Chase1
    Chase1 [OP] New Member
    Jeff
    2019 Tundra TSS
    My 2019 seems to idle high at startup. Worst thing in the world is for a cold engine to high idle before oil flows. It idles around 1200-1300 RPM, then will eventually settle down to about 600 after it warms up. I know 600 is not considered high idle by any means, but it seems to have trouble stopping, as though it were in high idle. I have also been hearing what I assume is fuel injectors, making it sound like it's low on oil. Have only had it 2 weeks.
  2. Jan 5, 2019 at 7:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is normal.
    Chase1[OP] likes this.
  3. Jan 5, 2019 at 7:53 PM
    timsp8
    NY
    Mine does it. Probably does it cause of emissions crap.
    If yours ticks, Ive seen a few do it. Everything I found says it’s normal. Mine does it from drivers side of engine.
  4. Jan 5, 2019 at 7:59 PM
    It’s normal. I recommend driving after it settles down.
    15whtrd and Chase1[OP] like this.
  5. Jan 5, 2019 at 8:11 PM
    Chase1
    Jeff
    2019 Tundra TSS
    I guess I have too much time with street cars, and cold starts and ticking make me nervous. LOL Thanks guys.
    Cement_Trd likes this.
  6. Jan 5, 2019 at 8:15 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Remember carburetors and their high idle cams? High idle here serves the same purpose here, to get the engine up to operating temperature quickly. Only it's all computer controlled now-a-days.
  7. Jan 6, 2019 at 4:44 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Completely normal, get out and drive it put some break in miles on it. It should settle down some.
    -Jason
  8. Jan 6, 2019 at 4:57 AM
    timsp8
    NY
    Forgot to say earlier, the ticking has something to do with the VVT thing.
  9. Jan 6, 2019 at 5:24 AM
    All of the above. ^^^^^. Also the AIP's kick on making a racket. The first time I cold started my truck was......WTF???
    15whtrd likes this.
  10. Jan 6, 2019 at 6:35 AM
    timsp8
    NY
    My 18 also makes like a fan noise for a second when I turn it off that my 10 never did. More emissions stuff.
    Black Wolf likes this.
  11. Jan 6, 2019 at 7:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, that's the Secondary Air Injection System running to try to clear out any moisture that may have gotten in, it also runs on start-up as mentioned by @Grey Wolf. On the older Second Gen trucks it would only run on a cold start to get more air into the converters to light them off, for emissions. It was noticed that the SAIS was getting moisture in them and they were corroding and failing, at great expense, so now they run on shutdown by default too, or there's an ECU re-flash from the dealer that will make them do so. There's also an aftermarket by-pass that can be installed.
    timsp8[QUOTED] and Black Wolf like this.
  12. Jan 6, 2019 at 7:42 AM
    The frustrating thing is the all Tundras have the AIPs because of Kommiefornia requirements. Other states "might' pass laws or come up with regulations similar to Kali so ALL Tundras get AIPs. Thank you Kommiefornia!!!!:crapstorm:
  13. Jan 6, 2019 at 7:47 AM
    timsp8
    NY
    After some issues on my 10, mostly caused by me, I got the 100k warranty. Ive seen the bypass but want to spend that $ on other stuff.
    Bought a Transfer Flow 46g for my 10. They operate out of Cal, but cannot legally sell their products there. Makes 0 sense. I have family that live out there and ask when I am moving out there. Long after never.
  14. Jan 6, 2019 at 7:56 AM
    Have family out there too. They will have to move. Done my time there......
  15. Jan 6, 2019 at 8:21 AM
    Chase1
    Jeff
    2019 Tundra TSS
    Oh I am. Over 1200 miles the first week. Traveling around the state looking at RV's.
