High Beams
Discussion in '2.5 Gen Tundras (2014-2021)' started by TommyTundra, Mar 1, 2021.
  1. Mar 1, 2021 at 9:04 AM
    TommyTundra
    TommyTundra [OP] Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Anybody have any ideas which wire on a 2019 TRD PRO is the high beam so I can tap into it for LEDs to supplement the high beams.
  2. Mar 1, 2021 at 9:19 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Can you just disconnect harness and test it?
  3. Mar 1, 2021 at 9:36 AM
    TommyTundra
    Long Island NY
    2019 PRO
    Probably can. Was trying to avoid taking the whole front end apart.
  4. Mar 1, 2021 at 9:44 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Does the fuse block have a seperate fuse for the high beams? If so, you can hook in there.
  5. Mar 1, 2021 at 9:45 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Do you have to do that to access the harness?
  6. Mar 1, 2021 at 9:45 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    It does on my 2017
  7. Mar 1, 2021 at 10:28 AM
    TommyTundra
    Long Island NY
    2019 PRO
    Definitely cant get to the harness without removing the grill and the headlight assembly. If i knew which wire it is i could try to tap into it without doing all the disassembly. As far as tapping into the fuse block id rather not do that. Just my personal preference
  8. Mar 1, 2021 at 10:31 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Wiring diagrams for all model years are available in the thread linked in my signature. Should be easy to hunt down from there.
    BlancaLaGordita likes this.
  9. Mar 1, 2021 at 10:33 AM
    TommyTundra
    Long Island NY
    2019 PRO
    Awesome. Thanks
  10. Mar 1, 2021 at 10:40 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
