High beam headlight issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by rcjh0891, Feb 17, 2020.
  1. Feb 17, 2020 at 5:00 PM
    rcjh0891
    rcjh0891 [OP] New Member
    Joel
    DFW
    2018 Tundra Platinum Crewmax 4x4 MGM
    I have a 2018 platinum the collision light is on the dash. My wife was in a wreck. The highbeams will only come on if pull back all the way and hold it. The stalk doesn’t just turn them on and off. To get on must manually pull back and hold it. Is it something to do with pre-collision sensor?
  2. Feb 17, 2020 at 5:50 PM
    Ricardowelch
    Ricardowelch New Member
    Welch
    I think it could be the fuse and connection. Try to check them. Good luck.
  3. Feb 17, 2020 at 5:51 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Pulling back is just to flash the high beams. You push it forward, toward the dash, to turn high beams on.
  4. Feb 17, 2020 at 5:55 PM
    rcjh0891
    Joel
    DFW
    I push it forward they don’t come on. The bulbs are good
  5. Feb 17, 2020 at 6:00 PM
    RonW
    RonW New Member
    You got the auto dim on by any chance?
  6. Feb 17, 2020 at 6:02 PM
    rcjh0891
    Joel
    DFW
    No it’s not
  7. Feb 17, 2020 at 6:18 PM
    rcjh0891
    Joel
    DFW
    RonW. You got it thank you. The auto push in push out was enabled. Pressed it now it comes on. I thought it was something in the wreck. Thank you again
  8. Feb 18, 2020 at 6:45 AM
    RonW
    RonW New Member
    Yeah, that auto dim wont let you put high beams on under 20 or 25 mph. Its annoying.
    NewImprovedRon likes this.
