Hidden winch possibilities/got trapped in the snow for a day
Discussion in '1st Gen Tundras (2000-2006)' started by 2000Strong, Dec 13, 2019.
  1. Dec 17, 2019 at 8:30 PM
    #61
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    5100s have selectable perches. The bottom of your coil gets raised up on the shock body, that extends the shock shaft and lifts the truck.
  2. Dec 17, 2019 at 8:32 PM
    #62
    2000Strong
    2000Strong [OP] Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    So I just use my oem front springs and pay someone to put it together?
  3. Dec 17, 2019 at 8:40 PM
    #63
    Aerindel
    Aerindel New Member
    Montana
    Which....is also how lift spacers work....
  4. Dec 17, 2019 at 8:49 PM
    #64
    2000Strong
    Benjamin
    Washington
    That’s kinda what I was thinking and I already have the spacer kit...
  5. Dec 17, 2019 at 8:57 PM
    #65
    Aerindel
    Aerindel New Member
    Montana
    To be fair, 51000s are great shocks. But mechanically, used as a lift they are doing the same thing spacers are, increasing the pre-load on your springs to push the truck higher.
    I had 3" spacers in the front on mine, it rode great, when empty. But with just 900lbs in the back it squatted terribly. A couple weeks ago when I did tie-rod ends and front brakes, I removed the lift.
    Honestly, I think our trucks have a lot of clearance stock and are actually more useful for truck stuff with a stock like suspension.
    With 900 lbs of concrete in the bed and 3" front spacers.
    2000Strong[OP] likes this.
  6. Dec 17, 2019 at 9:03 PM
    #66
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    You did a really good job with that. What kind of light's from Home depot, and how did you wire the lights to get them to work?? Lol, I only know of 120V Christmas lights that plug into the house supply.
  7. Dec 17, 2019 at 9:05 PM
    #67
    2000Strong
    Benjamin
    Washington
    Yeah that makes sense, but also 900 lbs is a lot to have in the bed so I feel like even stock it would squat but probably not as bad.
  8. Dec 17, 2019 at 9:06 PM
    #68
    2000Strong
    Benjamin
    Washington
    There powered off of a little battery pack via double A batteries I zip tied behind the grille.
    https://www.amazon.com/dp/B072NH2FQ1/ref=cm_sw_r_cp_api_i_JqB-DbE56GFN5
    something like this little leds on a bendy metal cable.
    02goes[QUOTED] likes this.
  9. Dec 17, 2019 at 9:08 PM
    #69
    02goes
    02goes New Member
    I heard beyond 2" is maxing out w/o modifying front end and having abnormal expensive component wear. I have the 5100's and am now looking at the 1 notch below 2" lift setting, even though I prefer the 2" setting.
    I pull a boat and don't want to look at the sky.
  10. Dec 17, 2019 at 9:12 PM
    #70
    2000Strong
    Benjamin
    Washington
    That’s probably true. It’s just what I have though, also I feel If I lift the rear I might need longer shocks.
  11. Dec 17, 2019 at 9:12 PM
    #71
    Aerindel
    Aerindel New Member
    Montana
    Well, 1700lbs payload capacity so I don't think it should have been that bad at just over half. They design trucks with a rake for a reason. I used to put that much in my little 93 toyota pickup all the time and of course it was low in the back but not that bad.
    This was my old truck with 1300 lbs of weight in the back so you can see why I was a little disappointed with my full sized truck with less weight when it was leveled.
  12. Dec 17, 2019 at 9:13 PM
    #72
    2000Strong
    Benjamin
    Washington
    Oh wow yeah. Nice truck by the way.
  13. Dec 17, 2019 at 9:16 PM
    #73
    Aerindel
    Aerindel New Member
    Montana
    Yeah, I sold it to pay for the tundra and kind of regret it. Once I had a kid having a vehicle without enough room for all three of us to use made it a lot harder to use so I upgraded to a tundra for the backseat. I do miss 25 MPG and the maneuverability though.
    That pick was taken when I moved back down to MT from Alaska.
    speedtre likes this.
  14. Dec 17, 2019 at 9:22 PM
    #74
    2000Strong
    Benjamin
    Washington
    Oh rad. My parents are thinking about moving to Alaska and I might end up being the moving truck. But I’m staying in Washington unless a better opportunity comes up. This truck used to be my dads and I’ve literally known it my entire life.
    Yes. That’s me.
  15. Dec 17, 2019 at 9:25 PM
    #75
    02goes
    02goes New Member
    Kool, you got these from Home Depo or Amazon cause I'm with your program.
    You lift the hood to turn it on/off, or spliced to have a little switch outside the front grill?
  16. Dec 17, 2019 at 9:30 PM
    #76
    2000Strong
    Benjamin
    Washington
    I just zip tied it in a way were I can fish my finger though the grille to hit the switch. I found mine at Home Depot but those are exactly the same. If you look closely on the drivers side you can see the wire to power the lights running into the grille.
    Be carful how you put the wreath on it scuffed my paint a bit on the hood. My paints shot anyway but it’s so small it would probably just buff out with a good compound.
  17. Dec 17, 2019 at 9:46 PM
    #77
    No, you shouldn’t run chains on the front unless running two sets. If only running one set, the primary drive axle should get the chains (on trucks, rear axle).
    Reason being:
    - Climbing hills, the weight is shifted to the rear.
    -Typically, if equipped, most trucks have a locker or limited slip in the rear. Your maximum traction axle should get chains.
    -Going down hill, having the chains on the rear will help the vehicle stay in control.
    There is a method to the madness.
    Trailscape and 2000Strong[OP] like this.
  18. Dec 17, 2019 at 9:54 PM
    #78
    2000Strong
    Benjamin
    Washington
    Makes sense, what if your towing though?
  19. Dec 17, 2019 at 9:55 PM
    #79
    02goes
    02goes New Member
    The matching 5100 rear shocks give 1" additional travel if lifted with 1" blocks or not. These shocks are great for gaining the trks 2" lifted height with added stiffness to perform well off road, vs stock shocks. However, definitely not to be used as a substitute for lift gain in order to slam the trk around in off road competition.
  20. Dec 17, 2019 at 10:10 PM
    #80
    2000Strong
    Benjamin
    Washington
    Yeah I have the supplies for 3 inch front and 2 rear just really don’t wanna mess with the breaks I hate working with break fluid and it’s hard to bleed them on your own.
  21. Dec 17, 2019 at 10:22 PM
    #81
    2000Strong
    Benjamin
    Washington
    Although I could probably go down to like 2.5 front and 2 rear from what I found that’s the most you should go without nodding break lines and all that.
  22. Dec 17, 2019 at 10:35 PM
    #82
    2000Strong
    Benjamin
    Washington
  23. Dec 17, 2019 at 10:43 PM
    #83
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  24. Dec 17, 2019 at 10:54 PM
    #84
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    There are two kinds of spacer. The rare kind is a shim that goes between the upper mount and coil, which has the same effect as a 5100 by extending the shock shaft while granting lift. I haven't seen those for the Tundra in years. That is not to be confused with the shims often used for leveling driver vs passenger, those are just spacers avoiding the word spacer.
    The common kind is a puck that lowers the upper perch of the shock/coil by creating space between that upper perch and the coil bucket to achieve lift. You have the same range of travel but it has been moved downward considerably(around 1.8" of downward shift for a 3" lift) because the puck bolts on top of the perch mounting bolts. For most day to day driving this isnt too big of a deal, but when in the full extension of travel you are out of the range that the rest of the suspension is meant to handle. This is where things like ball joint wear/breakage and coil slappage on upper arms can happen.
    Really, with the geometry on a 4x4 Tundra there shouldn't be lift applied beyond 2" by the coil/shock, but most spacers are for 3" because that means they can sell you a 1" rear block to get level.
  25. Dec 17, 2019 at 10:57 PM
    #85
    2000Strong
    Benjamin
    Washington
    So what would you recommend? Is that rough country kit no good?
  26. Dec 17, 2019 at 10:58 PM
    #86
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Don't buy that junk. Do research here and decide what you really want, then save up for it.
  27. Dec 17, 2019 at 10:58 PM
    #87
    02goes
    02goes New Member
    Like everything else, do your home work and compare the pros and cons to what you choose. Stiffness comparison for primary application and your comfort zone is a thought some forget about. But most important would be doing your homework about RC to find others complaining about front alignment and other issues after product install.
    I had a never ending serious problem with alignment using RC's 3" lift/leveling product on a Silverado. I had their product professionally installed. Because of that and since then, I'll never touch any of their product again. They had a design problem and threw me under the bus.
    I additionally purchased their highly recommended aftermarket control arms that were useless and a scam for more money. Using the OEM's would have been no different. With the RC kit installed my front tires were burning bald on the outside edge rapidly. With rotating tires every 3 thousand miles, the tires would only last 20 thousand miles. So, choice was to keep RC level/lift and eat buying tires every 20,000 miles, or go to the junk yard and remove/rebuild OEM control arms to replace the RC control arms, or just sell the trk while it was worth something and not go through the hassle.
    I sold the trk. Was easier to buy a different mfgrs competing new trk because Chevy's new fuel management system on the 5.3 had inherent problems that would go past warranty. Finally, after all that money spent on a few similar worthless new trks, I have this ole Tundra by fate and know better for what to do and don't. So choose wisely and go for the time tested better product.
    I remember RC as the cheaper choice when they started, and newbies like me took the bait because of very limited cash flow. Had a CJ Jeep and replaced the springs which were OK to me because I didn't have a clue to know better, Lol. RC products are still not comparable to quality that the old school boys and some recent mfgr engineers offer today.
    Read/research and save (not for the best) for a no headache product that you can afford!
  28. Dec 17, 2019 at 10:59 PM
    #88
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    What do you want of your truck? So far sounds like a daily driver that you care about and needs to carry a winch and go off road?
  29. Dec 17, 2019 at 11:02 PM
    #89
    Aerindel
    Aerindel New Member
    Montana
    Well, not really.
    nl
    The weight doesn't shift, its always pulling down. If your going up a 20º slope, which would be pretty steep, that angle from say, your engine, is just shifted back about a foot from where it is on level ground. Most of the weight is still in the front (without a load in the back)
    If you have a locker, there is a point there, but most of us don't have a locker or even LS
    Going downhill, most of your braking is still in the front, like it always is, which of course is why are rear brakes are nothing compared the the fronts. They always are doing most of the work. The rear of your truck can only come around on you if your fronts are also slipping. Which the won't, because a vehicle with chains is the next best thing to a tank.
    With our trucks with no center diff, in 4x4 the power is split 50/50 front and back so the front gets just as much power as the rear in all situations, except the front has more weight and thus more traction to make use of that power, but most importantly, with front chains you can pull yourself up and out of of holes instead of your rear end trying to push you down into them. You can pull yourself in the direction you need to go, and let the rear end trail behind.
    Of course four chains are better, but most of your traction is always going to be coming from the front chains or no chains so that is where they are going to do you the most good.
    And why RWD vehicles are a sad joke unless they are also a rear engine vehicle. My 67 VW is a beast in the snow but thats because it as a 20/80 weight distribution to the rear wheels.
    I don't know the numbers but I wouldn't be surprised if our trucks unloaded are 70/30 front biased, but even if they where 50/50 I would still want the steering wheels to be the ones with the most traction.
  30. Dec 17, 2019 at 11:05 PM
    #90
    2000Strong
    Benjamin
    Washington
    Ok. I’m not really trying to make the truck taller it’s just more I want it to sit level. Do you have any recommendations or are the bilstines the best bet? And if they are how do I do the front shocks?
