HID vs LED bulb upgrade for 2020 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra_2020, Jan 17, 2021.
  1. Jan 17, 2021 at 7:06 PM
    Tundra_2020
    Tundra_2020 [OP] New Member
    2020 Tundra SR5
    Hello,
    I am new to this forum but was wondering what everyone’s thoughts were on upgrading the halogen headlight bulbs to LED or HID bulbs. I have the LED running lights on my 2020 SR5 but have halogen hi/lo’s and fog lamps. I can’t see paying over 1,000$ for the LED housing upgrade so was wondering if you guys had any suggestions or if there are other posts that could help guide me in the right direction. Thanks, I appreciate the assistance.
  2. Jan 17, 2021 at 7:56 PM
    You can get the OEM led headlights along with the ihacker harness. Some of us run Morimoto XB leds. Don't put an HID kit in the stock housings. Those cheap drop in kits seem to have fallen off the radar.
  3. Jan 17, 2021 at 8:03 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Welcome dude!
    Lots of threads on this topic. You can upgrade the halogen bulbs with auxbeam leds for a cheap temporary solution. Like 35 bucks.
    Factory LED headlights will run you like 600.00 from cool springs Toyota.
    I have the Auxlights and they are much better than stock, but not at all as good as factory LED’s. Hope that helps!
    Auxbeam S1 Series H4 LED Bulb Fanless with 2 Pcs of Super Bright CSP LED Bulb Conversion Kit 8000Lumens 6000K Halogen Replacement https://www.amazon.com/dp/B074GZ3S4P/ref=cm_sw_r_cp_api_glc_fabc_mFqbGbATAMGCW?_encoding=UTF8&psc=1
    dpast88 and BravoDeltaRomeo like this.
  4. Jan 17, 2021 at 9:09 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  5. Jan 17, 2021 at 9:35 PM
    Gray223
    Gray223 New Member
    2014 Tundra Double Cab Limited
    Is this a good idea to do in the halogen housing? Usually anything but halogens just blind everyone unless its behind a projector. Been awhile since I've looked into the different lighting options nowadays.
  6. Jan 17, 2021 at 9:37 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Welcome from SoCal. I plan on saving up for factory LED headlights. If you want a quick upgrade you can do the factory LED fogs for now which are drop in without a harness.
  7. Jan 17, 2021 at 9:44 PM
    chingyeunglo
    chingyeunglo New Member
    I have a 2020 SR5, upgraded to LED light bulbs and the fog lights. They look good and bright, better than factory halogen lights. You can get them all from Amazon less than $100, plug and play, no adjustment needed.
  8. Jan 18, 2021 at 1:41 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Welcome. Try asking and searching here: https://www.tundras.com/forums/lighting.20/
    Tagged mod for move.
    @Squatting Pigeon
  9. Jan 18, 2021 at 2:11 PM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
    I just put the morimoto 2 stroke 3.0 bulbs in. I originally had the factory halogens, swapped them out for some aux beams and most recently took the aux beams out and replaced with the morimotos. Here’s a before and after for reference. First photo is the aux beams on low and the second is the 3.0’s on low. Highly recommend the 3.0’s
  10. Jan 18, 2021 at 2:12 PM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
    Also have the morimoto xb fog lamps that I replaced the halogens with
    disregard the top two lights. That’s the nsv light bar running lights
  11. Jan 19, 2021 at 10:45 PM
    Tundra_2020
    2020 Tundra SR5
    Thanks everyone for your help!
  12. Feb 3, 2021 at 7:26 AM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Amazon says these don’t fit the 2020 or the 2021 Tundra.
  13. Feb 3, 2021 at 2:11 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    They fit- don’t worry about it.
    PonyMan[QUOTED] likes this.
  14. Dec 18, 2021 at 7:28 PM
    Tmjnd0
    Tmjnd0 New Member
    2020 White Tundra 4WD SR5 TSS
    Hey bud, what did you end up doing?
  15. Dec 18, 2021 at 7:30 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Friends don't let friends put led bulbs in halogen housings.
    Tumbler and 831Tun like this.
  16. Dec 18, 2021 at 7:48 PM
    Nope. It's either TRD Pro headlights if you want reflector style or Morimoto XB's if you want projector style.
