HID bulbs on Spyder projection headlights?
Discussion in 'Lighting' started by rojamon, Nov 25, 2018.
  1. Nov 25, 2018 at 9:27 AM
    rojamon
    rojamon [OP] New Member
    Roger
    2016 Toyota Tundra Limited
    3" lift kit, xenon headlights, fender flares, 33x11.5 R20 tires, 20"Ballistic wheels, chrome accents, nerf bars, Spyder headlights
    I have HID Xenon bulbs on my 2016 Toyota Tundra. I purchased Spyder projection headlights. I would like to use my HID bulbs with the Spyder headlights. Unfortunately, there is no connector for the LED DRL bar. I need to know how to power the LED bar separately? Has anybody done that, or know of a youtube video to show me how?
  2. Nov 25, 2018 at 11:18 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Nov 25, 2018 at 12:34 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @rojamon , Here's what I did. Just an option. I wired my leds and halos via fuse tap to my ignition fuse. They come on when I start truck. Here's a link to tap for information purposes. You can get them from your local auto parts store.
    https://www.amazon.com/Auto-Circuit...ocphy=9009860&hvtargid=pla-403531110127&psc=1
    Let me know if I can help. Good luck
    Headlight Revolution likes this.
  4. Dec 9, 2018 at 6:28 PM
    ATrn
    ATrn New Member
    2015 Tundra DBL Cab Texas Edition
    I'm also looking for a solution to make the LED Bar stay on, so how do you do a tap with the spyder headlight, if you know?
  5. Dec 9, 2018 at 10:43 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    If I remember correctly, it's the green wire on the back of the Spyders, unplug the bullet connector/jumper that ties the u-bar into the running light and connect it to an ignition source with a fuse tap.
    ATrn[QUOTED] likes this.
  6. Dec 10, 2018 at 4:57 AM
    rons23
    Ron
    Kill Devil Hills
    @ATrn, just what Chris said above. So you would connect the wiring straight to fuse tap and plug into ignition slot in your fuse box. You will add 2 fuses, 10 amp , could be different on a 3rd gen so double check. Sorry for the cheesy photo edit, but hope it helps.
  7. Dec 10, 2018 at 5:43 AM
    ATrn
    ATrn New Member
    So would I have to do that with both headlights?
  8. Dec 10, 2018 at 5:54 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Yes, whatever wire that signals the drl have to run to the fuse tap, so both lights will have 1 wire running to it.
    rons23 likes this.
  9. Dec 10, 2018 at 6:29 AM
    rons23
    Ron
    Kill Devil Hills
    Yes, but you can wire everything together. Wire up your passenger and leave enough length to carry you to driver side. Wire everything to fuse tap. Make sure you ground this.
  10. Dec 10, 2018 at 7:25 AM
    ATrn
    ATrn New Member
    I don't think the wire on the headlight will be long enough to reach the fusebox, so what wire should I use to extend it? Also both cables should be able to fit in the end of the tap, right?
  11. Dec 10, 2018 at 9:34 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    You can use 18g wire.
    I did the samething back when i had the spyder headlights.
    I extended the 12v + wire for the drl only. I left everything else plugged into the factory wiring harness. Basically you want a to power the drl from a different source rather than the factory harness. So ground wire will stay put.
  12. Dec 10, 2018 at 9:54 AM
    rons23
    Ron
    Kill Devil Hills
    You cut some wire to reach over to your drivers side. 16 ga wire, hopefully @rons
    16-18 ga wire. Cut you a piece long enough to make it over to wiring from driver side led. Essentially your just running a jumper piece of wire to tie in with the rest. Once both led bar wires are together, you will wire to fuse tap. Like Brandon mentioned above, everything should be grounded. It's always good to check, then check again.
  13. Dec 10, 2018 at 10:19 AM
    ATrn
    ATrn New Member
    Is there a way I can connect the two cables from the headlight without sautering?
  14. Dec 10, 2018 at 10:30 AM
    rons23
    Ron
    Kill Devil Hills
    Yes, you will insert wiring from both headlights into fuse tap and then you will crimp that end piece to secure wiring inside. Sautering is the best way, but really not needed here. Take some pics of the back of your headlights and the wiring of you can.
  15. Dec 10, 2018 at 10:33 AM
    ATrn
    ATrn New Member
    Can I use a connector when I'm extending the cable from the headlight with the 16 ga to combine the two?
  16. Dec 10, 2018 at 10:44 AM
    BrandonL812
    Brandon
    Yes. Crimp connector are ok to use. If you want extra insurance. Put some heat shrink tube over the connector. Seal out any chance of moisture getting in.
  17. Dec 10, 2018 at 10:47 AM
    rons23
    Ron
    Kill Devil Hills
    Yes that's what I use. Butt splice connectors
  18. Dec 10, 2018 at 12:53 PM
    ATrn
    ATrn New Member
    I'll see what I can do when I get home from work.
    Thanks for all the help!
  19. Dec 10, 2018 at 1:23 PM
    Berdine
    Binghamton, NY
  20. Dec 10, 2018 at 2:26 PM
    ATrn
    ATrn New Member
    I have a bunch of speaker wire, would that work?
  21. Dec 10, 2018 at 2:35 PM
    rons23
    Ron
    Kill Devil Hills
    16-18 ga ;)
  22. Dec 10, 2018 at 2:45 PM
    rons23
    Ron
    Kill Devil Hills
    The same that's for your ignition, it's a 10 or 15 amp, add the same exact fuse.
  23. Dec 10, 2018 at 5:13 PM
    ATrn
    ATrn New Member
    BrandonL812, Berdine and rons23 like this.
  24. Dec 10, 2018 at 7:00 PM
    Cuzican
    Cuzican New Member
    Louisiana
    These are great, but I have become a big fan of these...
    https://www.amazon.com/Solder-Conne...connector&dpPl=1&dpID=41AVySCrJlL&ref=plSrch#
    Berdine[QUOTED] likes this.
  25. Dec 10, 2018 at 7:12 PM
    BrandonL812
    Brandon
    I picked up one of those marine heatshrink assirtment box from Harbor freight awhile back, been using it for sometime. I like them, they have the glue that melt and ooze out once shrinked. Work real well.
  26. Dec 10, 2018 at 7:56 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I've never seen them at my harbor freight, guess I'll have to look harder next time I'm there.
    I just redid a 20' flatbed trailer and after years of dealing with flickering/non-functioning lights, the crap wiring job and cheap connectors they used when it was built, were all replaced with these glue lined marine grade shrink connectors, I don't expect any more problems now.
  27. Dec 10, 2018 at 8:02 PM
    BrandonL812
    Brandon
    I bought these.
  28. Dec 10, 2018 at 8:17 PM
    Cuzican
    Cuzican New Member
    Louisiana
    I misunderstood, I was thinking you found the heat shrink butt crimps at harbor freight. I got one of those kits off of Amazon, but then I started ordering that stuff off of amazon 10' at a time, I prefer to be able to cut it to the length I need, sometimes I need pieces longer than the kits have in them
    BrandonL812[QUOTED] likes this.
