Hi-Lift Jack Mounts for Bed Rail System
Discussion in '2.5 Gen Tundras (2014-2021)' started by ragofabrication, Mar 4, 2021.
  1. Mar 4, 2021 at 6:48 AM
    ragofabrication
    ragofabrication [OP] New Member
    Melissa Rago
    The Rago Fabrication Hi-Lift Jack Mounts for the Toyota Bed Rail System were designed to mount a Hi-Lift Jack using the the Toyota Bed Rail System.
    The mounts are CAD designed, CNC cut, CNC bent, and welded by Rago Fabrication. They come with high torque knobs. Rago Fabrication designed and made the knobs in house with 1/2 inch bolts that are welded internally. They will never break away from over tightening like the plastic knobs are known for. They are Powder Coated black to protect from rust!
    Black Wolf and Saltyhero13 like this.
  2. Mar 4, 2021 at 7:32 AM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    @ragofabrication is probably sick of my shit. I think these are better suited for the back rail. The way the bracket sits on the side gives it no back support. When you wheel all that strain is on those 2 rail bolts and the center of gravity is a couple inches away and south of them with no back support. I like to go fast and hit uneven terrain. When you mount on the back wall, there is plenty of back support and the way the angles lie.....I'd say they were meant to be placed on the back wall. Just my .02 - and you know what E-40 says about people's 2 cents.......
    ragofabrication[OP] likes this.
  3. Mar 4, 2021 at 7:39 AM
    ragofabrication
    Melissa Rago
    Hey these can be mounted to the cab of the bed as long as the bed rails are there. :) Thanks for your feed back.
    TundraPHX[QUOTED] likes this.
