Hi Lift Jack - 48” or 60”
Discussion in 'Recovery & Gear' started by AZBoatHauler, Aug 26, 2021.
Which size hi-lift
  1. 48”
    27.8%
  2. 60”
    55.6%
  3. Neither
    16.7%
  1. Aug 26, 2021 at 1:04 PM
    AZBoatHauler
    AZBoatHauler [OP] SSEM#140 / 2.5 gen plebe
    So.Arizona
    I have some WKOR sliders on the way and plan to buy a hi-lift jack to carry when I’m out and about. What I’ve read so far indicates bigger is better but I’m having a hard time convincing myself a 48” wouldn’t be sufficient.
    Anyone care to share their thoughts or experiences using a hi-lift on a Tundra, what size they went with, and why?
    I already have the mount from Rago on order…
    Thanks in advance for your help.
  2. Aug 26, 2021 at 1:11 PM
    RobertD
    Robert
    DFW, Texas
    I don't have one but I think your terrain could play a factor. Seen images where folks had to use the jack but it was below the level of the wheels. If that is a possibility, get all the length you can. Otherwise, I'd agree that the 48" should be enough.
    AZBoatHauler[OP] likes this.
  3. Aug 26, 2021 at 1:16 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You go offroad and will use the jack in that environment? If so, i would go larger as you could need the extra length if the terrain is very uneven. Downside is the larger would be even heavier and those jacks are really heavy. Those jacks can be used for many things, so dont just think about jacking up the truck to change a tire.
    If you dont offroad in heavy uneven terrain, the 48 is plenty and a little lighter, may be cheaper too.
  4. Aug 26, 2021 at 2:39 PM
    AZBoatHauler
    So.Arizona
    Yes, I get off-road as much as I can - usually 5-6 trips/year. Terrain is usually mild but I’ve gone through a few rock gardens that had me quite nervous for both clearance and tires. I’m signed up for Broken Arrow at Tundras to Sedona in October which should be fun.
    Weight and price differences seem relatively minor - about 3-5 lbs and $10-25.
  5. Aug 26, 2021 at 3:00 PM
    frichco228
  6. Aug 26, 2021 at 3:12 PM
    2mchfun
    Longer is better if you need to winch with it.
  7. Aug 26, 2021 at 3:14 PM
    frichco228
    More I think on it, 60 inch for sure!
  8. Aug 26, 2021 at 3:25 PM
    Billy Swamp
    Billy Swamp New Member
    Ben
    Seminole County, FL
    2014 CM Magnetic Platinum 4x4 Tundra
    7" pro-comp, 35" tires, fuel assault rims, Amp Research power steps, JRT system
    Down here in FL longer is better just in case the mud your temporarily stuck in is deep. You could need that extra bit of height to get something under the wheel that dropped off in a rut
  9. Aug 26, 2021 at 3:31 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Go big or go home, but I hate hi lifts and think you're better off with literally anything else.
  10. Aug 26, 2021 at 4:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  11. Aug 26, 2021 at 4:12 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    60 without a doubt; there is so much more to consider than just jacking from the slider.
    Consider lifting a tire to jack and stack, or jack and cast from the tire.
    As others have said, the extra length definitely helps in winching operations.
    Then, take a recovery class that focuses on using it
  12. Aug 26, 2021 at 4:47 PM
    2mchfun
    Lots of youtube vids on hi lift methods.
    Btw, if you ever need to jack out a post extra length could potentially be helpful.
  13. Aug 26, 2021 at 4:49 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Instead get that ARB pillow! I'll find it just give me a minute.
  14. Aug 26, 2021 at 4:50 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  15. Aug 26, 2021 at 5:59 PM
    AZBoatHauler
    So.Arizona
    I looked closely at these before I ordered the sliders. It’s awesome they can be used on about any vehicle and they definitely look better for lifting but I’m loving the winching potential of a hi lift.
    Also, the problem I see with this and a lot of the alternatives, where the heck am I going to store it? Seems like it’d be a pain to keep in on/in the truck and secure.
  16. Aug 26, 2021 at 6:51 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Agreed.
    I have a 60", but it's the last jack I pick to use on a 3 ton vehicle.
  17. Aug 26, 2021 at 7:04 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I’d take a bottle jack over a high lift any day. Much safer and you can drive off them
  18. Aug 27, 2021 at 5:47 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    A bottle jack can't (easily) be used to lift a tire, or winch with, etc.
    The hi-lift isn't inherently dangerous, but it is very frequently used incorrectly or by those who don't have the training to use it.
    Here's where mine is mounted (I take the foot off so it doesn't rattle while driving)
  19. Aug 27, 2021 at 5:59 AM
    2mchfun
    Truth is it is best to have a selection of jacks, all have their purposes. I carry a hi lift, 12 ton bottle, and stock. Plus a few wood blocks.
  20. Aug 27, 2021 at 12:44 PM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    I was in the same boat (no pun intended), but went with the 60" jack. Better to have the extra height than be short. I also picked up a base plate (https://www.amazon.com/Seven-Sparta-Compatible-Accessories-Protector/dp/B08CZQHHZD) to use in case someone gets stuck in soft sand/mud.
  21. Sep 24, 2021 at 11:33 PM
    AZBoatHauler
    So.Arizona
    Ended up picking up a 60” with the base plate and winch kit. Already replaced the shackles that come with the winch kit and am currently shopping for some grade 80 chain and hooks… holy hell chain is expensive… 20’ will cost more than the hi-lift! Thanks for everyone’s input. Sliders should be here in 3 weeks!
  22. Sep 25, 2021 at 7:31 AM
    2mchfun
    Might check some pawn shops or junk dealers for chains. If you have a Fleet Pride shop around they also have reasonable prices.
  23. Sep 25, 2021 at 5:39 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    Instead of 20' of chain, why not look into a 20' winch extension, or just a static strap?
  24. Sep 25, 2021 at 5:48 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Absolutely, chains are outdated for the most part in an off road vehicle anymore. Straps have come a long, long way.
    BravoDeltaRomeo likes this.
  25. Sep 25, 2021 at 6:20 PM
    2mchfun
    Chains and straps both have their place. I carry one chain and three straps. In mud chain is nice and ez to wash up. Sharp rocks, chain doesn't get cut up. Dragging fallen trees, chain doesn't tear. Lots of reasons to have a chain handy.
  26. Sep 25, 2021 at 8:19 PM
    AZBoatHauler
    So.Arizona
    I do have 20’ and 30’ static straps - the way I learned to winch with hi-lift is using at least some chain and hooks. Plan is a 8’ section to run the length of the winch with room to spare, another 18” holder to reset, and a spare 10’ section for whatever random shit I may need.
    2mchfun and Mallcrl[QUOTED] like this.
  27. Sep 25, 2021 at 8:24 PM
    AZBoatHauler
    So.Arizona
    TucsonTundra1794 likes this.
  28. Sep 25, 2021 at 8:45 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Straps are great but the piece of mind that a chain gives you is head and shoulders above straps and wire rope. It is a bitch to lug around though.
    2mchfun likes this.
  29. Sep 25, 2021 at 9:12 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    BravoDeltaRomeo and 2mchfun like this.
  30. Sep 25, 2021 at 9:42 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
