Hi. Can anyone tell me how?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JewelledKitten, Jul 20, 2022.
  1. Jul 20, 2022 at 2:03 PM
    JewelledKitten
    JewelledKitten [OP] New Member
    2021 Tundra SR5 2019 Tacoma TRD
    Used to be there was a dot on the base of the key that signaled you had an engine immobilizer. Can anyone tell me if that is still true? How to know? What's the new thing?
    Thank you in advance!
  2. Jul 20, 2022 at 2:06 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have a supplemental device in my truck that was dealer installed, its a blue LED light under the steering column. Not sure if they had different immobilizer otpions
    JewelledKitten[OP] likes this.
  3. Jul 21, 2022 at 10:51 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    if your truck had it stock, couldnt you go to toyota website and enter your vin to see what options and features were installed on the truck from factory?
  4. Jul 21, 2022 at 11:18 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Don't pretty much all modern (>2010 models) vehicles have the "immobilizer" which means there is an embedded chip in the key that must be near the ignition for it to work?
    Retired...finally likes this.
  5. Jul 21, 2022 at 4:55 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    If you have a flashing red lock on your dash when you lock the truck you do. Even with a perfect copy of a key, if the chip is not programmed it will just crank and not start.
    Mike59 and landphil like this.
  6. Aug 3, 2022 at 1:44 AM
    JewelledKitten
    Hey thank you Gentlemen so much!!!
    I love my truck!!!
    panicman likes this.
