Hey guys so I have a 06 double cab sr5 and I’m looking for a nice 6 inch lift.
Discussion in '1st Gen Tundras (2000-2006)' started by 06doublecab, Dec 29, 2024.
  1. Dec 29, 2024 at 6:26 PM
    06doublecab
    06doublecab [OP] New Member
    2006 double cab 4x4
    I would like a non body lift as I’m trying to fit 35s at around a 6 inch lift for off roading. I do a lot of off roading in Phx Arizona area and I’m wondering if you guys have any advice on a good suspension lift kit. No rough country, made that mistake before. I’m pretty new to lifts as I used to off road my first gen Tacoma last year that already was bought with a 3 inch rough country lift. Hoping you guys could point me in the right direction for a 6 inch suspension lift for off roading. Thank you!
  2. Dec 29, 2024 at 6:33 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Usually you max at around a 4” lift with IFS, beyond that you are chopping the cross member. Generally would recommend a moderate lift and stuff the largest tires possible with fender adjustment to maximum offroad ability.
    455h0le_dachshund likes this.
  3. Dec 29, 2024 at 6:34 PM
    shifty` I'm having daydreams about night things
    First off, highly recommend checking the "Suspension, wheel and tires ..." section of the community collective info megathread. Before you get started, before you hop in, just to get a bearing.
    tl;dr: This is the wrong truck for that shit. :rofl:
    Your only viable options for what you want I've seen, if body lift is out of the equation, would be (A) solid axle swap or (B) bracket lift, which requires permanent cutting of the front of your truck.
    RCD and Tuff Country I believe are the two reputable companies to use for bracket lifts, but are 5" lift and 6" respectively? Avoid the 4.5" that use spindle spacers.
    Many people I've seen passing thru who do bracket lifts on their 1st gen Tundra are eventually unhappy. Many forum members running 35s are also not happy save for our Texans and/or folks who strictly offroad. They're heavy af, eat gas, require lots of fender/firewall hacking, etc. It's a fuckton of work.
    woods and 455h0le_dachshund like this.
  4. Dec 29, 2024 at 6:36 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    I will pay you to not.
  5. Dec 29, 2024 at 6:42 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    You'll be able to fit 35's with a 6" lift. But I'm not sure anyone still makes and sells them for these trucks.
    3" lifts are pretty popular, but will take lots of work to fit 35's.
    You could always go with 3" suspension and a small body lift. That's what I plan to do to fit 35's.
  6. Dec 30, 2024 at 2:48 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Lol
    BroHon likes this.
  7. Dec 30, 2024 at 4:12 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Here we go, Again…
    The Black Mamba and shifty` like this.
  8. Dec 30, 2024 at 4:21 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Good luck with your project. I hope it turns out how you’d like. I would definitely take the advice given here and RESEARCH. Do lots of reading here. Avoid the mistakes others have made before you. There’s a ton of knowledge here, if you get hung up on something, ask before you jump in. You’ll get some great insight from most members, some friendly jabs (have thick skin) from others, but a lot of help if you have the right attitude.
  9. Dec 30, 2024 at 5:16 AM
    If you can find an RCD kit for the 8/2003 and up build date Tundras, that will be your best bet. But the 6" lift is not gonna be your best off roading option. For the same money, you can go with a nice long travel front end and 2.5" or larger coil overs. If you look at the most sophisticated and capable off-roading vehicles, rock crawlers and trophy trucks, none are jacked up truck chassis with only 5" (stock) of suspension travel. They are long travel suspensions with lower center of gravity and large diameter tires. Largest tires for these trucks to fit easy is 33-34" with close to factory offset wheels. 35" tires are possible with mods. Long travel front suspension with glass fenders keeps the COG low, increases travel and allows larger diameter tires. At some point, firewall mods will be necessary to go larger on tire size. You'll have to figure out what style of off-roading you'll be primarily doing to choose the right setup for you. 6" bracket lifts are for mall crawlers.
  10. Dec 30, 2024 at 5:26 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
  11. Dec 30, 2024 at 7:04 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
