Help with tires that keep getting out of balance on 2019 PRO
Discussion in 'Wheels & Tires' started by one4x4dad, Aug 21, 2019.
  1. Aug 21, 2019 at 2:44 PM
    one4x4dad
    one4x4dad [OP] New Member
    James
    Houston TX
    2019 Tundra Crew Pro
    Hello all-
    I bought my Tundra in February 2019 and within 800 miles swapped the tires for BFG All Terrain KO2 275/70/18s all around. I just thought that the factory tires seemed small. And i liked the stance and height stock. I drove it for 300 miles and it started shaking around 55-65 mph. I had to take it back to Discount Tire to get re-balanced. They also rotated them> Problem solved. I went back and had them rotated at 7000 miles and all was OK. About a week later (200 miles) they started shaking. I asked them to not rotate and re-balance them. First time I drove it off and it shook worse. Took it back immediately and they "zeroed" them out on the balance machine. The MGR told me to drive and see if that fixed it. 1000 miles later balance is off again. Took it back and they balanced them again. 500 miles later prob came back.
    It seems to be the set that is on the front now. He swapped the tires from left to right and said if it does it again he will swap the tires.
    The shaking is driving me crazy.
    Questions;
    1. Is this a tire issue or a PRO rim issue?
    2. Could it be a suspension issue?
    3. Should i get a different tire all together? I have used this brand for over 2 decades on jeeps trucks etc. Never had this issue. Is there a better tire for this application? I saw a white tundra on here one day with bronze wheels and what looked like a Hummer H1 style tire we used the the Army. Looked sharp. Cant find the post, the guy had a rod in his garage and had just put some bad ass sliders on his Tundra.
    Thank you in advance.
  2. Aug 21, 2019 at 3:05 PM
    Justin Case
    Justin Case New Member
    TX
    Could have DT road force balance.
    After three sets of tires from DT, I gave up on them mounting tires correctly. Best bet is to find a smaller tire shop with people that care to do it right. Could be a bad tire. Could be loosing weights. They are just stuck on so you could try marking or making notes of where weights are on each wheel after you have them balanced.
  3. Aug 21, 2019 at 3:08 PM
    Blueknights75
    Ron
    Clayton, NC
    It is not a PRO rim issue as I have had no issues with mine.
    Watt maker likes this.
  4. Aug 21, 2019 at 8:39 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I have the slightest wobble in mine above 65-70 but it’s never been enough of a problem for me to do anything about. I’m still running the stock tires.
  5. Aug 21, 2019 at 8:57 PM
    I've mentioned here previously on this forum that my new tire guy stated that he sells a lot of KO2's...but.. a bitch to balance a set...
    Watt maker and Newm like this.
  6. Aug 21, 2019 at 9:49 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    As a current Assistant Manager for Discount Tire, I think they need to be road force/ ride matched.
    BFG’s in general seem to be a bitch to balance correctly.
    Every store should have right balancer to fix your issue. My truck with BFG’s rides phenomenal but, I spent about 45 mins ride matching the tires to the wheels.
    A road force balance will check for an out of round tire and tell you by how much. The balancer will then tell you if you can spin the tire on the wheel to make the assembly a more perfect circle. Anything over 30 pounds of road force will vibe.
    Strictly out of curiosity can you take a picture of where the wheel weights are on the inside of the rim? I’d like to see more specifically how they are balanced.
    Watt maker and JH5370 like this.
