Help With Setup 3/2 Leveled 2013 Tundra
Discussion in 'Wheels & Tires' started by badams1897, Apr 12, 2017.
  1. Apr 12, 2017 at 12:32 PM
    badams1897
    badams1897 [OP] New Member
    Bobby
    2013 Tundra Black Limited with Canyon Red Interior
    3.5" Level Kit in Front and 2" in back. MB TKOs 285/65/20 BFG KO2 ATs
    I have been reading a lot of posts and I am trying to find an answer to a very specific question.
    Currently I am running a 3/2 Ready Lift Leveled Setup. I have factory 20 inch Limited Wheels with 1.25" SpiderTrax Spacers. Tires I am running BFG KO2 AT 285/65/20's.
    I want to ditch the factory wheels for some 20 inch Fuels, or XDs. I like the wider bumped out look and want to get the same feel I have with spacers but more aggressive look with the wheel. My question is what type of wheel do I need? If I go 9/10 inch with a + offset to get a wider look and feel would that help? I really like the 20 inch Fuel D569 Vapors but there are a ton of options for offset +/- and backing. Do you think I would need to switch to a different tire size? Ideally I would like to run 35x12.50s. Any advice would help.
  2. Apr 12, 2017 at 12:43 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    The lug pattern should be 5x150. Fuel would have them anywhere between 18 and 25 IIRC, unless you go for the deep lip then it goes out to 0 and on.
    I think 18's would be perfect without sacrificing performance and adding too much stress. Should be about the same if not more aggressive than spacers.
  3. Apr 12, 2017 at 12:52 PM
    badams1897
    Bobby
    So that is a +18 offset? Do you think I could run the 285s with them? Also how wide of rim? 9 or 10?
  4. Apr 12, 2017 at 12:56 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep. You could run 305's with them easily. 9 is what most people run, 10" with 18 offset would move the offset in more (stick out less) since it's wider than a 9" rim.
    And I'm not positive you can run 285's with a 10" rim. Manufacturer specs vary
    GNTundra, Voyagermike and PaRunnerd like this.
  5. Apr 12, 2017 at 12:59 PM
    badams1897
    Bobby
    Sweet thanks I will go 9" cheaper anyway. I just paid $1600 in tires for the 285s like to not have to ditch them.. I really like the 35x12.50 look
    Law323[QUOTED] likes this.
  6. Apr 12, 2017 at 1:05 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Same here, running 275's and put in 1200 bucks....too small with a lift, but put too much money in those tires, so just biding my time until i need some new ones....then 295's are the ticket i'm punching then!
    just put on a few mods to make the time go by faster and keep your "satisfaction" up with your truck! LOL
    this site doesn't really help with budget issues!
  7. Apr 12, 2017 at 1:25 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    bud..get? bu..dget? budgeet? what is this word. I've no idea what you speak of. :rofl:Mine came with 275s and it kinda looks like my truck skipped leg day after the 3/1 spacer lift.
  8. Apr 12, 2017 at 2:07 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    yeah, it's some weird ancient word that meant something about money.....my grandmother used it all the time, along with "ration" and "money sense". Weird words like that.....no idea!
    Yep....that's my truck right now.....hoping my +18 offset method standards I'm putting on will help the look some! :anonymous:
    GNTundra likes this.
  9. Apr 12, 2017 at 2:13 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Maybe a Millenial could teach you to English good....then maybe you'll understood that wurd "budget"
  10. Apr 12, 2017 at 2:24 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    :rofl::rofl::rofl::rofl:
    In millennial speak, budget is saving up bitcoins and spending real money to get them!
  11. Apr 13, 2017 at 8:48 AM
    badams1897
    Bobby
    So I still do not have a plan. I think 20x9 is the way to go. Offset I am still a bit iffy, +18 seems to be popular. I would still like more input on if I should mount my 285s on the new wheels or just sell them?
  12. Apr 13, 2017 at 8:51 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Mount them, no reason to eat $1600 - unless you can get a good deal on some 35's and sell your 285's at a good price. Might only have to eat a few hundred. That would be acceptable from my POV.
  13. Apr 19, 2017 at 2:43 PM
    badams1897
    Bobby
    Ok so +18mm Offset or +30MM? and we are 5x150 right? The only rubbing i get now is reverse at mid lock in the front wheel well. I saw posts how to fix it, or I will post up a pic of what I saw a guy do in Des Moines Iowa. He cut it all out looked sweet.
  14. Apr 19, 2017 at 2:53 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Yup. Trim it
    52433F5C-8322-49EC-A826-65DA644EC04F_zps_e99a8bd1448a101ea4487f210848b9fdf331347e.jpg
    B4CD3B22-31A3-46CF-84E5-DECA04D8CB6C_zps_b758b4214b6859db4de88ca2f12d255cb45963df.jpg
  15. Apr 19, 2017 at 4:00 PM
    TheBeast The Beach
    or
    ooops :cookiemonster:
    BlueBottle likes this.
  16. Apr 19, 2017 at 6:32 PM
    badams1897
    Bobby
    What did you guys use? I have a dremmel with cutting wheel might try that.
  17. Apr 19, 2017 at 6:50 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @TheBeast used his tire.
    I used a dremel.
    TheBeast, joonbug and PaRunnerd like this.
  18. Apr 19, 2017 at 8:04 PM
    PaRunnerd
    PaRunnerd No N00B, No Pro.
    Dave
    Lehigh Valley, PA
    2014 Magnetic Gray Tundra SR5
    Plenty planned thanks to all of you.
    Always taking the easy way out. :rofl:
    TheBeast and BlueBottle[QUOTED] like this.
  19. Apr 19, 2017 at 9:33 PM
    TheBeast The Beach
    perfect way to cut it...The Beast is not very polished :turtleride:
    PaRunnerd and BlueBottle like this.
  20. Apr 20, 2017 at 8:10 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    TuRD Off-road!
    TheBeast[QUOTED] likes this.
