Help with rivet removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by bryan4x4trd, May 2, 2021.
  1. May 2, 2021 at 4:50 PM
    bryan4x4trd
    bryan4x4trd [OP] New Member
    Does anyone know how remove a bolt like this? No head to grip. I don’t see any threads:/
    what type of bolt is this.
  2. May 2, 2021 at 4:54 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Not a bolt. That looks like a rivet. Won't be removing that one without buying a new part. What is that anyway?
  3. May 2, 2021 at 4:54 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Its like a rivet. you will have to cut and replace with bolt and nut. Key to remember is the rivet while holding everything together doesn't "squeeze the joint". where a nut and bolt will, why are you taking it apart?
  4. May 2, 2021 at 5:04 PM
    bryan4x4trd
    So the seat belt connector keeps falling down. When I put the back seats down the seat belt buckle stays on the ground so u have to stick your hand inside the pocket to pick up the seat belt connector. It’s a hassle. I exactly wanted to replace with a bolt washer and nut and tight it to where the seat belt connector stays up forever
  5. May 2, 2021 at 5:05 PM
    bryan4x4trd
    Thank you
