Help with Rear Light Bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Vinstinct2g, May 13, 2022.
  1. May 13, 2022 at 8:36 AM
    Vinstinct2g
    Vinstinct2g [OP] New Member
    Hey everyone!
    I recently installed the Putco Blade model 92009-60 and used the Curt wire harness 55384. I mounted everything per multiple threads/videos, hardwired the reverse light into the 7th pin wire, plugged in adapters and the 4 prong pin.
    Zipped tied everything down, turned on the truck and am not getting anything. No lights no flashing, no constant on, nothing.
    I read about a device that could check my output on the 4-pin trailer hookup. Going to get that device and ensure I am getting power, but in the meantime does anyone know where the fuse is for these connections and what size it may be.
    I am also open to other troubleshooting suggestions.
    2016 Tundra 1794 4WD
    Thanks in advance.
  2. May 13, 2022 at 9:00 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Without some pictures its kinda of hard to figure out how you have wired everything. Which 4 pin are you connecting the Blade to? The one on the bumper or the one on the curt harness? How did you wire into the 7th pin? Have you check the grounding?
    Just a couple thoughts. Hopefully that helps.
  3. May 13, 2022 at 10:25 AM
    Try it with your parking lights turned on?
    NewImprovedRon likes this.
  4. May 13, 2022 at 10:26 AM
    Vinstinct2g
    I unplugged the 7-pin from the bumper and plugged it into the Curt. Then plugged the curt into the bumper. Plugged the 4-pin into the light bar.
    I spliced into the center wire of the 7 pin Curt harness and sodered (sp?) in the reverse light wire running from the light bar.
  5. May 13, 2022 at 1:00 PM
    Vinstinct2g
    FEAR NOT!! I have fixed this issue!!!
    the factory wire harness had a loose connection inside the molex. I shoved it back into its home, plugged the harness back in and BAM! Light works now.
    thanks to all who helped
    clarkritchie likes this.
  6. May 14, 2022 at 7:38 AM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Awesome! Glad you got it working. I connected my OPT7 Redline bar the same way. It has been working great for several months. I looked at the putco, but the price scared me away. Also, I wanted sequential turn signals. I mounted mine with magnets so I can remove it easily to clean the tailgate gap or if I need to access the spare tire.
    Occidentalis and Vinstinct2g[OP] like this.
  7. May 14, 2022 at 8:29 AM
    Vinstinct2g
    The magnets idea is solid! Have you had any issues with movement?
  8. May 14, 2022 at 8:32 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Use silicone tape between the magnet and the paint. I also used stoppers to prevent downward travel of the bar. There are four holes you can use for the stoppers.
    mav7021234 likes this.
  9. May 16, 2022 at 5:23 PM
    a522467
    Michelle
    Ohio
    These are the magnets I used.
    https://www.amazon.com/gp/aw/d/B08TMPRB39?ref=ppx_pop_mob_b_asin_title
    They hold it pretty well. Sometimes I need to slide it back up just a tad after roughhousing it or going through a touchless car wash. Like @Saltyhero13 said though, keep something between the magnets and your paint. I left the red strip from the OPT7’s 3M tape there and slid the magnets in behind it.
