Help with Rear End!
Discussion in '1st Gen Tundras (2000-2006)' started by Redrider001, Jun 15, 2024.
  1. Jun 18, 2024 at 7:17 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I'm pretty sure 2002 was the last year for choosing a non-abs option. Which would mean that in 2003 they all came with ABS.
    bmf4069[QUOTED] likes this.
  2. Jun 18, 2024 at 7:21 PM
    whodatschrome
    lots of dents
    Hard pass on the wheel spacers unless it's the last ditch effort. Don't be a axle...find the right axle. I'm kidding on that comment, but search craigslist, faceplace marketbook, U pull it, and other wrecking yards. The double cab is a fairly common truck. I'm confident one will turn up.
  3. Jun 19, 2024 at 5:10 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Not sure where you're located but the local U pull it in Columbia SC just got a 2004 Double Cab.
  4. Jun 19, 2024 at 3:35 PM
    Redrider001
    Redrider001 [OP] New Member
    Casey
    2006 Double Cab 4x4
    So I have called a couple pick n pills and they won’t ship I’m in OH. And 04 should be 4:10 I need 3:91s. Thanks though.
  5. Jun 19, 2024 at 4:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    You can put your 3.91 3rd into the 04 housing...
    whodatschrome likes this.
  6. Jun 19, 2024 at 8:25 PM
    whodatschrome
    lots of dents
    Do you have larger than stock tires? If so, i’d grab that 4.10 axle in a heartbeat. Then look for a 4.10 front diff.
    Option 2- i’d still grab that 4.10 and at the bare minimum i’d swap the 3rd members with your 3.91 axle. Then put the 4.10 on the shelf and swap it in at a later point. 4.10 gears would make your truck a rocket ship with stock sized tires.
    des2mtn likes this.
