Help with options please
Discussion in 'Suspension' started by Cpa757va, Mar 1, 2020.
  1. Mar 1, 2020 at 6:59 AM
    Cpa757va
    Cpa757va [OP] New Member
    Chad
    Hampton roads VA
    2019 Tundra limited TRD off road
    See build thread below.
    I need some opinions. Goal is to level and even slight rake would be fine. Already ordered 285/70/18 RG with SCS ray 10s +25 mm offset.
    option 1: Bilsteins 6112 set at 2.5” with CB shim each side for 3” front with 1.5” shackle in rear.
    option 2: Bilsteins set at 2.5” and shackle at 1” in rear.
    Option 3. Bilsteins set at 1.9” with two driver side shims and one passenger side shim and shackle in rear (1” or 1.5”??)
    I have 5100s in rear already and I already have Icon delta joint UCAs being installed as well.
    thanks for any input, experience.
