Help with more bass
Discussion in 'Tech12Volts' started by Travis g, Mar 13, 2022.
  1. Mar 13, 2022 at 4:55 PM
    Travis g
    Travis g [OP] New Member
    Travis g
    2020 tundra limited
    Is there a aftermarket sub that would help with more bass while still using the factory amp? My truck is a 2020 crewmax limited with jbl. Thanks in advance
  2. Mar 13, 2022 at 5:10 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    bulldog93 likes this.
  3. Mar 13, 2022 at 9:40 PM
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    Yep you are 100 percent correct. The 8 channel is no brainer in the JBL system . We just imstalled one Friday and the customer was crazy happy. His local shop said there was nothing they could do at all with his JBL system
  4. Aug 17, 2022 at 4:58 PM
    Travis g
    Travis g
    2020 tundra limited
    James@tech12volts. In your opinion would just replacing the sub be enough to sound good? I don’t want a super thumping stereo just more bass. Or should I go with the 8channel amp and sub? Thanks
  5. Aug 17, 2022 at 8:46 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    With just the sub it’s a little better , with the amp it rocks. You get a control with it so you can adjust lvl of sub.
  6. Nov 18, 2022 at 10:01 AM
    @james@tech12volts I have an enclosure question. I purchased this enclosure from a local guy a few years back. It is ported on the back. He had it built locally and said that he had Hertz subs in it. When I went to get subs from my local shop, he recommended the Alpine SWR-8D4. I have had them for a few years now. I was messing with amp gains after replacing the sub amp, and sometimes it sounds good, and sometimes not quite as good. Is there any major difference between the Hertz and the Alpines when it comes to the enclosure? Thanks.
  7. Nov 18, 2022 at 10:49 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Have you tried a chartreuse plastic worm Carolina rigged? :rofl:
  8. Mar 19, 2023 at 11:49 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Alpine makes good subs.
    Mike59 likes this.
