Help with hyperflash and taillights
Discussion in 'Lighting' started by JROCK915, Nov 1, 2015.
  1. Nov 3, 2015 at 10:05 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You got it to work i assume
  2. Nov 3, 2015 at 10:11 PM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    I feel so stupid! I completely forgot about the fuse box.
  3. Nov 3, 2015 at 10:13 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Yes sir. Thanks again guys.
  4. Nov 4, 2015 at 4:27 AM
  5. Nov 4, 2015 at 12:35 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    What fixed the hyperflash? In case I try to install led's!
  6. Nov 4, 2015 at 12:38 PM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    I think it was a fuse ... correct me if I am wrong :smack:
  7. Nov 4, 2015 at 5:43 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Soooo...... on the way home, I noticed my front flasher (which is a switch-back) is not flashing. Nor does the park lamp come on. But while lights are on, it's fine.
    Flashe/park fuse now???
  8. Nov 4, 2015 at 5:49 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Honestly..... I got so frustrated with it, I put the originals back in.
    NOW.... I may have overload on the driver's side from the resistor, because the front flasher or park isn't working, but while lights are on fully, the led white (switch-back) is fine. Prob blew that fuse too.
  9. Nov 4, 2015 at 8:37 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    So... I got home....relaxed a bit.... had some pizza & wine. Then went to work. I went through all the steps.
    Fuses were all good. Checked the rear resistors...they were good. As I went to pull the headlight on the driver's side, I see my resistor wire flopping around. It had some how pulled away from the connector. I also noticed the bulb was loose.
    Houston.... we have lift off. ALL lights are solid, and remain led.
    T-Rex266 likes this.
  10. Nov 4, 2015 at 10:08 PM
    csuviper
    Broomfield, CO
    Lol, had to be something simple.
    JROCK915[OP] likes this.
  11. Nov 4, 2015 at 10:09 PM
    csuviper
    Broomfield, CO
    Sean called it.
  12. Nov 5, 2015 at 4:02 AM
    TruckLife900
    2013 White SR5
    Good work mate! :jellydance:
  13. Nov 5, 2015 at 11:25 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Yup. Just had to step back and breathe for a min. I knew it'd get figured out
  14. Nov 5, 2015 at 11:25 AM
    JROCK915
    Jeremy
    Palm Desert, CA.
    Yes he did.
  15. Mar 27, 2016 at 9:01 AM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    Even a blind squirrel finds an acorn now and then.
    NewImprovedRon likes this.
  16. Mar 27, 2016 at 9:29 AM
    bigsapz
    bigsapz New Member
    Beast
    Led turn signal bulbs are not worth the hassle in a 3157 CK socket like the Tundra has. My .02 anyway.
