Help with How-To Enable Fog Lights
Discussion in 'Lighting' started by pmedic048, May 1, 2015.
  1. May 1, 2015 at 5:38 PM
    pmedic048
    pmedic048 [OP] Pull away from the herd, drive a Tundra!
    SC
    2008 SR5 Dbl Cad, 2015 SR5 CrewMax 4x4 and 2016 TRD Limited 4x4
    3" front spacer lift and 2" rear spring lift. 20" Fuel rims with BF Goodrich G2 33.5s and Volant cold air intake.
    Hey everyone,
    I have a 2015 crewmax and I tried the Eddie enable fog light mod. After I cut and jumped the wires my fog lights didn't work, so I put them back to stock and now I don't have fog, park or tail lights. With the headlights off my parking lights work and my DRL work. I checked all the fuses and they are good. Has anyone else ran into this issue before? Thanks Mike
  2. May 1, 2015 at 6:23 PM
    Any photos to show what was done?
    pmedic048[OP] likes this.
  3. May 1, 2015 at 6:30 PM
    Mike Tread lightly.
    south carolina
    Did you do the mod with power applied to the truck?
    Are you sure you checked the fuses under the hood also?
    Sounds like either the connections you made are bad or you dead shorted something (fuse out). Honestly.
  4. May 1, 2015 at 6:31 PM
    This is my guess...
  5. May 1, 2015 at 9:52 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    You already said fuses are ok so check the new wire connections. If you used quick splices there is a chance that the wires are not quite touching.
    I did the mod in my truck with no problems
  6. May 2, 2015 at 10:22 AM
    pmedic048
    SC
    Hi guys, thanks for the replys. I soldered the wires back to stock, I check fuses under the hood and I even changed the fog light fuse with a new one. I had the battery disconnect when I did the mod, ate there any other fuses beside under the hood? I appreciate all your guys help.
    T-Rex266 likes this.
  7. May 2, 2015 at 10:59 AM
    Pop the fuse cover panel under the hood...I dont recall off hand if there are any direct relations to it, but the cover will have the associated labels with said fuse.
    pmedic048[QUOTED][OP] likes this.
  8. May 2, 2015 at 11:02 AM
    pmedic048
    SC
    Thank you everyone for all the help and a huge thank you to Mike!! He is Mr.Tundra and I am thankful for your help sir.:amen:
    Mike and T-Rex266 like this.
  9. May 2, 2015 at 11:03 AM
    pmedic048
    SC
    Thanks Sean226, it was brought to my attention that there is a 2nd fuse box attached the ECU under the dash.
  10. May 2, 2015 at 11:06 AM
    pmedic048
    SC
    It was a blown 15 amp fuse under the dash, thank you to all of you.
  11. May 2, 2015 at 11:25 AM
    Mike Tread lightly.
    south carolina
    Sometimes it easier with a phone call man. Glad I could help.
