Help with fuel injector install
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Mar 19, 2021.
  1. Mar 24, 2021 at 9:34 AM
    #121
    Professional Hand Model
    Hand Protectors
    You seem like the type that likes watching.
    Filthyphil likes this.
  2. Mar 24, 2021 at 9:36 AM
    #122
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I once knew a dude that hired a Bubba, but Bubba didn't watch.
  3. Mar 24, 2021 at 9:38 AM
    #123
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    wow....best if I just leave that alone ....you have a swell one also
    empty_lord likes this.
  4. Mar 24, 2021 at 9:38 AM
    #124
    Hand Protectors
  5. Mar 24, 2021 at 9:43 AM
    #125
    Hand Protectors
  6. Mar 24, 2021 at 1:30 PM
    #126
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    BubbaW likes this.
  7. Mar 24, 2021 at 5:50 PM
    #127
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Got a couple more parts for the old girl. It’s going to feel good to change the fuel filter.
  8. Mar 24, 2021 at 6:14 PM
    #128
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    *laughs in no fuel filter!
  9. Mar 25, 2021 at 4:24 AM
    #129
    Hand Protectors
    Get some of this and wrap those threads about 4 times before tightening the flare nuts.
    Voss[OP] likes this.
  10. Mar 26, 2021 at 12:41 PM
    #130
    Voss
    2003 AC TRD 4x4
    Everything besides the fuel filter is in. I let it sit for a day so the rubber set well(the stuff in the tube used for the half moons and the corners of the valve covers). She drives smooth. I can't wait to fix my exhaust system. That should be the final item for the performance side of things to do on the truck.... Unless you all think there's something else I should really consider doing?
    Appreciate all the help along the way all! I don't know how I would get through these projects without you all!
  11. Mar 26, 2021 at 7:11 PM
    #131
    Voss
    2003 AC TRD 4x4
    So I’m trying to replace the fuel filter and things are not going great. I can’t stop the gas from spilling. It’s just coming none stop.
    I couldn’t put the yellow gas tap around the threads because of this.
    I tightened as much as I could without the yellow tape but it’s dripping this way.
    There’s a lot of gasoline...
    I’m thinking me being parked on a decline might have something to do with it? Would I be safe to tighten as much as possible and move the truck to a more level area?
  12. Mar 26, 2021 at 7:13 PM
    #132
    Voss
    2003 AC TRD 4x4
  13. Mar 26, 2021 at 7:28 PM
    #133
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Did you run your tank down close to empty?
    I'd bet not.... you just dumped like $7 on the ground.... :rofl:
  14. Mar 26, 2021 at 7:47 PM
    #134
    Voss
    2003 AC TRD 4x4
    I didn’t do anything close to that. Basically full tank
    Tundra2[QUOTED] likes this.
  15. Mar 26, 2021 at 7:54 PM
    #135
    NWPirate
    Zach
    WA
    Changed mine 3 months ago. I didn't use any tape, no leaks here. I had more issues with the plastic connector downstream.
    Voss[QUOTED][OP] likes this.
  16. Mar 26, 2021 at 7:54 PM
    #136
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Bummer. You'll lose more petrol to swap that fuel filter.
  17. Mar 26, 2021 at 8:01 PM
    #137
    Voss
    2003 AC TRD 4x4
    Yeah those plastic clips broke apart real quick
  18. Mar 26, 2021 at 8:02 PM
    #138
    Voss
    2003 AC TRD 4x4
    Not worried about that, just like to get it to stop leaking at this point.
  19. Mar 26, 2021 at 8:03 PM
    #139
    NWPirate
    Zach
    WA
    What side is leaking?
    Tundra2 likes this.
  20. Mar 26, 2021 at 8:13 PM
    #140
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Did you pop the gas cap loose to vent the tank and prevent expansion from pushing fuel out?
    Voss[OP], FrenchToasty and NWPirate like this.
  21. Mar 26, 2021 at 8:13 PM
    #141
    NWPirate
    Zach
    WA
    Keep in mind this is on my 04 Sequoia so things might be a little different.
    I didn't use any tape on the metal flare nut, I had issues with the red plastic keeper going back to its normal position. Everything is clipped in and sealed up, the hose clamp is just insurance.
    Voss[OP] and Tundra2 like this.
  22. Mar 26, 2021 at 8:16 PM
    #142
    NWPirate
    Zach
    WA
    Yep, helps big time.
    Tundra2 likes this.
  23. Mar 26, 2021 at 8:27 PM
    #143
    Voss
    2003 AC TRD 4x4
    I did but then closed it cause it was leaking a lot. Nothing really changed after closing it... kept leaking
  24. Mar 26, 2021 at 8:27 PM
    #144
    Voss
    2003 AC TRD 4x4
    the driver side
  25. Mar 26, 2021 at 8:28 PM
    #145
    Voss
    2003 AC TRD 4x4
    Soon enough I’ll make enough mistakes to get it right
    NWPirate[QUOTED] likes this.
  26. Mar 26, 2021 at 8:35 PM
    #146
    NWPirate
    Zach
    WA
    I meant upstream or downstream
    Edit: front or back fitting?
  27. Mar 27, 2021 at 1:54 AM
    #147
    Voss
    2003 AC TRD 4x4
    towards the front of the truck. The back side doesn’t seem to be leaking but then again it isn’t under much pressure. Glad I have the entire weekend to figure it out.
    It’s tight enough now where it’s only dripping into a pan. Good enough for now.
  28. Mar 27, 2021 at 6:00 AM
    #148
    Hand Protectors
    It. Can. Be. Done.
    You’ll need patience which it seems you have and some Hand Skills for Tape Wrap.
    1) Loosen the Filter Frame Mount Bolts a hair such that it has some wiggle room Mojo.
    2) Disconnect both flares/lines again. The dripping will ensue so you’ll be ready with bucket. I like a taller bucket than yours so its easier to move around and less slash back.
    3) Do the ‘non dripping’ flare line side first. This is practice for the Big Time Hand Moves on the other side. Wrap 4 wraps as best as possible. If you get sloppy tear the shit back off and re-do. Now... concentrate on the thumb to index money move when finding the flare groove on insert. You got this gurl! Tighten most of the way by wrenches but don’t crank it yet. *Remember* the two frame mount bolts are still slightly loose for wiggle Mojo.
    4) Now you are ready for the Big Time. Take a deep breath to inhale some more fumes and embrace the Pucks Rocky Mount Head Rush. You may begin entering into a mind warp at this point. This is living on the Edge of Ying and Yang!
    5) This side is gonna drip, as you know. Here is where I performed one of my best Hand Moves ever. Sadly, no audience but we can relive it here together. ***I pushed the flared pipe into the filter and held it which reduced the dripping to almost nothing! Simultaneously, I did the Tape Wrap Move using the other Hand. This is high level shtuff here! Spin the flare nut and watch the Tape Wrap around it like a 2.0.
    6) Now repeat the Flare Nut insert twist insertion like the other side. Tighten her down using the two wrench technique. Move over the the first side and tighten that down for the final torque. Move up and tighten the Frame Bolts to secure the final Mojo location on the Frame Mount.
    Voss[OP] and NWPirate like this.
  29. Mar 28, 2021 at 3:11 PM
    #149
    Voss
    2003 AC TRD 4x4
    All done. A couple tips for guys like me in the future.
    1- an ear plug in the line coming from the gas tank plugs things up nicely so you can work in peace.
    2- the fuel filter has rivets you need to align with the holder. The screw won’t reach unless they are aligned.
    Appreciate you all!
  30. Jun 7, 2023 at 9:25 AM
    #150
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Wanted to resurrect this thread to say, "This was a helluva read, my friend".
    I know it felt like you were a little worm on the end of a big friggen hook at times, but you did it (and probably much more since the last post was 2 years ago) and God bless you for it.
    Just goes to show that with patience, time, and perseverance, these sexy machines can be worked on by any of us.
