Help with brake controller swap (factory P3)
Discussion in 'Towing & Hauling' started by infiniteDH, Sep 13, 2020.
  1. Oct 1, 2020 at 5:43 PM
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    Weird... i've had good luck on the few things I've attached (granted not for extended periods) with the 3M automotive tape that has the red vinyl backing on it.
    I do clean the area real good with alcohol prior to use though.
    infiniteDH[OP] likes this.
  2. Oct 5, 2020 at 9:37 AM
    mass-hole
    mass-hole New Member
    I just put a RedArc Tow-Pro Elite in my Lexus GX. It was also plug-n-play and believe they make a harness for the Tundra as well.
    https://redarcelectronics.com/products/tow-pro-elite-electric-brake-controller
    https://redarcelectronics.com/products/tow-pro-brake-controller-harness-to-suit-toyota-tph-015
    They also make dummy switches so that the gain knob can go in one of the switch blanks in your dash and you don't need to drill holes.
    https://redarcelectronics.com/products/switch-insert-to-suit-toyota-mitsubishi
    When it is installed, the gain knob is the only thing visible. The actual control box gets mounted under the dash. I just used mine this weekend to tow my 5500 lb travel trailer behind my GX and it worked really well.
  3. Oct 5, 2020 at 8:31 PM
    infiniteDH
    infiniteDH [OP] New Member
    Dustin
    2017 Toyota Tundra Platinum
    I know you all have been waiting with bated breath for an update (lol), so here we go. The AutoZone order with 20% off the $140 P3 got canceled...twice. As did a Walmart order ($130.) Luckily, my Amazon order ($140) was delivered today, and I got it installed. I'll say this: those of you that installed it in 10-15 minutes definitely must have gotten the full dash panel vs just the plate because it def took waaaay longer than 15 minutes to install this biotch. Having said all that, I'm blown away by what a literal night and day difference the P3 is from the factory IBC. I took my 16' Big Tex car hauler out for a test drive and was able to actually lock up my brakes for the first time. Never could I do this with the IBC even at the highest setting. My IBC had completely sht the bed and was not even registering the trailer. Like someone else said, the P3 "just works." If you're on the fence, just do it. It is a 1000% improvement. Can't wait to actually feel safe pulling my Jeep. Happy trails, my friends. Next mod is more aggressive wheels and tires!
  4. Oct 5, 2020 at 8:37 PM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    i already had the panel off for some other work but it was only about ten minutes. just laid down the plate and drilled four holes = easy claps. i haven't been able to test my trailer yet but im glad to see your results - hoping i can lock mine up now :)
  5. Oct 5, 2020 at 8:47 PM
    infiniteDH
    Dustin
    My plate was slightly larger than where it installed, so I had to score the bottom on each side. I also had to cut out a section on the left of the dash panel so the P3 would fit. Finding the ground was also a PITA. However, now I'm done and am enjoying a cold beer or three. :)
    runCMD[QUOTED] likes this.
  6. Oct 5, 2020 at 11:49 PM
    TTund16
    TTund16 New Member
    Is 2017 IBC same as 2016?
  7. Oct 6, 2020 at 4:00 AM
    infiniteDH
    Dustin
    Believe so...or at least has the same issues.
