Help wiring ceiling fan/light
Discussion in 'Home Improvement' started by Clicknerdavid, Aug 21, 2022.
  1. Aug 21, 2022 at 12:24 PM
    Clicknerdavid
    Clicknerdavid [OP] New Member
    David
    Georgia
    2017 Tundra TRD Pro
    Greetings folks,
    I recently replaced a ceiling fan/light combo due to the old fan dying on me. When I bought the house there was three switches that appeared to operate the fan and light, although they never operated properly. You could turn the fan on and off with one switch (we’ll call it switch A), and the light on and off with another switch (switch B). The third switch (switch C) could turn the light OFF/ON only if the light had been previously turned on by switch B. Say you used switch B to turn the light on….then used switch C to turn it off, toggling switch B would no longer turn it back on.
    Hoping this is somewhat making sense…I’m sure it sounds whacky and confusing.
    Anyhow, I’m interested in trying to get these wired correctly. Ideally I would like one switch to control the fan independently and the other two switches to turn the lights on/off.
    Seems to be that there is several different ways possible of wiring this up from what I’ve gathered on Google. This is what I know:
    there’s one 12/3 going into the ceiling box for the fan/light combo.
    there’s two 12/2 wires and two 12/3 wires going into the 2 gang box that houses 2 switches (switch a and b)
    there’s one 12/3 wire going into the last box that houses switch c
    NOW, as confusing as all that is to me, I’m hoping it all makes sense to some of you electrician savvy folks who can help me out. Any advice? Thank you all in advance
  2. Aug 21, 2022 at 1:47 PM
    Retired...finally
    Three way switch on lights. Either bad switch or improperly wired.
  3. Aug 27, 2022 at 1:16 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    That’s a lot of wires. Some pictures would help.
  4. Aug 27, 2022 at 1:55 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I agree with @Retired...finally
    Switch A turns the fan on and off, period, that is it.
    Switches B and C are 3-way switches for the light.
    12-3 to the ceiling box
    1 light or fan hot
    2 light or fan hot
    3 netural for both
    4 bare cooper ground
    Apparently one of the 3-way switches is bad or wired incorrectly.
    My guess would be it is wired incorrectly.
    You'd need to get your DMM and see what powers what or call an electrician if you don't feel safe doing that.
    The fan switch is what it is, nothing is needed.
    The 3-way switches need to be addressed..
  5. Aug 27, 2022 at 2:15 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Show pics of your fan and the three j-boxes/switches
