Help! Truck cranks but won't start
Discussion in 'General Tundra Discussion' started by maxcala, Nov 14, 2019.
  1. Nov 15, 2019 at 4:40 PM
    maxcala
    maxcala [OP] New Member
    Max
    L.A.
    2014 Limited Crewmax
    No error codes.
  2. Nov 15, 2019 at 4:41 PM
    maxcala
    Max
    L.A.
    Yeah, i got no codes.
  3. Nov 15, 2019 at 4:41 PM
    maxcala
    Max
    L.A.
    I bought a new battery but still no go.
  4. Nov 15, 2019 at 4:42 PM
    maxcala
    Max
    L.A.
    I did but still no go
    15whtrd[QUOTED] likes this.
  5. Nov 16, 2019 at 7:05 AM
    hogpiolet
    hogpiolet New Member
    Jimmie
    2018 tundra Platnium
    none
    my motorcycle won't start if the battery in the fob is weak
  6. Nov 17, 2019 at 2:14 AM
    maxcala
    Max
    L.A.
    Is therr a battery in the keys?
  7. Nov 17, 2019 at 8:30 AM
    hogpiolet
    Jimmie
    none
    the fob that controls the alarm
  8. Nov 18, 2019 at 11:41 AM
    maxcala
    Max
    L.A.
    ok guys, been searching online with the issue of cranks but won't start. I've had my buddy bring his 2016 sr5 for me to check. So when he insert his key, the immobilizer LED stops blinking. When I insert my key and my spare key, it is still blinks. Anyone know how to fix this? I found a fix online to do a jumper on the OBD, has anyone tried it?
    TIA,
    Max
  9. Nov 18, 2019 at 11:43 AM
    maxcala
    Max
    L.A.
    I have an OEM fob and a viper alarm fob. I'll try and see if the OE fob will fix it.
    15whtrd likes this.
  10. Nov 18, 2019 at 1:58 PM
    AZBoatHauler
    So.Arizona
    When you replaced the battery, did you leave the terminals off long enough (at least 10 minutes) to allow the ECU to completely lose power? If not, I would try that. If that doesn't work, I would pull the remote start module and go back to stock wiring to see if that solves the issue. One time I noticed my key immobilizer light flashing while driving shortly after installing my Fortin remote unit. I have not been able to duplicate that issue.
    JohnLakeman likes this.
  11. Nov 18, 2019 at 2:38 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Mmmkay..."When I START it, the Battery light and Engine light is lit." Does that mean that you are actually getting the engine started with the new battery?? :confused:
  12. Nov 18, 2019 at 6:08 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Dude my buddy had this exact same problem in a 4 banger Toyota, same setup with the Viper alarm. A Viper tech showed him how to reprogram the fob by holding down the reset button on the alarm transponder that's mounted on the windshield by the rear view mirror. After that his car started fine.
  13. Nov 19, 2019 at 5:47 AM
    maxcala
    Max
    L.A.
    I didnt use the truck for about a month so the battery completely died so i charged it and install the battery back and still wont start. I removed the battery and bought a new and still wont start.
  14. Nov 19, 2019 at 5:50 AM
    maxcala
    Max
    L.A.
    Engine cranks but wont start with the old battery then i removed the battery to buy a new and still wint start.
  15. Nov 19, 2019 at 5:52 AM
    maxcala
    Max
    L.A.
    I cant seem to find the button to disable the viper alarm. I'll call viper tech support and maybe they can help.
  16. Nov 19, 2019 at 7:34 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Oh, I thought it meant Mother In Law...
  17. Nov 22, 2019 at 12:13 PM
    maxcala
    Max
    L.A.
    Hi all, all sorted out. Thanks to all who replied. Learned a lot on this thread.
  18. Nov 22, 2019 at 12:25 PM
    Badger Co-Op
    Badger Co-Op Blood sausage, cheese, and lutefisk; hit me!
    Kenny
    WISCO
    2 pages of confusion, and not going to share the solution?
    plumber802 and scpete24 like this.
  19. Nov 23, 2019 at 12:06 AM
    #49
    maxcala
    Max
    L.A.
    Its the immobilizer. Just needs reset and techstream was the solution.
  20. Nov 23, 2019 at 3:02 AM
    #50
    Badger Co-Op
    Kenny
    WISCO
    From the Viper or the OEM fob?
  21. Nov 23, 2019 at 7:05 AM
    #51
    maxcala
    Max
    L.A.
    Both. I've pressed both unlock button but the immo led still flashing.
    Badger Co-Op[QUOTED] likes this.
  22. Nov 23, 2019 at 10:19 AM
    #52
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Being a Techstream user, what area in Techstream deals with this and what were the steps taken if you recall ?
    edit....disregard, found it under "Smart Access/Utility/Smart Code Reset" if that's correct ?
    It also appears one has to download "ImmoReset PassCode Calculator" ?
  23. Nov 24, 2019 at 1:09 PM
    #53
    maxcala
    Max
    L.A.
    Yup, exactly!
