Help..transmission extension rear seal
Discussion in '1st Gen Tundras (2000-2006)' started by 2003stepside, Mar 7, 2020.
  1. Mar 7, 2020 at 10:22 AM
    2003stepside
    2003stepside [OP] New Member
    David
    2003 Tundra Stepside
    Transmission rear seal on my 2003 4.7 with auto trans was leaking and slinging the trans fluid. I had local mechanic replace seal with OEM seal . After about 75 miles leak started again. Does anyone have any input on what could be causing the leak. Is this something I need to take to dealer to troubleshoot?
  2. Mar 7, 2020 at 10:46 AM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    Did your mechanic notice any play at the output?
    I’m assuming this is a 2WD?
  3. Mar 7, 2020 at 12:29 PM
    2003stepside
    David
    It’s 2wd . The mechanic said he checked for play and also the weep hole that I have read can cause leak. I’m wondering if replacing the slip yoke will fix problem
  4. Mar 7, 2020 at 12:42 PM
    Alltimehigh
    Alltimehigh New Member
    My slip yoke has been leaking for a long time. I really need to change it. (Thought it was the seal at first also.) Some people say you can just JB weld the plug at the back of the slip yoke but I tried and I still have a leak.
    Let us know what you decide to do!
  5. Apr 23, 2020 at 8:16 PM
    Waterboyz
    Waterboyz New Member
    Fredericksburg VA
    2006 Silver Tundra X-SP Double Cab 2WD 18" Wheels
    Any update ? ?
