Help!!! Tonneau troubles w/ 2021 Tundra crewmax trail
Discussion in 'Tonneau Covers, Caps and Shells' started by Kingslary005, Oct 13, 2020.
  1. Nov 29, 2020 at 1:01 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    It rained pretty hard day after I installed it and so far so good.
    Vissarian[QUOTED] likes this.
  2. Nov 29, 2020 at 7:36 PM
    jcTundraTrail
    jcTundraTrail New Member
    2021 army green sr5 tundra trail edition
    Thanks so much For sending the pics!
  3. Nov 29, 2020 at 7:40 PM
    CorsoTundra
    North GA
    :thumbsup:
  4. Nov 30, 2020 at 3:11 PM
    Kingslary005
    Kingslary005 [OP] New Member
    Sorry for the long wait. Here are some pictures. As you can see, I cut ~1.5inch squares in the plastic with a multi-tool that are just big enough for the back of the bracket to sit in. This is best seen in pics 5 and 6. I did have to remove the deck rail system. Frankly, I wasn't a big fan of it anyhow. You are able to see the "hooks" I installed and provided a link to earlier. They are just black triangles. I used the screw holes and screws that came with the deck rail system for this. As such, there is still very good access for tie-down locations.
    Also, you can see the mx4 sits very low and the curved tailgate is not a problem. It is very waterproof. I keep my golf clubs in there and they get just a little wet when going through the car wash. Even in heavy rails, I have not noticed any water in the back. tun1.jpg tun1.jpg tun2.jpg tun3.jpg tun4.jpg tun5.jpg tun6.jpg
    MitchFamx4, Vissarian and EddieO like this.
  5. Dec 3, 2020 at 1:45 PM
    EddieO
    EddieO New Member
    Ed
    2021 Crewmax Trail Edition
    Thank you for the photos. Quick question??
    Did you order the Backflip MX4 with or without the bedrail system to get those cover clamps?
  6. Dec 3, 2020 at 2:13 PM
    Kingslary005
    They comes with both models. Don’t get the the for the bed rail system. That one would allow someone with out the boxes to lower the deck rail system so it could still be used. However, the boxes prevent this from being possible.
    EddieO likes this.
  7. Dec 4, 2020 at 6:14 AM
    IBeam
    IBeam New Member
    Southeast Texas
    2021 SR5 CM 4x4 Trail Edition, bed-mounted M2
    jonclark96:
    I have new trail version and I am toying with the notion of removing the bed cargo bins. Was your removal done without any issues?
    jonclark96 likes this.
  8. Dec 4, 2020 at 6:34 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Removal was easy. You need to remove the cargo tie down near the tail gate, the bolts that hold the rail system to the bed, and then one bolt on the interior of the tool box. All you need is a star bit and and a screw driver.
    If your truck is like mine, there is a spot at the bolt through the box where there isn't any bed liner installed, but is should be an easy touch up. There are some pictures I posted up in my thread on installing my tonneau.
    IBeam[QUOTED] likes this.
  9. Dec 4, 2020 at 6:36 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
  10. Dec 4, 2020 at 9:13 AM
    tgs303
    tgs303 New Member
    I’m opting for the soft roll up as well similar to the one posted here. I talked to a couple different truck accessory places and this is what they all recommended without having to make any modifications or removing the boxes. I would have preferred a either a hard or soft folding cover, but I don’t want modify it too much. I also don’t want to store the boxes in my garage and have to reinstall later. It’s a lease and not sure if I’ll be keeping it after the times up. Definitely sticking with the Tundra, but it’ll just depend on what the deal is at the time on whether I keep it or lease a different one.
  11. Dec 4, 2020 at 2:52 PM
    IBeam
    IBeam New Member
    Southeast Texas
    Thank you. So your found bare metal spots under the removed bed bins? IOWs, incomplete bedliner spray job prior to attaching the boxes?
    jonclark96[QUOTED] likes this.
  12. Dec 4, 2020 at 3:04 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    I think these are the spots he talking about. . Thats what it looked like after I took my boxes out.20201204_180212.jpg
  13. Dec 5, 2020 at 4:32 AM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Yes. There are missing spots in the bed liner, not the paint.
  14. Dec 5, 2020 at 5:44 AM
    Terra27
    Terra27 New Member
    Bethlehem GA
    2021 Tundra Trail Edition
    Hi CorsoTundra, did you order the X15 model for installation with the deck rail system or without?
    Just got my 21 Trail Edition and love the bed storage but need a cover as well. This look like what I’m looking for thanks for posting.
    CorsoTundra[QUOTED] likes this.
  15. Dec 5, 2020 at 6:33 AM
    jcTundraTrail
    Thanks everyone on this thread! I can confirm the prox15 Works without any modifications to the trail edition Tundra!
    CorsoTundra likes this.
  16. Dec 5, 2020 at 7:06 AM
    CorsoTundra
    North GA
    With deck rail.
    Terra27[QUOTED] likes this.
  17. Dec 5, 2020 at 7:06 AM
    CorsoTundra
    North GA
    That looks as good as mine
    DIYDad likes this.
  18. Dec 5, 2020 at 7:43 AM
    IBeam
    IBeam New Member
    Southeast Texas
    Nomoredomestics and Jonclark956: Thanks a lot
    Wonder if a dealer would touch up that bare spot or if it would look odd afterwards....
  19. Dec 5, 2020 at 8:10 AM
    #49
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Anytime. . .and I need to go to one if the local bedliner shops and see if they'll touch it up.
  20. Dec 5, 2020 at 8:54 AM
    #50
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    No worries.
    I’m pretty sure a rattle can of touch up would do the trick.
  21. Dec 7, 2020 at 4:23 PM
    #51
    IBeam
    IBeam New Member
    Southeast Texas
    Howdy. I have a brand new 2021 CM in the Trail Edition, which comes equipped with the slim profiled, but sturdy lockable storage bins (one over each wheel wheel). I removed them to maximize bed use. I will likely sell them if my friend does not want them. I posted here because my account here is less than 30 days old so I am prohibited from posting new threads (I tried to do so on the marketplace forum). Don’t want to derail the original scope of this tread but maybe this one time:
    I am posting this to gauge the interest level of the members. As a frame of reference, I don't know what the dealer charges for them, or if they even offer them over the counter since they are relatively new item (I called a dealer and was clueless). Anyway, please chime in if that might interest you. Any feedback as to their worth is appreciated. By the way, they install simply with two Torx nuts.
    I found this video, which provides a good overview:
    https://www.youtube.com/watch?v=wkMg981sIYA
  22. Dec 19, 2020 at 8:40 PM
    #52
    rrp0968
    rrp0968 New Member
    Still available?
  23. Dec 19, 2020 at 8:44 PM
    #53
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    I have a set for sale in the marketplace section.
    Tundyfundy likes this.
  24. Dec 19, 2020 at 9:40 PM
    #54
    rrp0968
    rrp0968 New Member
    Saw yours as well, you are much farther away from me. I am in South Louisiana.
  25. Dec 20, 2020 at 8:03 AM
    #55
    IBeam
    IBeam New Member
    Southeast Texas
    rrp0968: I will soon post it...just have a lot of personal problems right now...
  26. Dec 20, 2020 at 8:52 AM
    #56
    rrp0968
    rrp0968 New Member
    No worries.....was just checking.
  27. Dec 26, 2020 at 7:58 PM
    #57
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    That's good to know. I have that same cover already, so if any of these boxes show up for sale near me I may just grab them.
    I like the idea of these boxes since it really only takes up the mostly unusable space around the wheel well.
  28. Jan 28, 2021 at 5:59 PM
    #58
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I'm looking at a cement trail edition, has anyone else come up with tonneau cover solutions? I currently have have a backflip cover on my 17 crewmax and it leaks a little. So I'm up in the air as to what cover to go with on a new truck. I may just go with a soft color, idk?
  29. Jan 30, 2021 at 4:22 PM
    #59
    Dagooagoo
    Dagooagoo New Member
    2021 Tundra Trail
    #26 post, (corsotundra)
    did you have to mod the installation in anyway? I’ve got the exact same color and truck as you all the way out in the Big Island and I need a cover. Trade winds out here are out of control sometimes!
    when I looked up the cover you specified on Amazon, the manufacturer responded to my query that it would not fit! There answer was not easy to understand.
    should I get it with the track rail system? Without?
    I’m tempted to purchase it anyway and see what happens.
    Can you post a link to the exact purchase?
    Thanks!
    (First time poster) boooom.
    hillbillytoyo likes this.
  30. Feb 3, 2021 at 5:44 PM
    #60
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I find it funny on the Amazon listing for that tonneau cover it specifically excludes trucks with trail edition boxes in the title even though you both have it and are happy with it. https://www.amazon.com/TruXedo-Roll-up-Tonneau-1463801-Toyota/dp/B0711RQJ7B?th=1
