Help .... tires don’t fit
Discussion in 'Wheels & Tires' started by Radical08, Jul 7, 2018.
  1. Jul 7, 2018 at 10:09 PM
    Shonuff
    Shonuff New Member
    2007 Tundra TRD
    Pro comp 6 inch lift
    It looks like your running a 6" lift which only allows for a 35x12.50 or 325/45. In order to run a 37" your gonna have to have at least a 7" lift which will still require minor trimming.
  2. Jul 7, 2018 at 11:18 PM
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    When and if he goes to 37's what are the odds he comes into more issues that will need to be adjusted as well? Asking because my shop and I are looking at pro comp stage 2 with 37's Toyo OC M/T but may have to settle with 35's for the time being with the thought above.
  3. Jul 8, 2018 at 7:39 AM
    Radical08
    Radical08 [OP] New Member
    White lift d Tundra
    Lifted, skid plate, front bumper delete
    @GNTundra you think front coil overs would work ? I’ll post a picture of the back later today as well ..
  4. Jul 8, 2018 at 7:42 AM
    Radical08
    White lift d Tundra
    @qweegybo how much cutting did you have to do ?
  5. Jul 8, 2018 at 8:09 AM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Get a reasonable offset. I believe you can stuff 37”s without cmc with stock offset and ~2.5-3” lift +ucas. It is his -44 offset that is killing him.
  6. Jul 8, 2018 at 8:20 AM
    Pale_Horse
    FL
    Cupcake chit.
    Yes it looks way better with 37”s. I would either lift more, or swap wheels that are around 0 to idk +25ish offset 10wide. Unless you are going for that stretch tire look you don’t need 12” wide wheels.
    Or try glass fenders+cmc
    Mountun Goat likes this.
  7. Jul 8, 2018 at 9:31 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’m liking this thread.
    There’s also stock fender pulled out as well for a cheap wider fender. Just cut all the inner to outer fender mounts and pull the fender out until they stuff and weld new extension tabs on.
    equin likes this.
  8. Jul 8, 2018 at 11:40 AM
    Radical08
    White lift d Tundra
    @Pale_Horse The wheels are non refundable unfortunately so I either have to figure how to make them fit or sell them .. if I’m at 6inch now how much would it take to lift my truck a few more inches ?
    Mountun Goat and GNTundra like this.
  9. Jul 8, 2018 at 11:42 AM
    Radical08
    White lift d Tundra
    @2ndgenny Yeah was thinking about getting fiberwerx fenders just not sure if it will fit with that and how much cutting I would still need to do ..
  10. Jul 8, 2018 at 11:47 AM
    Radical08
    White lift d Tundra
    @GNTundra Coilovers sounds like they are the easiest fix then. What are some good ones for 7inch plus lift .. if Fox has a good pair that would work I get a discount on there stuff .. I look into but any suggestions will help
    GNTundra likes this.
  11. Jul 8, 2018 at 1:13 PM
    Radical08
    White lift d Tundra
    @GNTundra I think it’s a 6inch lift and bought the truck with the lift on it so not sure exactly what it is ...
  12. Jul 8, 2018 at 5:16 PM
    Pale_Horse
    FL
    Cupcake chit.
    I would say 3” body lift and cmc might get you there and be your easiest and cheapest route I think. Well, besides :sawzall:
    That is going to be a giant freaking lift lol.
    Let us know how it goes.
  13. Jul 8, 2018 at 8:15 PM
    qweegybo
    qweegybo New Member
    ef
    Camburg build
    They cut the entire outer funder, and most of the inner, only retaining some of the inner for mounting the fiberglass flared fender
  14. Jul 8, 2018 at 8:17 PM
    qweegybo
    qweegybo New Member
    ef
    Camburg build
  15. Jul 8, 2018 at 8:18 PM
    qweegybo
    qweegybo New Member
    ef
    Camburg build
    Stepped in gum in this one, ruined my new shoes!
    Mountun Goat, landphil and Yzed608 like this.
  16. Jul 9, 2018 at 3:35 AM
    Adam New Member
    That's not gum...;)
    qweegybo and Mountun Goat like this.
  17. Jul 9, 2018 at 1:22 PM
    Radical08
    White lift d Tundra
  18. Jul 9, 2018 at 4:46 PM
    Radical08
    White lift d Tundra
    @qweegybo Thats a clean set up !! @GNTundra Thanks appreciate it also thinking about selling my wheels and getting less an offset .. what do you think the widest offset I can run anyone know ?
    qweegybo and GNTundra like this.
  19. Jul 9, 2018 at 4:55 PM
    #49
    Radical08
    White lift d Tundra
    @GNTundra How big is your lift ? I have 37s now not sure my offset is but wondering the widest I could run with my 6inch lift now ?
  20. Jul 9, 2018 at 5:01 PM
    #50
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Completely THIS.
    That super aggressive offset is the killer here.
  21. Jul 9, 2018 at 5:17 PM
    #51
    Radical08
    White lift d Tundra
  22. Jul 9, 2018 at 5:20 PM
    #52
    Relentless
    Eric
    For max tire size you're best staying as close to 0 offset as possible. +18mm to -12mm is pretty common. Your -44 is around 1 1/2" to 2" farther out and more steering scrub radius than most guys run.
    For instance, a set of 35x12.50's just BARELY rub with a +18mm wheel on only 2-3" of lift and your caster maxed out on the alignment.
  23. Jul 9, 2018 at 6:54 PM
    #53
    Pale_Horse
    FL
    Cupcake chit.
    Damn this looks good. What specs on wheels/suspension?
  24. Jul 15, 2018 at 7:48 PM
    #54
    qweegybo
    qweegybo New Member
    ef
    Camburg build
    Details as requested.... not cheap, but done right the first time... saves headaches down the road.20180715_224456.jpg
    Pale_Horse likes this.
  25. Jul 17, 2018 at 8:35 AM
    #55
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    That is a sick truck!!
  26. Aug 22, 2018 at 11:13 AM
    #56
    Radical08
    White lift d Tundra
    UPDATE -
    I ended just buying new wheels with +18 offset and 37x13.5x20 .... still trying to sell my old wheels
