Help! Swapped headunit, truck not starting. Immobilizer?
Discussion in '1st Gen Tundras (2000-2006)' started by fctry, Oct 10, 2019.
  1. Oct 11, 2019 at 4:04 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Wonder if the wire supplied power to the cigarette lighter when key is/was off?
  2. Oct 11, 2019 at 4:23 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    This drawing might not help but I think you're are possibly onto something !
  3. Oct 11, 2019 at 5:05 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Like you, I have unplugged my DRL.
  4. Oct 11, 2019 at 5:54 AM
    tvpierce
    Maine
    Here's a pic of mine. I think I have it marked consistently with yours. The green is the DRL connector (disconnected). The red is what you have only one side of. Does that seem right?DRL Plug+.jpg
  5. Oct 11, 2019 at 6:18 AM
    Rubberdown
    Tow package option? Maybe for power to charge trailer through plug?
    TX-TRD1stGEN likes this.
  6. Oct 11, 2019 at 8:44 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    That small wire can be numerous things. Need to trace it down. I’ve seen aftermarket alarms with that wire and aftermarket tow trailer converters...
    speedtre likes this.
  7. Oct 11, 2019 at 10:14 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    You a Phan?
  8. Oct 11, 2019 at 11:22 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Take the wire and ohm it out to ground. That'll at least tell you if its shorted or over-amping. Whatever it is.
  9. Oct 11, 2019 at 2:42 PM
    Aerindel
    Aerindel New Member
    Montana
    Yes, that is right. I believe that is the connector that the OP's mystery wire is going to. I have both sides of the connector but where a wire would go there is just a rubber plug.
  10. Oct 11, 2019 at 4:12 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    I dig the music and I’ve heard them on Sirius Xm Jam-On. But I haven’t been exposed to them a lot. Don’t know much about the band other than killer mountain driving music with the sunroof open.
  11. Oct 11, 2019 at 4:23 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    In true Phish fashion, caps and stems would go good with that drive :cool:
    Darkness and bmf4069 like this.
  12. Oct 11, 2019 at 4:48 PM
    NoRcptn
    NorCal
    2017 Platinum
    True!
    It’s really a lost genre - Dead, phish, string cheese. I can almost guarantee my kids will never just sit and listen to a long jam. It’s all about rap to them. Sorry I Highjacked the thread!
    Darkness likes this.
  13. Oct 11, 2019 at 5:48 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Subaru are known to need this as well. At least on my old 2008 Forester sport. After disconnecting the battery , I had to let it idle for a while, the ECU needs to relearn. And also relearn my driving habits.
  14. Oct 13, 2019 at 5:29 PM
    DividedSky
    Jeff
    yeah, guess it shows my age but I’ve seen all of the ones you listed. Some Leftover Salmon as well.
    Probably 30 Dead shows under my belt before Jerry kicked it and 50+ Phish shows.
  15. Oct 13, 2019 at 5:30 PM
    DividedSky
    Jeff
    Lol. I guarantee mine WILL, but not by choice!
  16. Oct 14, 2019 at 2:44 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Theyll get past rap one day. You'll catch them sipping a beer with some Doc Watson and David Grisam playing.
  17. Oct 14, 2019 at 4:47 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Git back and whip her brother and whip her pa...
    https://www.youtube.com/watch?v=Gr9GM-TdYG4
  18. Jan 5, 2020 at 4:27 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    That wire is something that was added. You know one thing added was a trailer hitch. My guess is the wire was for a trailer brake controller.
    To add. Just delete that wire to the plug to clean it up. You know it is something that the truck did not have from the factory. And the wire in the harness is for some reason or option you dont have.
    Some owner must have removed something they installed and just cut the wire at the end. And it has shorted out so the fuse blew.
    If bored you could look under the dash to see if someone drilled some mounting holes. And looks like something was removed.
    Some electronic trailer brake controllers needed constant 12 volts so that still a possibility.
    And I recently replaced my OEM trailer hitch. And noticed around the trailer hitch there was a similar OEM plug back there that had a OEM cap in the plug. Not something I needed for standard trailer lights. So did not care what it was for.
    It is at least a possibility that you may even find this is the other end of the wire you are dealing with.
  19. Jan 5, 2020 at 5:35 PM
    #49
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I remember the first time this happened to me. I don’t remember what made me think ‘when in doubt, throttle out!’ and that’s exactly what I did and it cured itself. Sorry I was in the mountains this weekend otherwise I could have jumped in sooner. Glad one of the other guys were able to jump in and help you out! Nothing feels better than getting back on the road!
    I will say up in the mountains this weekend, I saw a TON of first gens and not one Tacoma. I think that’s where they all go to retire.
