Help. Suspension question
Discussion in 'Suspension' started by meeerafael, Jul 16, 2017.
  1. Jul 16, 2017 at 5:36 PM
    meeerafael
    meeerafael [OP] New Member
    Rafael
    2012 toyota tundra sr5
    Leveling kit, 20in tires, bedliner, headlight and tailight smoked, led head and tail lights and little more.
    I just got my 2012 Toyota tundra and decided I want to keep it that i am willing spend money on it. I wanted to run bigger tires for the winter here in Alaska. I heard alot of bad things about lifts and was leaning towards a levelling kit. Would leveling the tundra make it less comfortable to ride? Would my lvling kit make my truck parts worn out faster? And what is the maximum lift i can do and biggest tire i can put if I do so? Thank you so much guys!!
  2. Jul 16, 2017 at 5:40 PM
    LML 3500HD
  3. Jul 16, 2017 at 5:42 PM
    LML 3500HD
    Law323 and SouthBoundSteve like this.
  4. Jul 16, 2017 at 5:52 PM
    Edited title so members aren't in a panic thinking you're stuck somewhere.
  5. Jul 16, 2017 at 5:56 PM
    meeerafael
    Rafael
    I apologize sir. Im still very new, I will make sure not to do that next time. I really appreciate it
    T-Rex266 likes this.
  6. Jul 16, 2017 at 5:57 PM
    Hey, no problem at all. This forum has members that'll drop everything to go help someone out :thumbsup:
    ColoradoTJ and CM-LENNY like this.
  7. Jul 16, 2017 at 5:58 PM
    meeerafael
    Rafael
    That's amazing! I really appreciate it sir. Thank you
  8. Jul 16, 2017 at 5:59 PM
    Welcome from CO, btw!
  9. Jul 16, 2017 at 6:53 PM
    gosolo
    Ray
    NW Oregon
    @meeerafael
    Welcome from AZ! Let's see some pictures!
    the question you asked is a good one without a simple answer.
    Some folks are anxious to get someplace and others are more interested in looking good getting there.
    Which are you?
    Simply put, the engineering done on these trucks will dictate that running stock suspension and tires will be best for the truck. This may not be the best way to serve YOUR purposes. Some lift would help your approach and departure angles and bigger wheel/tire diameter will give you better clearance. The more changes you make in the suspension and wheel/tires, the more the original design engineering is altered and stresses are increased, and yes, you may have premature failures. It could be incremental and it could be worth it if you're running a trap line in the bush.
    What exactly are you doing with your truck? If it's just adding mud/snow tires for bad weather that's one thing. For several of my rigs, I had two full sets of tires mounted and balanced. I'd run studded mud n snows all winter and put the others back on in the spring.
    Darth Tundra likes this.
  10. Jul 16, 2017 at 7:01 PM
    Bienvenidos de Tejas!
  11. Jul 16, 2017 at 7:14 PM
    meeerafael
    Rafael
    My main thing that I want is for looks and then better handling in the snow because it snows alot here in Alaska. The guy in the shop told me to do a roughcountry leveling kits for 3in and put a 305 70 r18. But I am a little worried about trimming. I know I should trust him because he knows what he is doing but I just want to double check prior to doing so. He also quoted me $750 to do the leveling for 4 hours. I didnt want to go so high because they i researched that doing a lift kit rather than a leveling kit would damage my vehicle (worn certain things out faster). I guess is it worth it to do level kit for those two reasons? Would it worn my parts faster if I do just a simple leveling kit like a lift kit would do so?
    I really appreciate you time. Thank you for answering my questions.
  12. Jul 16, 2017 at 7:17 PM
    meeerafael
    Rafael
    Mine is pretty basic. Its just a 2012 double cab tundra sr5. I did got lucky cause it only has 14k miles when I got it couple of months ago.
    Law323 and ColoradoTJ like this.
  13. Jul 16, 2017 at 7:18 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    I personally went with a Revtek 2.5 inch spacer up front....a little trim job on skidplate, took front little guards off that sit in front of tires, and threw a set of 295/70/18"s on my stock rims.....sits level and higher...did not put ANYTHING in the rear !!..No blocks in rear because i HATE RAKE ON A TRUCK !!!...My truck sits perfectly LEVEL....As far as ride comfort, its fine...but if you want SOFT ride you have to spend a little coin and go with Coilovers or adjustable shocks ...Cost me less than $100 for the Revtek kit and a little sweat as i am in the Autobody trade and did everything myself.
  14. Jul 16, 2017 at 7:21 PM
    Darth Tundra
    Curt
    17 CM TRD Black
  15. Jul 16, 2017 at 7:25 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Revtek leveling kit is the ONLY spacer kit that Toyota approves. Thats what both Toyota dealerships told me here in Portland Oregon..Factory Warranty is honored with this kit installed.
  16. Jul 16, 2017 at 7:34 PM
    LML 3500HD
    Another faster white Tundra men!!!
  17. Jul 16, 2017 at 7:35 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    :crazy: :facepalm: :goingcrazy: :goingcrazy: :goingcrazy:....lol
  18. Jul 16, 2017 at 8:01 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
    GNTundra likes this.
  19. Jul 16, 2017 at 8:27 PM
    meeerafael
    Rafael
    Got pics of your truck? Im curious what it looks like
  20. Jul 16, 2017 at 8:27 PM
    meeerafael
    Rafael
    Thank guys i appreciate it!!!
  21. Jul 16, 2017 at 8:30 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Law323 likes this.
