Help shackle install/removal
Discussion in 'Suspension' started by xtyfighterx, Apr 23, 2019.
  1. May 7, 2019 at 7:07 AM
    #91
    MNBighead
    MNBighead New Member
    2015 CREWMAX TRD OFF ROAD
    Well this went just about as expected. Total nightmare that took from 9am-4pm, mainly due to the drivers side. All OEM components completely frozen with rust on a 2015 truck. Can blame MN winters and the liberal use of salts on the road. Unreal.
    equin likes this.
  2. May 7, 2019 at 7:11 AM
    #92
    MNBighead
    some pics of the process. I envy all the folks outside of the rust belts were things just pull apart. I had to cut bolts and make custom press sleeves since the Harbour frieght maddox ball joint kit doesn come with the correct size for pushing out the Oem bush inside of the leaf. Even the oem shackle side plate was frozen/rusted to the bolts and unable to remove initially.
    NewImprovedRon, equin and BlackSheep like this.
  3. May 7, 2019 at 7:41 AM
    #93
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Welcome to the club buddy! At least you got both out as one piece lol I only got one the other side I had to torch the bushing and cut the sleeve:
  4. May 7, 2019 at 8:22 AM
    #94
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Yeah, definitely feel your pain. I'm glad you eventually succeeded! I'll never do it again. My time is worth more than the extra cost to pay someone who has the proper tools and know-how. I installed the whole rest of my kit (coilovers, diff drop, carrier bearing drop) in less time than it took me to replace the shackles and their four bolts. I'm still more than a little pissed nearly a month later.
    How about pics of the finished product? ;)
    TOYOTRD8 likes this.
  5. May 7, 2019 at 9:18 AM
    #95
    MNBighead
    I'll post some pics tomorrow. Same with me, the rest of the project / kit went just fine and took less time than the shackles and 4 bolts. I'm running 6112's at 1.9" and +2 CB shackles with 275/70/18
  6. May 7, 2019 at 11:44 AM
    #96
    BlackSheep
    Scott
    Kansas City, MO
    Funny thing is, I had called a few shops around town for install prices before I committed to doing it myself, and one of them (that ended up convincing me to do it myself) was like "2 hours for the fronts, so $250, and there isn't much to the rear." Au contraire.
  7. May 7, 2019 at 12:21 PM
    #97
    xtyfighterx
    Ty
    North Idaho
    If I ever do another trucks and the bolts are stuck I’m taking the leafs off torching the bushing and sawzaling the the sleeve out that took less time then messing with the press and everything else.
    Coachbuilder1 likes this.
  8. May 13, 2019 at 11:43 AM
    #98
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Glad to hear they're in :) I would still install the CB drop kit, over time it will help with over all wear on the U joints/Pinion.
  9. Jun 12, 2019 at 12:10 PM
    #99
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    So just so im understanding going to install poly bushings this week from coach the bushing and inner and outer metal sleeves need to come out to install the poly correct?
  10. Jun 12, 2019 at 1:00 PM
    #100
    xtyfighterx
    Ty
    North Idaho
    Yes inner and outer sleeve has to come out. Good luck!
  11. Jun 12, 2019 at 1:01 PM
    #101
    Yota100
    Yota100 New Member
    Well that just made it interesting lol
  12. Jun 12, 2019 at 1:04 PM
    #102
    xtyfighterx
    Ty
    North Idaho
    It’s a bitch
    BlackSheep likes this.
  13. Jun 12, 2019 at 1:05 PM
    #103
    xtyfighterx
    Ty
    North Idaho
    I got one fully out with the ball joint press: the other I torched the bushing out and then cut the outer sleeve with the sawzall and took a chisel and pounded it out.
  14. Jun 12, 2019 at 1:06 PM
    #104
    xtyfighterx
    Ty
    North Idaho
    Soak in PB blaster or break away for 48 hours
  15. Jun 12, 2019 at 1:08 PM
    #105
    Yota100
    Yota100 New Member
    Yeah reading through the thread seems like it can be a nightmare. I gotta good feeling mine will be stuck going to start soaking tonight
  16. Jun 12, 2019 at 1:09 PM
    #106
    xtyfighterx
    Ty
    North Idaho
    Yep mine bolts were even seized in the sleeve had to cut the shackle off with a sawzall to
  17. Jun 12, 2019 at 1:55 PM
    #107
    MNBighead
    My Drivers side bolts were sized also. See my pics. Give yourself plenty of extra time to accomplish this task.
  18. Jun 15, 2019 at 8:19 AM
    #108
    Yota100
    Yota100 New Member
    Well update thankfully took me 10 mins to get mine out surprisingly mainly because the ball joint tool was a pain in the butt to set up by myself lol but for 138k miles they came out super easy with my 3/8s impact and a 26 mm socket I think I can't remember
    4x4_Angel likes this.
  19. Jun 15, 2019 at 2:22 PM
    #109
    xtyfighterx
    Ty
    North Idaho
    Dam lucky
    Yota100[QUOTED] and BlackSheep like this.
  20. Feb 9, 2020 at 2:04 AM
    #110
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Are the shocks removed for this process or left in place?
  21. Feb 9, 2020 at 4:53 AM
    #111
    xtyfighterx
    Ty
    North Idaho
    How high are you going in the rear?
    Shouldn’t have to.
  22. Feb 9, 2020 at 5:10 AM
    #112
    Yota100
    Yota100 New Member
    Mine were at the time
  23. Feb 9, 2020 at 7:33 AM
    #113
    BlackSheep
    Scott
    Kansas City, MO
    Not sure if it's necessary to remove them if you're only installing 1" or 1-1/2" shackles. I removed mine though. It's only one bolt per side and they aren't hard to line up to reinstall.
  24. May 27, 2021 at 10:20 AM
    #114
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    @xtyfighterx this is an old thread but DAMN did I just feel your pain. I was worried about getting my front coilovers installed. That took about 6 hours of hard work but went in relatively smoothly. I thought replacing the rear shackles would be easy after doing the fronts. I got 3 out of the 4 bolts but couldn't get the last one out. Rusted and seized up from PA winters. Had to pay the shop $250 to get the old shackles out and new ones in.......Some BS!
  25. May 28, 2021 at 5:24 AM
    #115
    xtyfighterx
    Ty
    North Idaho
    Yep defiantly wasn’t a fun install for how simple it would of been. That’s why I tell everyone to soak the bolts and bushings in PB blaster or some kid of penetrating oil for like 3 days straight before touching the shackles.
    TXTundra2722 likes this.
  26. May 28, 2021 at 5:34 AM
    #116
    BlackSheep
    Scott
    Kansas City, MO
    Can I guess?...driver side, rear bolt was the seized one.
  27. May 28, 2021 at 5:39 AM
    #117
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Driver’s side, bottom bolt. They needed to whip out the torch after it whipped their asses like it did mine.
  28. May 28, 2021 at 5:51 AM
    #118
    BlackSheep
    Scott
    Kansas City, MO
    yepppppp mine was seized up too. I manage to get the bolt out at least, but a full day of torching, beating, pressing, and air hammering the bushing got me nowhere lol. I keep that damn bushing as a memento to remind me that some things are just better to pay the pros to do :rofl:
  29. May 28, 2021 at 3:26 PM
    #119
    xtyfighterx
    Ty
    North Idaho
    Torch hammer and chisel will be your best friend on this
  30. Feb 11, 2022 at 2:05 PM
    #120
    a_double
    a_double New Member
    Do the press in bushings only come out in 1 direction? if so, which direction should the be pressed out? TIA.
