Help shackle install/removal
Discussion in 'Suspension' started by xtyfighterx, Apr 23, 2019.
  1. Apr 23, 2019 at 1:38 PM
    #61
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    like i noted earlier, put your helmet and goggles on, shit will come out of there hotter than a hooker in church...or just explode...
    Newm, BlackSheep and 15whtrd like this.
  2. Apr 23, 2019 at 1:46 PM
    #62
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    definitely helps to remove the leaf pack from the truck, as long as you have another way to keep it immobilized while you work on it. I was able to get enough leverage this way to turn the bolt enough to break it free, but unfortunately, it just ripped through the rubber. If that happens you'll still have to contend with that metal sleeve others have mentioned.
    15whtrd likes this.
  3. Apr 23, 2019 at 1:47 PM
    #63
    BlackSheep
    Scott
    Kansas City, MO
    for real though. i'm lucky i have both my eyes. my pry bar hit me just below the eyebrow, and my glasses went flying.
    conlons26[QUOTED] likes this.
  4. Apr 23, 2019 at 1:51 PM
    #64
    BlackSheep
    Scott
    Kansas City, MO
    one more thing, if you can get enough of the metal sleeve out of the spring to get a pipe wrench on it, you should be able to work that back and forth enough to get it the rest of the way out.
    15whtrd likes this.
  5. Apr 23, 2019 at 2:05 PM
    #65
    Newm
    Newm New Member
    KC
    IDK but I have been checking this thread all day as I know all to well the frustrations that wrenching can bring me....come on @xtyfighterx , you got this! :)
  6. Apr 23, 2019 at 2:25 PM
    #66
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    If this dude lived by me , i would leave work "sick" and get some beers and go help this guy
  7. Apr 23, 2019 at 2:34 PM
    #67
    15whtrd
    15whtrd Mr. Blonde
    I was thinking the same thing. Idaho is a little far.
  8. Apr 23, 2019 at 6:51 PM
    #68
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Thanks fellas so I took out a leaf pack and they are siEZed I ordered new poly stuff from coach.
    I worKed it back and forth sledged it you name it I burned it out and I’m getting the sleeves pressed out so I’ll install the new poly stuff and new shackles and everything should go smooth appreciate all the help today I really didn’t plan for this to be that difficult lol
  9. Apr 23, 2019 at 7:01 PM
    #69
    Porkchop Express
    Cody
    2017 Tundra CM
    Well hey , you got it done-ish
    xtyfighterx[OP] likes this.
  10. Apr 23, 2019 at 7:10 PM
    #70
    xtyfighterx
    Ty
    North Idaho
    Ya I should of ordered them anyway when I got the carrier bearing drop
  11. Apr 23, 2019 at 7:19 PM
    #71
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    :popcorn: I'm not doing anything to my truck (not right now anyway) but I was interested in why this thread was 3 pages deep. I was literally pulling for the OP and wishing I was close to lend a hand.
    Now all we need is pics of the finish.
    Glad you got it worked out. So far.
  12. Apr 23, 2019 at 7:26 PM
    #72
    AZTundra
    Paul
    Phoenix, AZ
    Things never seem to go as easy as they should. Just like watching your favorite wrenching show on Velocity....remove a couple bolts here and there, pull this out of the way and whala engine removal in 5 mins completed....I'd like to see the full episode when they start swearing and throwing tools at the wall.
  13. Apr 24, 2019 at 7:52 PM
    #73
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    Man, I feel your pain. Just did my +1 shackle this afternoon. Everything was going fine until I needed to press those bushings out. Thought I could cheat with a C-clamp and piece of round stock I had lying around. Boy, was I wrong. I had to stop what I was doing and rent a ball joint press from Advance. I wish I had done that earlier. Bushing number 1 came out like a bullet. Bushing number 2 wasn't going without a fight. Rubber internals pressed out, but left the sleeve. Was about to set fire to the truck, but 12 ounces later, I returned with the Sawzsall and cut the bitch out. Cleaned up the holes, lubed the bushings, and pressed everything together.
    Poly makes a difference. Glad I went with the 2 -1 level setup. Looks great in the dark, but don't we all?
  14. Apr 25, 2019 at 3:39 AM
    #74
    xtyfighterx
    Ty
    North Idaho
    Ya man it’s retarded torch and air chisel worked wonders just waiting on bushings now.
  15. Apr 30, 2019 at 6:07 AM
    #75
    xtyfighterx
    Ty
    North Idaho
    Got my poly bushings yesterday took the plunge and installed what a PITA. I have to cut out the stock shackles then I used a ball joint press my press to get the passenger said out but the driver side wasn’t having it.i have to torch out the middle then cut the outer sleeve with a sawzal and then chisel it out after all that everything went smoothly. I removed my 1in block and added these 2in shackles and what a difference night and day. Rides like butter! Thanks everyone for the help I’ll post pics up later today
  16. Apr 30, 2019 at 6:33 AM
    #76
    Porkchop Express
    Cody
    2017 Tundra CM
    Dang man , sorry that was such a bitch. Glad you got it done
  17. Apr 30, 2019 at 6:43 AM
    #77
    xtyfighterx
    Ty
    North Idaho
    Ya wasn’t expecting that at all lol but hey now I know. If the ball joint press would of worked for the driver side it wouldn’t of been to bad. Cutting out th shackles wasn’t to fun but the sawzall got it pretty good. Just glad it’s done and on the road again my father in law let me borrow his raptor to ride around in for the time being thankfully.
  18. Apr 30, 2019 at 7:09 AM
    #78
    AZTundra
    Paul
    Phoenix, AZ
    Any idea what a shop would charge to install the +2 shackles? Sounds like a pain and maybe this job is worth handing off.
  19. Apr 30, 2019 at 7:25 AM
    #79
    xtyfighterx
    Ty
    North Idaho
    I think you would be ok living in AZ the road salt and crap in winter is what ruined mine. But idk maybe a couple hundred. I’m sure it’s $100 an hour. With the right tools shackle and bushing install id say is a two hour job or so....just shackles I bet you can do them in an hour if yours come out easy without issue.
    AZTundra[QUOTED] likes this.
  20. Apr 30, 2019 at 7:46 AM
    #80
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    I got mine installed last week and the shop charged me 1.5 hours which came out $128. I got mine ripped of. Lol normally $85.
  21. Apr 30, 2019 at 9:44 AM
    #81
    BlackSheep
    Scott
    Kansas City, MO
    I had a shop simply press out the bushing on my driver side leaf pack, which i had removed myself and carried in to them myself. Then they pressed in the new bushing. I was charged half hour of labor, $47.50. I did all the rest of the work on the shackles and shocks myself. If I had to do it over again, knowing what I know now about how stuck in the leafs the factory bushings get running around on salt-treated roads, I'd have gladly paid $128 to have the whole thing done for me.
    equin and AZTundra like this.
  22. Apr 30, 2019 at 10:17 AM
    #82
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    I’m glad as well and true that. Since I am no mechanic. Lol
  23. Apr 30, 2019 at 1:02 PM
    #83
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Glad to hear you won the battle :) Nice job!!!
    Some of these trucks are so corroded its a job and a half getting OE parts removed, one of the many reasons we machine from billet and use finishes that are designed to last.
    *** Ball Joint Press Tool Tip ***
    When setting the ball joint press tool up on your leaf springs remember to oil the threaded rod, so many times we see this tool bone dry and dirty making the threads lock up under light torquing. if the threads are clean and lubricated you're able to easily torque down on it
    applying more pressure directly onto the OE rubber bushings. Also don't be afraid to cut your OE shackles in half or cut the bolts off ( sawzall or cut off wheel ) if the lower bolts are seized into place. you're replacing everything in there anyways.. its just not worth spending any extra time fighting them.
    Ronsofury, equin, 15whtrd and 2 others like this.
  24. Apr 30, 2019 at 2:24 PM
    #84
    MNBighead
    MNBighead New Member
    2015 CREWMAX TRD OFF ROAD
    I have +2's sitting on the workbench as we speak and have read every thread and watched all the videos. Ran across this story today and man, now I feel bad for the OP. I live in MN so I'm anticipating a battle-royal with the OEM bushings. Wish me luck. I'll report back on the process.....
    Coachbuilder1 likes this.
  25. Apr 30, 2019 at 2:28 PM
    #85
    BlackSheep
    Scott
    Kansas City, MO
    Yeah...we'll be your support group. Good luck! :thumbsup:
  26. Apr 30, 2019 at 2:31 PM
    #86
    Coachbuilder1
    David
    Salt Lake City UT
    If you have not already... spray the OE rubber bushings and all OE shackle hardware with penetrating oil and give it a few days of soaking. Oil the threads on your Ball joint press before using the tool and push those babies out! If you get stuck during your install remember you're always welcome to call, We've seen it all and have all kinds of back up plans if needed.. You got this!
    Pimpala1962, equin and 15whtrd like this.
  27. Apr 30, 2019 at 2:36 PM
    #87
    MNBighead
    Haha - ya I've been hitting them with PB blaster for 2 weeks. Def. will lube the press threads. I have air tools, torch etc. I'll report back and reach out for help if needed!
  28. Apr 30, 2019 at 2:51 PM
    #88
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    One of my bushings seized in the leaf spring and the bearing press wasn't working. I rented a gear puller, and with a little cursing I was able to push it out. PB blaster is your best friend here. Love the poly bushings.
  29. Apr 30, 2019 at 7:00 PM
    #89
    xtyfighterx
    Ty
    North Idaho
    Thanks coach I actually called and talked to you last Thursday....I cut the shackles off the truck with a sawzal then pressed out the passenger use some 30wieght oil on the threads like you suggested. The driver side wasn’t cooperating at all I have them both soaked in PB for about 6 days to. But hey it’s done and your bushings are now pressed in I didn’t need the carrier bearing drop tho I don’t have any vibes. Do you suggest doing it anyway?
    Coachbuilder1[QUOTED] likes this.
  30. Apr 30, 2019 at 7:00 PM
    #90
    xtyfighterx
    Ty
    North Idaho
    Did you get poly bushings to? Or gonna try and use stock?
