Help: Reset TPMS no workie
Discussion in 'Wheels & Tires' started by AK 6.7PSD Replacement, Feb 18, 2020.
  1. Feb 18, 2020 at 4:00 AM
    AK 6.7PSD Replacement [OP] New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    Just got LT tires installed and tried resetting my TPMS (no warning light, the pressures for each tire just display as “—“.
    The owners manual states to turn the ignition to “on” (not start) and hold the reset button until the tire warning light flashes 3 times and a “TPMS resetting” message appears. This didn’t work.
    I started the truck and then pushed the button for 3 flashes, got the message and then proceeded to drive until the pressures registered. Only they didn’t register after a 14 mile commute.
    Am I missing something? Current pressure is 45psi; doe they need to be at 33psi to register first and then I can air them up?
  2. Feb 18, 2020 at 4:03 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Mine took an hour of city driving one time before they registered haha.
  3. Feb 18, 2020 at 4:03 AM
    18" TRD Off Road Wheels
    It can be a bit wonky ( I just reset mine after changing pressures), but if you hold the reset until it flashes it will give the "---" for a while. I thought mine was screwed up, but the next day after sitting overnight it was reading properly. You do NOT have to have your pressure lower to make it work.
  4. Feb 18, 2020 at 4:09 AM
    Good to know; I’ll give it a day or two. Thanks!
