Help - Rear Pop Sound When Taking Off (Not the Clunk)
Discussion in '1st Gen Tundras (2000-2006)' started by Bulldog_tundra, Jun 4, 2020.
  1. Jun 4, 2020 at 5:56 AM
    Bulldog_tundra
    Bulldog_tundra [OP] New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    As the title says, this is not the normal clunk, thunk, bump from the rear.
    When I take off from a stop and accelerate quickly or am turning and take off quickly I hear and feel a quick pop from, what sounds like, behind the cab. I can really hear it when I lower the rear window.
    If I take off slowly from a stop or turn, it doesn’t pop and it never pops while I’m already driving - only when I accelerate quickly from a stop.
    Any ideas?
  2. Jun 4, 2020 at 11:11 AM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    Have you done any maintenance on your rear diff? If you haven't, it's really easy to do and may be the source of your noise.
    Check all the maintenance items like the carrier bearing and the joints on the drive shaft for wear.
    What mileage do you have on the truck?
  3. Jun 4, 2020 at 11:15 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
    Make sure your drive shaft is lubed up too!
  4. Jun 4, 2020 at 4:04 PM
    Bulldog_tundra
    USA
    2006 Double Cab
    Embarrassing as this is, need to research how to do this. It’s a 2WD and this is the one area I’ve never messed with.
    It’s a 2WD with 148K miles. I serviced the rear diff 2-3K miles ago and the fluid was actually pretty clean.
    I’m not real familiar with how much play is normal in the driveshaft, it moves if I push or pull on it real hard, but otherwise it feels pretty solid, it’s not “loose”.
    From what I’ve read there’s no zerks on the 2WD?
