Help! Pulling to the right when driving and braking
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra2010, Feb 14, 2015.
  1. Feb 14, 2015 at 5:38 PM
    Tundra2010
    Tundra2010 [OP] New Member
    2010 black tundra 4.7
    I just had my 2010 tundra leveled and put new tires and wheels on it. Now the problem is it pulls to the right while driving and also pulls right when applying the brakes. It did this before the new tires and level kit. I'm stumped please help!!!!!
  2. Feb 15, 2015 at 10:07 AM
    Mike Tread lightly.
    south carolina
    get a alignment done first.... while its on the rack have them check pads and rotors out make sure they are not out of spec..
  3. Feb 15, 2015 at 11:24 AM
    Strong this. Make sure you take it somewhere that knows what they are doing.
  4. Feb 15, 2015 at 12:36 PM
    tuna813
    tuna813 New Member
    Tuna!
    13' RCSB
    Sounds like my previous 14 tacoma after the $5k service and tire rotation. x3 on alignment check
  5. Feb 15, 2015 at 1:19 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I had that problem with my Tacoma, ended up being calipers, good to check maybe. I was told also to get a alignment after installing leveling kit.
  6. Feb 15, 2015 at 2:09 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Did you mean to say that it did not do this before new tires and level kit? If you really meant what you wrote, it might indicate a more serious problem than alignment.
  7. Feb 15, 2015 at 3:16 PM
    Tundra2010
    It did do it before the level and alignment, I'm kinda leaning towards a brake caliper
  8. Feb 15, 2015 at 4:00 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Brake pads, calipers or rotors for the pull when braking.
    Alignment when driving.
  9. Feb 15, 2015 at 4:34 PM
    Tundra2010
    Ok I have no problem buying new rotors pads and calipers if I need them, what's a good website to but them?
  10. Feb 15, 2015 at 5:35 PM
    Anywhere you prefer. It just depends on what brand you want and stopping power, I suppose.
  11. Feb 15, 2015 at 8:04 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I would imagine our front calipers are expensive. I'm no tech, but I would assume your driver's side caliper at least is fine. I would check to see if your passenger side front caliper piston(s) are seized up. If not, no sense in wasting the money. Without putting it on a lift to spin the wheel and inspect the caliper, after a few miles on the interstate check out your passenger side front rotor. If you can smell hot brake pads and it seems a lot hotter than the driver's side, that's an obvious clue.
    The alignment seems more likely. Did you already have that done?
  12. Feb 15, 2015 at 8:37 PM
    csuviper
    Broomfield, CO
    I agree with mototundra. Most likely not caliper with a 2010. Just take a look at the pads and rotor. If more worn on one side than the other then you may have a problem.
    If even wear but pads are worn down then replace pads and get rotors turned down.
    MotoTundra likes this.
  13. Feb 16, 2015 at 3:12 PM
    Tundra2010
    Ok great thanks guys I'll inspect everything this weekend hopefully it's nothing tooooooo major
