HELP! POWER STEERING FAILURE
Discussion in '2.5 Gen Tundras (2014-2021)' started by THORYOTA, Oct 27, 2021.
  1. Nov 26, 2021 at 5:25 AM
    FireArrow
    FireArrow New Member
    MD
    2021 MGM Crewmax
    I just got a recall notification, but it said there is no resolution.
  2. Nov 26, 2021 at 5:31 AM
    NWPirate
    Zach
    WA
  3. Dec 2, 2021 at 7:18 PM
    jgullace
    jgullace New Member
    Joshua
    2020 Tundra (Cavalry Blue)
    Just an update. After my first drop off with most of the reservoir being empty. Two Toyota mechanics stated they could find no leak anywhere under the truck it was "bone dry". So they topped off the power steering and sent me home. Blue berthas been sitting some with the holidays and losing my job, however about 3-4 weeks later While driving around I heard the same noises as before. Pulled over and was almost empty again. I took pictures again and sent them to the assistant manager and within 3 minutes had a reply saying bring it in. An hour later I get a call they've ordered a new rack and pinion as the seal was indeed broken in some way. Truck is to be finished tomorrow afternoon so we'll see how it goes. All warranty, however I have a 2020 but the service manager said it's not uncommon for the list of Vins and years to increase after a recall is first announced.
  4. Dec 2, 2021 at 7:21 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    How many miles on your truck? Any warning signs of this before it happened or was it sudden without any warning?
  5. Dec 3, 2021 at 12:08 AM
    jgullace
    jgullace New Member
    Joshua
    I'm currently sitting at 21,631 miles and this started a couple hundred miles ago. The only warning signs I had were some increased vibrations in the wheel the wheel getting a little heavier to turn, not returning to center as fast but the biggest sound was as if there was some amount of slippage or rustling or popping when turning the wheel and accelerating. These came over a period of roughly 5 days to a week and I thought could of been caused by some stuck plastic under front of the truck. Once I removed the plastic the noise stopped temporarily but returned a few days later. The tell tale sign was when I popped the hood and thought that's some clear power steering fluid in there. Until I realized there was very little.
    Bergy24[QUOTED] likes this.
  6. Dec 3, 2021 at 5:35 AM
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Dealer I stopped by yesterday to see a old friend had 10 new 2021 crew max on lot ,
    Asked what’s up with them there all on hold due to recall coming on the ps racks ,
    New dealer so there allocations are higher
  7. Dec 4, 2021 at 3:28 AM
    Retired...finally
    Maybe I should swing by the dealer and ask for a case or two of PS fluid N/C. Just in case mine starts this crap.
  8. Dec 4, 2021 at 5:29 AM
    2mchfun
    Keep filling and then it will probably just blow out the boot and make a huge mess. I wonder if temporarily they could install some in line pressure regulator coming out of the pump?
  9. Dec 4, 2021 at 5:43 AM
    Big Papi
    Big Papi New Member
    Massachusetts
    2021 Tundra TRD Pro Black
    So my 2021 built in October was held at the Port till early November for "Steering Column Parts". I wonder if they were waiting for bad parts or the replacement parts that the recall will take care of?
    I haven't been notified of a recall the App and Toyota recall website says I have none. Maybe they held it at the Port for better parts of the fix?
    Bergy24 likes this.
  10. Dec 24, 2021 at 8:36 AM
    Spreader
    Spreader New Member
    2021 Mag Gray TRD Crewmax
    My power steering quite working yesterday on me while backing out of a parking spot. Called the local dealership and gave them a heads up. They said there was a recall out with no identified fix currently. I limped it there for them to diagnose and this morning I got a phone call letting me know they got me a rental. Still no fix but at least I have a car to drive paid for by Toyota. We shall see how long this takes to identify a fix.
  11. Dec 24, 2021 at 9:21 AM
    Retired...finally
    How many miles were on your Tundra when it failed?
  12. Dec 24, 2021 at 9:46 AM
    Spreader
    Spreader New Member
  13. Dec 24, 2021 at 10:26 AM
    Retired...finally
    :facepalm: I have 6,000 on mine and hoping I'm in the 75% club.
    9DivDoc likes this.
  14. Dec 24, 2021 at 11:17 AM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    2021 TRD PRO CM MGM 2021 SKM CM Limited
    1800 for me and I no longer trust it enough to venture far from home...disappointed in Toyota's handling of this...but hey at least it's not a runaway throttle...
  15. Dec 24, 2021 at 11:25 AM
    Retired...finally
    I already ventured 1,000 miles from home for the winter before getting wind of this. Pulled travel trailer down here too.
    9DivDoc[QUOTED] likes this.
  16. Dec 24, 2021 at 11:32 AM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    Sounds like the source that cuts the groves has 4 machines doing the cutting and there was a bit failure on one of the machines causing this problem.
    You have a 1 in 4 chance of being just fine.
    I sincerely hope you are one of the lucky ones...hopefully you'll get in and inspected by the end of Feb and if needs be fixed up shortly after and then ready to head back north in spring?
  17. Dec 24, 2021 at 2:10 PM
    Retired...finally
    I'll be on the Gulf until April 1st so there's some time there. Someday there will be a case study of this fiasco showing how not to do inspections and QC. I'm shocked that 5,500 units could be produced before it was caught. Also betting if Toyota hadn't found the problem and reacted as they didthere would have been many more bad racks.
  18. Jan 1, 2022 at 6:34 PM
    Retired...finally
    So now we are finding out the OP had a 25% chance of getting another bad rack installed to replace the first bad rack.
    9DivDoc likes this.
  19. Jan 1, 2022 at 7:58 PM
    #49
    9DivDoc
    9DivDoc New Member
    Wisconsin
    Yeah talk about adding insult to injury eh?
    Sure hope he lucked out and got a good one.
  20. Jan 1, 2022 at 8:07 PM
    #50
    303Tundra
    303Tundra New Member
    Denver
    2021 Tundra Platinum
    Mine also has a 10/21 build date and I'm not seeing any recalls on it in the app/website either. Hoping that continues to be the case
  21. Jan 2, 2022 at 8:17 AM
    #51
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Patriot likes this.
  22. Jan 2, 2022 at 11:04 AM
    #52
    Retired...finally
    The talk about driving the cars with the PS inop anuses me for two reasons: First, there is a huge difference in effort required to control a vehicle designed with manual steering and one with a failed PS system. Second is how long will the PS pump last without lubrication? Lock that pulley up and all sorts of nasty things can happen. It's almost as if Toyota is blowing this thing off a little bit.
    9DivDoc likes this.
  23. Jan 2, 2022 at 1:42 PM
    #53
    9DivDoc
    9DivDoc New Member
    Wisconsin
    Yep...it's either dangerous to drive it and have it go out while you are or it's not...can't be both....
    They don't have a fix so I can't drive mine/won't drive mine...but still have to make payments on it...:rolleyes:
  24. Jan 5, 2022 at 10:59 PM
    #54
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Today I ran the vin on a 2021 TRD Pro Lunar Rock CM with low miles I was thinking about possibly purchasing from a Jeep/Ram dealer only to find two open recalls after running the VIN on the link below.
    Bummed to say the least as I liked the truck and but am going to totally pass on the purchase. I honestly just can’t make an offer on a truck with (2) recalls open.
    I hope anyone impacted by this gets their truck fixed quickly by Toyota.
    Power steering and headlight assembly recalls see link-
    https://www.kbb.com/toyota/tundra-crewmax/2021/recall/
    Spreader, 9DivDoc and ColoradoTJ like this.
  25. Jan 6, 2022 at 6:41 AM
    #55
    9DivDoc
    9DivDoc New Member
    Wisconsin
    Where was this gem found? if you don't mind my asking?
    Get the power steering looked at (ya got a 75% chance of that being a nothing burger) and the wiring changed out on Toyota's dime...and you got a TRD PRO Lunar Rock...a grail truck my man...a grail truck...:)
    Spreader likes this.
  26. Jan 6, 2022 at 8:26 AM
    #56
    Spreader
    Spreader New Member
    Anyone heard any updates from the dealer on timeframes? Im going on week 3 as I sit and wait for my truck to be fixed. Very frustrating to say the least.
  27. Jan 6, 2022 at 8:46 AM
    #57
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    I think mine shit the bed within 800 miles of delivery. 2020 Pro. I can double check the RO, might have been 1200 miles but needed a new pump
  28. Jan 6, 2022 at 8:58 AM
    #58
    tdm850
    tdm850 New Member
    2021 Toyota Tundra
    Isn't this the recall. They said they are going to start sending them out in January
  29. Jan 6, 2022 at 9:57 AM
    #59
    Spreader
    Spreader New Member
    Yep. No parts to fix it currently and if you previously had it repaired even the new pump you got might be faulty as well. That’s what I’m hearing.
    Mike59 likes this.
  30. Jan 6, 2022 at 10:00 AM
    #60
    Retired...finally
    I understand one of the tierod boots is catching the majority of the fluid when the seal blows. Can anyone say if it's the drivers or pax side? Or is there evidence either side can fail?
