Help on Rear Bumper
Discussion in '2nd Gen Tundras (2007-2013)' started by jgatorswin, Apr 8, 2020.
  1. Apr 8, 2020 at 7:28 AM
    jgatorswin
    jgatorswin [OP] New Member
    2010 Toyota Tundra SR5 Crewmax
    3" lift with 35x12 on 18"s
    I just bought a DV8 rear bumper for my 2010 SR5 Crewmax. It didn't come with any instructions and it seems nothing lines up. I called DV8 and they don't have instructions and are truly ZERO help. Anyone have experience with this and if so, I'd appreciate any tips or advice. TIA
  2. Apr 8, 2020 at 7:52 AM
    Is it a 1 piece bumper? I didnt know they even made a rear. I know they have a 3 piece front bumper.
  3. Apr 8, 2020 at 8:05 AM
    ckkone
    ckkone New Member
    SLC, UT
    I would imagine its bolts in place where the factory bumper was mounted, probably not much more to it than that. Pictures would help.
  4. Apr 8, 2020 at 8:06 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    You have to remove 2 or 3 of the bolts that hold the hitch receiver to the frame. The round hole on the bracket fits around the stub and weld from the round tube of the receiver tubing. The other end bolts to the bumper, two per side.
    I removed my hitch receiver frame completely and had it sandblasted and powder coated, but there are somewhere like 12 bolts holding that thing onto the frame.
    jgatorswin[OP] likes this.
  5. Apr 8, 2020 at 8:40 AM
    jgatorswin
    Thank you tnbndr! You helped more than DV8!
    I've attached pics in the zip file.
    oogabooga289 likes this.
  6. Apr 8, 2020 at 12:03 PM
    jgatorswin
    Got it done! I appreciate all the help!
    rons23 and tnbndr like this.
  7. Apr 15, 2020 at 9:49 PM
    MCL1
    MCL1 New Member
    Having the same issue, but with 3rd Gen. So with dv8, you have to lose the hitch receiver, right?
  8. Apr 16, 2020 at 3:50 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    No, receiver stays, the brackets go on the outside of the receiver mount. Remove the bolts through the receiver mount that are right near the cross pipe that the receiver is welded to. The hole in the bumper bracket fits over the end of that cross pipe and weld and the bolts go back in to hold it to the frame. Bumper gets mounted to the part sticking out.
  9. Apr 16, 2020 at 4:32 AM
    Post pics. How much does that bumper weigh? Did you do the front too?
  10. Apr 16, 2020 at 7:39 AM
    jgatorswin
    I swapped out the front and back bumpers. The instructions on each are terrible though. The final result, pretty cool.
  11. Apr 16, 2020 at 8:06 AM
    oogabooga289
    oogabooga289 New Member
    Did you cover up the auxiliary reverse lights on the rear bumper?
  12. Apr 16, 2020 at 8:21 AM
    Nice. Have you noticed the added weight when driving?
  13. Apr 16, 2020 at 8:45 AM
    MCL1
    MCL1 New Member
    That’s the thing. The damn brackets for the bumper are the exact same size as the bracket for the hitch receiver. There’s no way to fit it over. Also, realizing that I’ll lose my bsm system when I install this.
  14. Apr 16, 2020 at 2:14 PM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    0621191746_LI.jpg that is different then the mounts on mine must be a new version... did they not send the mounting plates to go around the hitch welded tube?
  15. Sep 27, 2021 at 4:34 PM
    Ob1
    Ob1 New Member
    Looking into this bumper. Looks beefy as heck. In any case, were you able to mount it? Quality? How do like it? Pictures?
    I know lots of questions, just worried that it might be a piece of junk like the last two I ordered.
  16. Sep 30, 2021 at 5:51 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Just a heads up I duno if DV8 makes there Jeep products, but there Tundra products are all no name eBay Chinese junk thats marked up %50 with there name riveted to it. Was disappointed after figuring that out when I bought my front bumper.
    Ob1 likes this.
