Help needed diagnosing audio issue
Discussion in 'Audio & Video' started by ForceV4, Jul 20, 2020.
  1. Jul 29, 2020 at 10:06 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    We were enroute to solving the problem. With the LC6 ruled out, the amp was the only component left. Glad you got it resolved... and got to learn a few things!
    ForceV4[QUOTED][OP] likes this.
  2. Jun 30, 2021 at 9:50 AM
    lsumatt1514
    lsumatt1514 New Member
    2008 Tundra Crewmax Limited
    Where was the wiring issue? I’m having a similar issue in my truck, where the left channel audio randomly fades in and out. This started out of nowhere about a week ago and it’s driving me nuts. I have a Kenwood DMX906S in my truck and the stock JBL amp and system. Thx!
  3. Jun 30, 2021 at 10:59 AM
    ForceV4
    ForceV4 [OP] Pull my finger
    Sacramento
    2018 DC TRD 4x4
    It was all in the aftermarket Rockford Fosgate 4 channel amp. I replaced it with a mid level JL Audio amp and haven't had a hiccup since. Oh, I almost forgot that 1 of the RCA cables had some issues, too.
    A huge thumbs up to TundraTex for helping me out. I was way over my head trying to diagnose the issue.
    MTRock likes this.
  4. Jun 30, 2021 at 11:11 AM
    lsumatt1514
    Thank you. I'm going to start by pulling everything out and checking the wiring harness connections behind the Kenwood. This is SOOO aggravating!
  5. Jun 30, 2021 at 11:24 AM
    ForceV4
    Sacramento
    2018 DC TRD 4x4
    Best of luck to you. Don't forget to curse repeatedly. That's often my first step in diagnostics.
  6. Jun 30, 2021 at 11:29 AM
    lsumatt1514
    Yeah, I'm not looking forward to this. Seems like more than a loose wire, but we'll see.
  7. Jun 30, 2021 at 11:45 AM
    ForceV4
    Sacramento
    2018 DC TRD 4x4
    Well, if you get stuck, just ask on the forum. As I'm sure you've noticed, there are some sharp people here. I've also found that there are always people willing to help out. Tundras.com has a lot of good people.
    RdKing and lsumatt1514 like this.
  8. Jun 30, 2021 at 12:32 PM
    AZBoatHauler
    So.Arizona
    My bet is on the JBL amp causing fits. Can you swap the R and L inputs going to the amp and see in the problem switches sides? If the cutting out moves it would suggest a HU signal issue and if not it suggests your amp is faulty.
    I’m running the same HU and have experienced a handful of quirks but thankfully nothing this significant.
  9. Jun 30, 2021 at 12:39 PM
    lsumatt1514
    I'm not even sure where the stock JBL amp is mounted...is it under the driver's seat?
  10. Jun 30, 2021 at 1:10 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Why did you windshield crack after you washed it?
  11. Jun 30, 2021 at 1:27 PM
    lsumatt1514
    I don't have an aftermarket JBL amp...it's the stock JBL amp that came with the truck. Don't believe I can swap leads because everything is in a couple wiring harnesses connected to the amp.
  12. Jun 30, 2021 at 2:24 PM
    AZBoatHauler
    So.Arizona
    I’m guessing you didn’t do the install? Do you know in the signal to the amp is coming from the high level speaker wire outputs from the HU harness or the low voltage RCA outputs on the back of the HU?
  13. Jun 30, 2021 at 5:59 PM
    lsumatt1514
    I did do the install of the Kenwood head unit. The Kenwood is tied into the truck using an iDataLink Maestro harness/module. I don't have anything else aftermarket...the rest of they system is the stock JBL system that came with the truck, including the amp and speakers. I am not utilizing the RCA outs of the Kenwood...all of that is speaker level through the stock JBL amp.
  14. Jul 1, 2021 at 12:00 AM
    AZBoatHauler
    So.Arizona
    Gotcha. I’ve read the fade and balance on the JBL system is controlled by the amp not the OEM HU so it sounds like something weird could be going on with the amp.
    like most audio threads, the real answer is to call/email James at Tech12volts and he will tell you how to straighten out your Tundra audio.
  15. Jul 1, 2021 at 6:09 AM
    lsumatt1514
    How do I contact James? When I try to submit my contact information and question on their Contact Us form, I get a "Forbidden" message. Thanks!
  16. Jul 1, 2021 at 6:11 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Calling is your best bet. Or email. Contact info should be on his Web page.
  17. Jul 1, 2021 at 6:19 AM
    lsumatt1514
    I can't find an email address or phone number on their site...only the Contact Us form which give me a Forbidden message when I submit...
  18. Jul 1, 2021 at 8:00 AM
    AZBoatHauler
    So.Arizona
  19. Jul 1, 2021 at 9:49 AM
    #49
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  20. Jul 1, 2021 at 10:55 AM
    #50
    lsumatt1514
    Thanks guys...hoping its not the OEM JBL amp. A used one is $300 and a new one from TRD Sparks is over $1,000...
  21. Jul 1, 2021 at 12:05 PM
    #51
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    I just took one out of my 2008. Not going back in.
    AZBoatHauler likes this.
  22. Jul 10, 2021 at 6:20 PM
    #52
    lsumatt1514
    I just swapped out the amp with another stock JBL amp (Thanks 81 TOY!) and the problem persists...the left channel audio intermittently cuts in and out. It's not a connection issue at the amp, because there are only three connections there and they are wiring harness connections that lock in place. I will try to pull the Kenwood out tomorrow and see if it is a loose connection behind the head unit, but the intermittent left channel audio cutout happened tonight while the truck was parked in the driveway...so it's not like anything was getting jarred or anything while driving. Anyone else have other ideas of where to check? Thanks!
    81 TOY likes this.
  23. Jul 12, 2021 at 10:45 AM
    #53
    lsumatt1514
    Update...I pulled the Kenwood out yesterday and for lack of a better term, reorganized the wiring behind the head unit. So far so good and I haven't heard the left side cut out again. Not sure if something was grouding out, but hopefully it is solved.
  24. Sep 24, 2021 at 3:12 PM
    #54
    lsumatt1514
    Latest update…had all the connections redone including solder and this is still happening. I’ve even tried two different stock JBL amps. Now the sounds cuts out of the left side sometimes and sometimes on the right. You can hear it come and go. I’m at a loss…any ideas what is causing this?
