Help! Multiple dash lights blinking...ABS 4Hi 4Lo, etc
Discussion in '2.5 Gen Tundras (2014-2021)' started by Roundheadkid, Jul 21, 2022.
  1. Jul 21, 2022 at 10:45 AM
    Roundheadkid
    Roundheadkid [OP] New Member
    Driving the other day and my dash lit up with multiple lights flashing.
    ABS, 4 hi 4 lo, traction control, etc.
    Anyone have any ideas?
    2015 crewmax 4x4 with 75k kms
    Thanks
  2. Jul 21, 2022 at 11:30 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Jul 21, 2022 at 2:22 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Check battery....low voltage?
    1UP likes this.
  4. Jul 21, 2022 at 4:42 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I've seen others with this problem say it was a wheel speed sensor, you can pretty easily see if one is broken or frayed.
  5. Jul 22, 2022 at 6:00 AM
    Roundheadkid
    Thanks!
    So...reading through those threads people replaced the 4wd actuator...axles...wheel bearings...abs sensor...not really sure where to start.
    I'm going to crawl under the truck after work today and look for obvious wires cracked, etc
  6. Jul 22, 2022 at 6:01 AM
    Roundheadkid
    I'll check the voltage and see what it's at.
    Assuming I'll take the reading with the truck off?
  7. Jul 22, 2022 at 7:00 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    My truck did that once while drive home from San Diego. I pulled over to the side of the road and shut the truck off for 5-10 minutes. Restarted and has never happened again. I have heard everything from battery, TSS sensor, ABS and/or just a quirk. :notsure:
  8. Jul 22, 2022 at 7:10 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Mine did that once under warranty. Shut
    Same here did it once, has never happened again and I've put many miles on..
  9. Jul 22, 2022 at 8:20 AM
    frichco228
    Check your battery first. If original it probably done, they usually only last 3-4 years. Battery going bad will cause faults to different systems, as the systems are not getting enough power/volts to perform.
    If that checks out ok or you replace it and still have the errors, then look at your ABS sensors and associated wiring.
  10. Jul 22, 2022 at 8:36 AM
    Trikerider
    Trikerider New Member
    2015 Limited CM
    Had the same issue and ended up being wheel speed sensor, took a scan tool to determine which one. The sensor had the smallest crack in it but enough to allow moisture into the copper core and corrode and lose the connection. Kind of crappy that Toyota wont let you put the vehicle in 4x4 even when in Park with that sensor failure as mine happened during winter.
    Joe333x likes this.
  11. Jul 22, 2022 at 4:08 PM
    Roundheadkid
    Battery is reading 12.36V with the truck turned off
  12. Jul 22, 2022 at 4:32 PM
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Same issue here took to dealer they cleared it and came back the next day on. They couldn’t figure it out.
  13. Jul 22, 2022 at 7:22 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    That is 70% charged....100% is 12.6. Have them check the battery at AutoZone, etc...
  14. Jul 22, 2022 at 8:17 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Agree with this. Need to have the battery load tested at a parts store.
  15. Jul 24, 2022 at 7:56 AM
    Roundheadkid
    I'm in Canada...don't have AutoZone and I'm not aware of anywhere that will test a battery.
  16. Jul 24, 2022 at 8:08 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
  17. Jul 24, 2022 at 8:40 AM
    Roundheadkid
    I crawled under the truck and found the rear right wheel speed sensor was cracked off.
    I replaced it...cleared the codes...and all the dash lights just keep coming back on.
    I cleared the codes a few time...the scanner picked up: ABS, 4WD and Trailer brake codes
  18. Jul 26, 2022 at 10:09 AM
    Roundheadkid
    What's my next option? Replace the battery?
  19. Jul 26, 2022 at 3:44 PM
    NickB_01TRD
    Nick
    KY
    Did you do a battery disconnect for a little while after replacing the sensor?
  20. Jul 26, 2022 at 3:59 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    I do not recommend just replacing stuff willy nilly but prefer to have some diagnostic testing indicating the issue. That's why I recommended you have the battery tested. If yours is more than 3 years old and you are getting voltage readings of less than 12.6v after a lengthy drive, it's probably not a bad idea to replace it but not sure that will fix your issue.
    Rocko9999 likes this.
  21. Jul 26, 2022 at 4:10 PM
    Roundheadkid
    I have the negative off the battery right now...I'm going to leave it until morning and then take it for a drive and see if the codes come back.
  22. Jul 26, 2022 at 4:28 PM
    Redpill
    Redpill New Member
    2015 Tundra DC Limited 4x4
    Leveling kit, airbags on rear axle, led light bar with cattle pusher.
    I just had that problem, and it turned out to be the passenger side wheel bearing going bad. Enough debris from the bearing caused the speed sensor to throw a code. I cleaned off the speed sensor and cleared the codes and it worked for about a week and did it again. Replaced the wheel bearing and have had no issues since. Its been about two months.
  23. Jul 26, 2022 at 4:59 PM
    Roundheadkid
    Thanks...good to hear you got it resolved
  24. Jul 27, 2022 at 12:23 PM
    Roundheadkid
    Left the truck until after 5pm...just put the negative terminal back on and took it for a quick drive.
    All the same lights are back on the dash.
  25. Jul 27, 2022 at 12:25 PM
    frichco228
    Have you had the battery load tested yet?
  26. Jul 27, 2022 at 12:46 PM
    Roundheadkid
    Not yet...still trying to find somewhere that will do it. We don't have Autozone here.
  27. Jul 27, 2022 at 1:08 PM
    frichco228
    2015 truck, if your battery is original you should replace it, long past due. If not, still is probably due since batteries last about 4/5 years if lucky. Would mean it has been replaced once and it getting close or time to replace again, especially if you live in an area with hold or cold extremes.
  28. Jul 27, 2022 at 1:37 PM
    Roundheadkid
    Yes...I think I'm just going to grab a battery at Costco tomorrow
  29. Jul 28, 2022 at 3:37 PM
    Roundheadkid
    Picked up a new battery today and had it on the charger all day. Just put it in the truck...no lights on first start...but once I drove a few km's they all came back on.
  30. Aug 10, 2022 at 8:40 AM
    Roundheadkid
    Took the truck to a small local garage yesterday.
    They replaced the rear right wheel bearing. No more codes on the dash!
