Help me with steering.
Discussion in '2nd Gen Tundras (2007-2013)' started by matt@texas, Nov 16, 2015.
  1. Nov 16, 2015 at 7:48 PM
    matt@texas
    matt@texas [OP] New Member
    2012 tundra
    ome 3 inch
    This evening I completed my ome 3 inch lift. Put heavy duty coils on along with heavy duty upper control arms. I intend on putting a full replacement on front and rear. But haven't yet. Truck steers horrible can it be fixed with alignment or do I need more weight to correct problem?
  2. Nov 16, 2015 at 7:53 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Alignment will correct the steering. You changed the configuration of the front suspension enough to throw it off.
    Heavy duty coils will just make for a little rougher ride without extra weight like offroad bumper
  3. Nov 16, 2015 at 7:58 PM
    matt@texas
    2012 tundra
    ome 3 inch
    Ok so Im buying tires. Get it aligned then and when I put bumper on align it again? Also which tires on factory wheels 33 or 25? Thx for your help
  4. Nov 16, 2015 at 7:58 PM
    matt@texas
    2012 tundra
    ome 3 inch
    35 not 25
  5. Nov 16, 2015 at 8:02 PM
    csuviper
    Broomfield, CO
    With 3" lift you should go 35s. You will have to trim some plastic on the front wheel well and remove the front mud flaps. No big deal.
    After a bumper with a decent weight you should get it aligned to ensure tires wont get worn uneven but it shouldn't cause the steering issues you have right now by going up 3"
  6. Nov 16, 2015 at 8:17 PM
    matt@texas
    2012 tundra
    ome 3 inch
    Ok thx a lot. You have been a big help. I should sleep better knowing I didnt mess up by changing what wasn't broken.
