HELP ME WITH MY CLUNK CLUNK
Discussion in '1st Gen Tundras (2000-2006)' started by 04 Tundra, Oct 23, 2020.
  1. Oct 23, 2020 at 4:56 PM
    04 Tundra
    04 Tundra [OP] New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Well here we go..... So i bought the truck 2 years ago now with a very minor clunk when heavy off-roading. Now its gotten so bad the if i turn i get a deep CLunk CluNk.
    I just re did my inner and outer tie rods
    Ball joints are great no movement
    Re did Rack and Pining bushings
    Leaf springs are tight
    C V joint has normal minor movement
    Took of spare wheel and try and re create popping in the bracket (some ppl had this issue)
    I can not re create the sound with shaking the truck or bouncing on it up and down. I only get the pop when the weight of the truck shifts from one side to another. I honestly feel like something is shifting like 2 inches one way then back. Never happens when accelerating and stopping straight.
    If i drive in a circle nothing. the sounds is always from a shift in weight like driving up onto my driveway in a turn.
    Nothing seems lose swaybar plus links.
    Its so annoying... anything else i can try ? Ill gopro it tomorrow and post
  2. Oct 23, 2020 at 5:11 PM
    Professional Hand Model
    Hand Protectors
    Try spraying/soaking your leaf springs with PB Penetrant and then see if you can recreate the sound or if it goes away. I’m on my original rear leafs and had this problem you’ve described going up driveway aprons at slow speeds 90° turns.
    I’ve discovered that the leaf tip silencer pads have worn and fallen off thus allowing the clunking of the tips. Was worse in extreme cold weather. Sprayed the leafs and the noise went away.
    Did a jack leg fix with some composite shims from big box wedged into the tip ends with success. Need new leafs eventually.
  3. Oct 23, 2020 at 5:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Body mounts? Motor mounts?
  4. Oct 23, 2020 at 5:22 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Sounds like End links or the sway bar, doesn't hurt to check the steering rack... I had clunks in my car, apples to oranges, but usually when I turned or hit bumps at slow speeds, turned out the end links were slightly loose.
    mtntop likes this.
  5. Oct 23, 2020 at 5:55 PM
    04 Tundra
    Albert
  6. Oct 23, 2020 at 5:57 PM
    04 Tundra
    Albert
    Very interesting i will try this tomorrow ! I believe i have rubber missing in the leaf springs
    theblurry1 likes this.
  7. Oct 23, 2020 at 5:58 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Had a similar clunking issue in my CRV. Like @blackdemon_tt stated, it ended up being the sway bar links going bad. Replaced those and no more noise.
    Best of luck figuring it out. I have yet to find the source for an annoying ass squeak which I assume is the leaf springs
    blackdemon_tt likes this.
  8. Oct 23, 2020 at 6:10 PM
    04 Tundra
    Albert
    I have brand new sway bar links and they are tight thanks though
  9. Oct 23, 2020 at 6:16 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Transmission mount crossmember. Make sure you haven't lost any of the bolts.
  10. Oct 23, 2020 at 6:44 PM
    04 Tundra
    Albert
    just checked all there
  11. Oct 23, 2020 at 6:45 PM
    blackdemon_tt
    You should probably put the front on jack stands and start jiggling stuff... It'll make it easier in the long run...
  12. Oct 23, 2020 at 6:49 PM
    04 Tundra
    Albert
    I already did that everything is quite and smooth nothing is lose on the front end that i can tell. Wifes arms got tired from turning the wheel side to side. only time i can re create the sound is with movement in a turn or a bump.
  13. Oct 23, 2020 at 6:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    typically when you get a clunk with only one side of the suspension hitting something first, its related to the sway bar. I know it may be a pain, but unbolt the end links and take it for a ride and see if the noise is gone. past this you may have an issue with a strut.. but i doubt it if it doesnt do it on a straight on hard bump
    mtntop likes this.
  14. Oct 23, 2020 at 6:55 PM
    blackdemon_tt
    Double check the end links... the Impact can't get them tightened all the way... some have a hex center where you need to tighten it by hand, or it has a nut on the back end of the link where it needs to be held while tightening up the end link... You wont be able to replicate it by hand, you're right there, but it will come up on bumps and turns and its annoying AF..
    Dannydirtyfingers likes this.
  15. Oct 23, 2020 at 7:00 PM
    04 Tundra
    Albert
    my sway bar end links are about 2 months old ill take them off tomorrow but i don't think that's the issue. Also i forgot to mention before it got this bad it would normal be a lot louder and noticeable when n it was raining outside and the bottom of the truck got wet
  16. Oct 23, 2020 at 7:02 PM
    empty_lord
    05 rollover special
    my brand new end links started clunking exactly how you describe when they were 2 weeks old. warrantied them and it was gone. It does happen, before chasing a ghost, its the easiest to rule them out by removing them
    04 Tundra[QUOTED][OP] likes this.
  17. Oct 23, 2020 at 7:04 PM
    artsr2002
    'Yonder
    What about the sway bar bushings that told the sway bar to the frame?
  18. Oct 23, 2020 at 7:05 PM
    empty_lord
    05 rollover special
    they can cause a bit of noise. by they'll usually rattle around more than clunk when worn. and the bushings are obvious when worn out
  19. Oct 23, 2020 at 7:06 PM
    artsr2002
    'Yonder
    True true.
  20. Oct 23, 2020 at 7:13 PM
    04 Tundra
    Albert
    yeah this is a very loud clunk clunk and no is metal shifting and re setting but strut mounts are new and so are Bilstein's and coils. i payed to close attention to these deff not it
  21. Oct 23, 2020 at 7:14 PM
    blackdemon_tt
    Did you swap the pillow mounts to the new struts?? May be that as well, not sure how old they are..
  22. Oct 23, 2020 at 7:20 PM
    04 Tundra
    Albert
    got new ones
    blackdemon_tt[QUOTED] likes this.
  23. Oct 23, 2020 at 7:23 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That would be my thought as well. Something in the struts or a strut bushing.
    How often are there problems with control arm bushings on the Tundra? I know the LS430 Upper control arm bushings are pretty stout, but the lowers will make Clunking noise when worn.
  24. Oct 23, 2020 at 7:27 PM
    blackdemon_tt
    typical Toyota.. Uppers are usually pretty good, my SC4 has issues with the bottom ones too...
  25. Oct 23, 2020 at 7:34 PM
    empty_lord
    05 rollover special
    hmm lower ball joints can cause a clunk and not have noticable play.. something to consider if pulling the links off doesnt fix it.
  26. Oct 23, 2020 at 7:51 PM
    04 Tundra
    Albert
    usually you can some play up and down with a crowbar lifting up on the tier.
  27. Oct 24, 2020 at 4:54 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    Skid plates can flex and clunk too. How much armor do you have? Worth verifying, but I'd be on the trail of the weight bearing point suspects.
  28. Oct 24, 2020 at 6:00 AM
    Hand Protectors
    In particular, my clunk was going on for quite a few years. I had the front end rebuilt and it still happened. Put on a new sway bar and it still happened. Straightened up the splayed rear leafs and put on new leaf keepers it still happened.
    Researched these ‘silencer pads’ and discovered mine non-existant. Rode in the bed while recreating the clunk on turns and identified the sound was at the rear wheels. Only the inside wheel on the turn would sound off.
    Only happens on slow turns going up an incline. Mine still occasionally does it with the jack leg leaf shims. Not as ‘clunky’ either.
    The PB Spray helped me identify the problem by making it go away. Rear end felt slippery afterwards!
    Dannydirtyfingers and theblurry1 like this.
  29. Oct 24, 2020 at 7:03 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    Wooden shims?
  30. Oct 24, 2020 at 7:08 AM
    coTony
    Tony
    Montrose, CO
    Do you have the stock leaf springs? What sway bar do you have?
