Help me find a good 4runner 3rd or 4th gen in California please
Discussion in 'California' started by Rica25, Mar 5, 2020.
  1. Mar 5, 2020 at 9:11 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    I'm looking at getting a toy 4runner 3rd or 4th gen in California let me know if you guys see one for sale that is good shape. I would prefer it to be stock or very little mods please and thank you
    Inquiringone likes this.
  2. Mar 5, 2020 at 9:15 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    CarGurus, is a good start. you can plug in all the info you want, press done, the site does the work you. If you haven’t tried it.
  3. Mar 5, 2020 at 11:45 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    What's your budget?
    Rica25[OP] and porkitt like this.
  4. Mar 6, 2020 at 5:51 AM
    Rica25
    Ricardo
    Tulare
    Under 10k
    porkitt and BestGen[QUOTED] like this.
  5. Mar 6, 2020 at 6:25 AM
    Rica25
    Ricardo
    Tulare
    For those of you that have had 4 runners which generation is better as far as engine wise with less issues from the 3rd Gen. And the 4th Gen.
  6. Mar 6, 2020 at 6:26 AM
    Rica25
    Ricardo
    Tulare
    Also as far as off roading what is the bigger difference between both of them if any
  7. Mar 6, 2020 at 6:36 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Both made in Japan.
    3rds use the 3.4 vs 4ths use a 4.0.
    4ths upgraded the 4.0 w/VVti in '05, good for an extra 40 ponies/#s of torque.
    4ths also had an optional 4.7v8.
    Both highly reliable, some claim the 4.7 4th gen is the most reliable of all, yet I also read many, many folks with the air injection problems on these 4.7s.
    As far as off-roading, 3rds gens had an optional electric rear locker thru 2000. I'm not 100% certain, so someone chime in, but I believe 4th gens only have the center diff as lockable from factory. Starting in 2001 3rd gens began using a center diff lock and did away with the rear locker, that feature I believe continued thru the 4th gens life span. May never need a locker, so otherwise both are very capable off-roaders right out of the box.
    Limiteds have the most features, safety and personal touches.
    More info: https://en.wikipedia.org/wiki/Toyota_4Runner
    Here is The Supreme 4Runner site for all the info you'll ever need on one: Luck and let us know what comes up!
    Rica25[OP] likes this.
  8. Mar 6, 2020 at 6:45 AM
    Grumpy Uncle
    Pat
    CO
    Sorry no experience with the 4th gen. We have had 1-2nd gen, 2-3rd gens and our current 5th gen. The 3.4 is a very good engine though it could use some more oomph. One of the things to watch out for is the dreaded pink milkshake. If I remember correctly it was caused by a corroded cooling line. I never had this happen.
    Our 99 and 97 had rear lockers both had 4.30 gears. The tailgate sometimes will not open and you will need to take apart the rear door to work on it.
    The heater core up under the dash has been known to leak, again never had this happen to us.
    If I can remember anything else, I will post as I remember.
    I ran 32" and 33" tires the 4.30's were good to go. If you go bigger or heavier re-gear it.
    If it has a locker it will have 4.30's on the limited's and some SR5's. Some limited's also had a center locking diff with the all wheel drive option our 97 had both center and rear diff lockers.
    No locker they are running 4.10's.
    Rica25[QUOTED][OP] likes this.
  9. Mar 6, 2020 at 6:50 AM
    Grumpy Uncle
    Pat
    CO
    My 99 loved blowing rear maker and break lights. It ended up being a grounding issue. Once I replaced the ground cable with a bigger gauge wire it was happy.
  10. Mar 6, 2020 at 8:50 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    I have one under 10k. I’ll show you the 4Runner when I get back on the 20th :cheers:
    BestGen, Rica25[QUOTED][OP] and Pinay like this.
  11. Mar 6, 2020 at 10:06 AM
    Rica25
    Ricardo
    Tulare
    Yes sir no problem I just want to have a few to look at if I can find them near by. Just trying to get as much info as possible before making purchase.
    BestGen and porkitt[QUOTED] like this.
