Help!! Lift and wheels.
Discussion in 'Suspension' started by Ubc2361, Dec 27, 2015.
  1. Jan 12, 2016 at 12:31 PM
    Ubc2361
    Ubc2361 [OP] New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    All done guys thanks for the help.
    5100 bilstein in front
    285 75 18 toyo rt tires
    18" xd rims 25 mm offset
  2. Jan 13, 2016 at 6:18 AM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    Wow turned out nice! I like the rims, smart move on the 5100's!
  3. Jan 15, 2016 at 12:53 PM
    double_b
    double_b New Member
    2015 Tundra TRD Off Road CM
    Looks good man! Nice stance and perfect tire size selection. You won't regret spending more for the 5100s. Smart move to get them instead of your first choice.
    Ubc2361[OP] likes this.
  4. Feb 15, 2016 at 11:02 AM
    ramalama65
    ramalama65 New Member
    rich
    2016 tundra trd pro
    hi Jaylee,, I need some help.. I have the exact same truck as you. 2016 trd pro and want the same look. I ordered 35's to go on 20 inch rims with a 2 1/2 leveling kit installed. The installer calls me today and says he's having a hard time finding a kit for my truck. Tells me it might not be able to be lifted since its a pro. Its been in the business along time and doesn't bullshit. Very honest guy. He sounded surprised himself. Does this sound right. Is yours a pro? if so, what lift did you go with to make it all work out. Your look is exactly what I want mine to look like. Yours looks awesome... thanks for the help.
  5. Feb 15, 2016 at 2:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Check with Toytec (toyteclifts.com). They should have something that works for the pro. I really dont think the suspension setup is any different that the no Pro's except for the expensive reservoir front coilovers and rear shocks.
  6. Feb 15, 2016 at 6:41 PM
    csuviper
    Broomfield, CO
    Confirmed, the Pro Bilsteins are bolt on just like other stock suspension, they have springs that give 1 1/2" lift. You can swap to any 2.5" or 3" lift.
  7. Aug 10, 2016 at 11:42 PM
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    Was about to order Rough Country level kit (just a front spacer) until I chanced upon this thread. Here's the link:
    http://www.roughcountry.com/toyota-leveling-lift-kit-871.html
    It's $99 for a 2.5" and seems a good setup for a basic level. Numerous posters in this thread recommended away from it - may I ask why? And did the OP install them and then remove them for the 5100s? Was it a bad ride?
    As to the 5100s, will they stiffen the ride if pushed to their max setting for the 2.5" lift? I tow an 8k lb trailer with an '08 and 91k miles and am looking to do a level lift and replace the shocks (age-based) plus new tires. I'm avoiding a coil over based on cost.
    Thanks for any suggestions.
  8. Aug 11, 2016 at 2:08 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I have the RC spacer kit on my truck (3 months now) and from experience, the ride pretty much sucks, it's much easier to bottom out your shocks plus you're more at risk for busting, bending, and all around destroying your shocks, not just from the geometry being off, but your OEM shocks aren't designed for that mod.
    I don't have experience with bilsteins, but from what others have told me and riding in a couple of trucks geared with them, I would say you shouldnt have any worries about it being too stiff and does fine with towing. I would look more into the 6112 (if I'm not mistaken) if you're dead set on bilsteins with the weight you're towing.
    Look in the suspension and towing threads in this forum. Those will be a big help.
    In a few months I'm upgrading to the Toytec BOSS suspension. I would absolutely recommend you go the bilsteins, BOSS, OME, etc route in place of a spacer lift. Your truck, ride and passengers will thank you. Trust me.
  9. Aug 11, 2016 at 2:20 PM
    dragon_coma
    Sky
    @Law323 thanks! Nothing like first-hand experience to help a community out. I'll do the 5100s on all 4 for now, which should get me level if I skip a rear block. I'll try to remember I promised @csuviper some stock suspension measurements before I install them :facepalm:
    Law323 likes this.
  10. Aug 11, 2016 at 2:24 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Blocks.....I would consider coachbuilder shackles first. All around better security and peace of mind.
    No problem Sky! Let us know how it goes and post some pics of the end result! :burnrubber:
  11. Aug 11, 2016 at 7:41 PM
    csuviper
    Broomfield, CO
    Yes you do
    Law323 likes this.
  12. Aug 11, 2016 at 7:48 PM
    Check out ToyTec Shackles first IMHO. Solid welded steel, not assembled. (a weakness).
    Law323 and csuviper like this.
  13. Aug 12, 2016 at 4:46 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Huh, didn't know that. Definitely going to look into that when I upgrade!
  14. Sep 28, 2018 at 8:19 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    What was your run width and offset? Any lift? Is a second gen figment same as the 3rd?
  15. Sep 28, 2018 at 8:47 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This is an old thread. He no longer has his truck.
  16. Sep 28, 2018 at 9:11 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Yeah figured... but just not finding much info on 13+ wide tires. Oh well...
