Help identifying noise from intake manifold
Discussion in '1st Gen Tundras (2000-2006)' started by makna_sg, Jan 6, 2024.
  1. Jan 9, 2024 at 7:49 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
  2. Jan 9, 2024 at 8:36 AM
    shifty` Waving My Dick In The Wind
    Man, that is spot-on similar tone and nature of sound. I'll bet it is the intake mani gasket with OP just like it was with yours. Twice.
  3. Jan 9, 2024 at 8:37 AM
    makna_sg
    makna_sg [OP] New Member
    TX
    '02 AC SR5 V8 2WD
    Previous owner added k&n fuel injection kit and intake filter, as well as trd exhaust.
    ATBAV8[QUOTED] likes this.
  4. Jan 9, 2024 at 8:40 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I didn't replace mine. I was just very careful pulling the throttle body off. The gasket seemed quite durable, a mix of pliable plastic and rubber.
  5. Jan 9, 2024 at 8:45 AM
    makna_sg
    TX
    '02 AC SR5 V8 2WD
    Okay then maybe I'll just get that out of the way today, its difficult to know if my initial job was thorough since it's still attached.
  6. Jan 9, 2024 at 8:47 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
  7. Jan 9, 2024 at 8:54 AM
    makna_sg
    TX
    '02 AC SR5 V8 2WD
    This does sound very close to the noise I'm hearing, however mine is totally intermittent and only makes that sound at low rpms or idle. It also was always only starting after being driven for at least 20-30 minutes and then would continue from that point forward. I did drive the truck for that long yesterday and the noise still has not come back. I will probably just change the intake manifold gaskets anyways since just about all the gaskets on this thing are rotten and because it's not a super expensive or difficult fix. I think maybe when the engine would run a while, the rink of gunk around the butterfly flap would warm up and become softer so that when the flap was mostly closed it would seal along the sides like a bubble and pop open due to the vacuum. When I was poking around with the stethoscope I couldn't hear the pop coming from the intake manifold or from around the gaskets either. I just initially heard the sound coming from the intake manifold area.
    shifty` likes this.
  8. Jan 9, 2024 at 1:30 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, my intake manifold gasket is bad again.
  9. Jan 9, 2024 at 2:15 PM
    You are quite possibly right on that. It's the one thing I'll say, it sounded like it was a larger orifice.
    And those oiled filters are a huge cause of TB buildup. My truck has always seen OEM buildup. I have zero buildup after almost 80k miles of driving, and I haven't cleaned the TB once. All the more reason to get rid of that oiled filter STAT.
