Help. I popped off about oil change. "Where the f ..."
Discussion in '2nd Gen Tundras (2007-2013)' started by AgitatedGopher, Aug 13, 2020.
  1. Aug 13, 2020 at 5:50 PM
    AgitatedGopher
    AgitatedGopher [OP] Deer destroyer
    Dallas, TX
    2013 White Tundra and 2006 Green-ish Tundra 4x4
    Guys please help. I popped off about changing the oil in our 2013 Tundra. I cant find the dang drain plug, and I have 3 people mocking me (mercilessly) MIL, FIL,and hubs. Everyone is hi-tense about school, and I'm about to pop. Please help me change the mother-loving oil in this truck tonight. I need a break from them. Under the truck is quiet.
    YardBird likes this.
  2. Aug 13, 2020 at 5:57 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    low point of the sump on the passenger side iirc
    Darkness and YardBird like this.
  3. Aug 13, 2020 at 5:59 PM
  4. Aug 13, 2020 at 5:59 PM
    AgitatedGopher
    Dallas, TX
    Ok, now for a dumb question where the f is the filter. I cant spot it topside.
    I miss motorcycles.
  5. Aug 13, 2020 at 6:01 PM
  6. Aug 13, 2020 at 6:03 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Oil drain is on the passenger side directly across from the passenger side lower control arm. I have a fumoto drain valve on mine.
  7. Aug 13, 2020 at 6:06 PM
    AgitatedGopher
    Dallas, TX
    That pic looks like I need to remove the skid plate thing?
    Inquiringone, AZBoatHauler and SC_TRD like this.
  8. Aug 13, 2020 at 6:08 PM
    This was an internet pic, mine looks nothing like so, this was reference for you
  9. Aug 13, 2020 at 6:09 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
  10. Aug 13, 2020 at 6:10 PM
    Professional Hand Model
    Hand Protectors
    Send the men into the kitchen to make you a sandwich!:D
  11. Aug 13, 2020 at 6:11 PM
    AgitatedGopher
    Dallas, TX
    Black Wolf likes this.
  12. Aug 13, 2020 at 6:13 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
  13. Aug 13, 2020 at 6:13 PM
    AgitatedGopher
    Dallas, TX
    Ham, cheddar, lettuce, nacho cheese doritos, and spicy mustard. Dont think it's gonna happen, though.
  14. Aug 13, 2020 at 6:21 PM
    AgitatedGopher
    Dallas, TX
    I dont even. Is there a Chilton's for this?
  15. Aug 13, 2020 at 6:26 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  16. Aug 13, 2020 at 6:31 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Hey gopher ! I’m thinking maybe it’s time to take it to jiffy lube suck up the pride
    Tundyfundy and Steve like this.
  17. Aug 13, 2020 at 6:41 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Holy shitake mushrooms! Your truck has a front differential infestation!
    Cleanse it with fire!!
  18. Aug 13, 2020 at 6:45 PM
    AgitatedGopher
    Dallas, TX
    Never! I own all the socket sizes...
    Blue Thunder and Darkness like this.
  19. Aug 13, 2020 at 6:53 PM
    Where's your 10mm socket?
  20. Aug 13, 2020 at 6:55 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Were you able to get it done? Be sure to loosen silver plug first, push plastic plug up inside to drain filter cap, then remove cap ,filter is inside. Be sure to look very close to large o-ring location, and replace the same. Also be sure to get o-ring back in silver plug and tighten snug. Without the drain valve you are gonna get an arm full of oil when you push the plastic plug up inside to drain the cap, be sure your oil filter wrench has slots to fit the housing.
  21. Aug 13, 2020 at 7:08 PM
    AgitatedGopher
    Dallas, TX
    Um.... ...
  22. Aug 13, 2020 at 7:11 PM
    AgitatedGopher
    Dallas, TX
    TY. I did not get it done tonight. Too many cooks in the kitchen. I will tackle this at sunrise, when I'm the only one awake. I suspect it will be much easier then.
    Thank you for your description of the parts, it will come in handy in th AM.
  23. Aug 14, 2020 at 4:51 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    To piggyback on this thread... does anyone make an aftermarket (decent) skid plate with a hole in it for the damn filter? Changing the oil in my Tacoma took 10 minutes. It takes me double that just to get the damn skid plate off....
  24. Aug 14, 2020 at 4:54 PM
    RCI Offroad! Made in CO! If you need beefier then BudBilt..go with RCI. Ask for forum discount. An approved vendor here.
    BTBAKER and T-Rex266 like this.
  25. Aug 14, 2020 at 5:25 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    An impact makes the getting off not bad, the fun part imo, is getting it lined back up and 2 bolts started :)
  26. Aug 14, 2020 at 5:42 PM
    Justin Case
    Justin Case New Member
    TX
    Just cut a hole in skid plate.
    Tipsovr likes this.
  27. Aug 14, 2020 at 7:59 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Easy cut out , if your not into heavy offroading you can cut a hole in platewith grinder. Works great. The skid plate is pretty easy, just remove the front 2 bolts and it will hang there , then remove each bolt on sides, then go to middle bolt and let down , now go to front and unhook it. This hole is only about 4x4inch .IMG-1001.jpg IMG-1001.jpg
    RitcheyRch and Blue Thunder like this.
  28. Aug 14, 2020 at 8:22 PM
    It's not a skid plate. Basically a dust cover or a hard cheese plate..
  29. Aug 14, 2020 at 8:25 PM
    So why not just remove that piece of crap cheesy wanna be skid plate unless you put a hinged door on it?
    Geo4x4 and RitcheyRch like this.
  30. Aug 14, 2020 at 8:38 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    i agree 100%. i prefer the term "slash guard" over "hard cheese plate".
    don't want to invite the wrong kind-a crowd to my party... although "splash guard" may "excite" the same type of crowd that would attend a "hard cheese plate" party...
    that's a thinker... :monocle:
    that tin-foil thin piece of crap ain't skidin' nothin'
    Geo4x4 and Black Wolf[QUOTED] like this.
