Help, Going to be lifting my rear 5" need shock options.
Discussion in 'Suspension' started by sc134, Feb 16, 2017.
  1. Feb 16, 2017 at 4:34 PM
    sc134
    sc134 [OP] O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
    I currently have fox in the front but I dont find any fox shocks for the rear that will work with 5"
    anybody have any idea of what other shocks will work or what your running?
    thanks!
  2. Feb 16, 2017 at 4:51 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Is this 5" lift new or existing? Is it a drop bracket in the front? What size is the overall lift? What lift in the back?
  3. Feb 16, 2017 at 4:53 PM
    sc134
    sc134 [OP] O.P.S.
    No I have not installed it yet, planning on doing it in a few weeks. The front is ready to go, just not sure on what shocks to go with in the rear.
    also ill be needing extended brake lines correct?
