HELP: Fuel gauge shows half tank when tank is full
Discussion in 'General Tundra Discussion' started by Deucemimo, Jan 19, 2019.
  1. Jan 19, 2019 at 6:33 PM
    Deucemimo
    Deucemimo [OP] New Member
    2014 Tundra 1794
    I recently filled up my tank, the gauge shows half tank but my tank is full. I was only able to get 13 gallons into the tank. I pulled the neg battery cable to reset but that didn't help.
    Does anyone have any other suggestions on how to calibrate the fuel gauge?
  2. Jan 19, 2019 at 7:13 PM
    Do you normally top off your fuel?
    Black Wolf likes this.
  3. Jan 19, 2019 at 7:14 PM
    I know where this is going. For good reason...
    T-Rex266[QUOTED] likes this.
  4. Jan 19, 2019 at 7:36 PM
    Deucemimo
    2014 Tundra 1794
    Yes....... Sometimes
  5. Jan 19, 2019 at 7:37 PM
    Never ever top off fuel on your Tundra......
  6. Jan 19, 2019 at 7:40 PM
    Deucemimo
    2014 Tundra 1794
    Interesting.......How does topping off fuel play role in this situation?
  7. Jan 19, 2019 at 7:41 PM
  8. Jan 19, 2019 at 7:42 PM
  9. Jan 19, 2019 at 7:42 PM
  10. Jan 19, 2019 at 7:47 PM
    You may have messed up your Evap system. Others should chime in. A few here have had that same issue of over filling and causing a lot of problems related to what you are experiencing.
  11. Jan 19, 2019 at 7:47 PM
    Deucemimo
    2014 Tundra 1794
    Thanks for the info
  12. Jan 19, 2019 at 7:54 PM
    @T-Rex266 was right to ask if you normally top of when fueling. Caught my my eye so I chimed in. A failed evap system can cause weirdness, on the other hand the best thing to do in your case is go to the dealer and verify. I know....sucks.
  13. Jan 19, 2019 at 7:58 PM
    Deucemimo
    2014 Tundra 1794
    Much appreciated........I figured I would get a check engine light in a situation like this.
    I'll have dealer check it out next week.
    4x4_Angel and Black Wolf[QUOTED] like this.
  14. Jan 19, 2019 at 8:07 PM
    I agree..you would think you'd get a CEL but then again it really comes down to what could potentially trigger a CEL from the Evap system other than a loose fuel cap and that is above my pay grade.....
  15. Jan 19, 2019 at 10:10 PM
    Have you tried a different pump / station?
  16. Jan 20, 2019 at 3:24 AM
    timsp8
    NY
    Could it be the fuel sending unit? There was a post here a few weeks ago by someone whose unit went bad. I had a 46 gallon tank in my 2010 and could get another 3-4 gallons in it after the pump shut off. Did this topping off for years and never had an issue.
  17. Jan 20, 2019 at 3:54 AM
    I recall seeing that post. Sending units can fail. Not a cheap fix.The topping off is only bad if you overfill enough for gas to get into the Evap lines and foul the canistor. That Evap canister is a bit pricey too.
  18. Jan 20, 2019 at 3:54 AM
    Deucemimo
    2014 Tundra 1794
    Yes, I tried this.
  19. Jan 20, 2019 at 4:25 AM
    Navi
    Navi New Member
    2019 CrewMax Limited
    +1 fuel sending unit.
    this happened to me on my 2001 tundra, and it was about $450 to have it repaired but it did fix the problem. the part is cheap but it’s hard to get to, which is why it’s expensive
    but my truck was a 2001 and the OP has a 2014 so maybe not the problem but worth considering.
  20. Jan 26, 2019 at 8:20 AM
    Deucemimo
    2014 Tundra 1794
    Update.........Fuel pump assembly floater broke off into tank. Dealer repaired under warranty
    T-Rex266 and 831Tun like this.
  21. Jan 26, 2019 at 8:24 AM
    Navi
    Navi New Member
    Makes sense. Glad it was covered
