Help do I have limited slip differential? 06 tundra
Discussion in 'General Tundra Discussion' started by rally15gtr, Aug 5, 2018.
  1. Aug 5, 2018 at 1:35 PM
    rally15gtr
    rally15gtr [OP] New Member
    ryan
    06 tundra
    Leveling kit and 33
    Hey guys I have a 2006 tundra V8 double cab SR5. I want to change my differential fluid. I need to know if I have a limited slip differential. How would I find this out for my make and model? Also my manual calls for 90 weight rear differential fluid which I cannot find. Does anyone have a Brandon wait they suggest?
  2. Aug 5, 2018 at 3:44 PM
    Jrfor0
    Jrfor0 New Member
    James
    Maybe a local dealership can confirm based on VIN. I used to have a 2006 SR5 double cab V8 as well and it had a limited slip.
  3. Aug 5, 2018 at 4:12 PM
    Casper421
    In the woods
    06 DC
    Put your VIN into this link:
    https://www.toyota.com/owners/vehicle-specification
    and it will tell you if you have a limited slip. Other than that, the easiest way is to check the pumpkin for this sticker:
  4. Aug 6, 2018 at 1:14 PM
    rally15gtr
    ryan
    06 tundra
    Leveling kit and 33
    Thanks so much everyone!! I do have an lsd.
    YardBird, Black Wolf and Casper421 like this.
  5. Aug 6, 2018 at 5:40 PM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Make sure you use the lsd additive.
  6. Aug 6, 2018 at 6:46 PM
    rally15gtr
    ryan
    06 tundra
    Leveling kit and 33
    Yeah absolutely any specific brand of LSD Additive? I know Toyota does not make one that's what the dealership told me.
    YardBird likes this.
  7. Aug 6, 2018 at 6:48 PM
    Casper421
    In the woods
    06 DC
  8. May 21, 2020 at 1:11 PM
    moonshine
    moonshine New Member
    I just got a 2006 tundra, also a V8 double cab SR5. I did use the VIN checked on that link. But it is says nothing about the differential, is that means I have a standard type differential?
  9. May 21, 2020 at 1:24 PM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    On most vehicles that have a traditional mechanical limited slip you can tell by:
    Jacking the rear of the vehicle so both rear tires are off the ground.
    Put vehicle in neutral.
    Rotate one of the rear tires by hand.
    If the opposite rear tire rotates in the same direction, you have a limited slip.
    If the opposite rear tire rotates in the opposite direction, you have an open rear end.
    moonshine likes this.
  10. May 21, 2020 at 1:26 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I used this stuff without issue. If the unit keeps chattering as you turn corners then just add more friction modifier until the chattering stops.
    rally15gtr
  11. May 23, 2020 at 11:30 AM
    Wintersun
    Wintersun New Member
    Current trucks have an anti-spin rear end and use the ABS braking system to apply the brakes to the tire that is spinning faster. They do not have a LSD with a clutch and no option for getting one with Toyota pickups.
  12. Jan 12, 2021 at 8:40 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    How much K&W friction modifier do I need to add to my 80w-90 gear oil (3.5qt??) = 4oz for friction modifier?
    Also is there any other modifier that would work? for Ford kinds?
    Hey guys so I am doing my Rear LSD differential change. on my new to me 322k miles 2006 2wd Tundra double cab. I am going to use Walmart's 80w-90 gear oil (1 gallon) which is not synthetic. But I need to add friction modifiers for it. How much do I need to add? for my truck it says I will need to add 3.5 qt. I am thinking of adding the K&W friction modifier - This one exactly
    K & W Chemical Trans-X® Posi Trac® Limited Slip Gear Oil Additive -- Part # 402508
    Thanks.
  13. Mar 23, 2021 at 11:48 PM
    Tsgrav2011
    Tsgrav2011 New Member
    Yuma
    2006 4D TRD 2WD
    Brush scratches and dents
    So.... This is fairly straight up. If your differential has EB197366-1FDF-4537-A69E-F4A811F57DCA.jpg an LSD sticker on the back, use a GL-5 rated oil
    George 7250 likes this.
  14. Mar 24, 2021 at 12:20 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the lucas HD dino gear oil is the ONLY gear oil i've had that has not had chatter with my LSD. even with friction modifier with other gear oils. these diffs HATE the synthetic fluids.
    des2mtn likes this.
  15. Mar 24, 2021 at 9:52 AM
    Tsgrav2011
    Yuma
    2006 4D TRD 2WD
    Thanks! Great information. I’m due a change, I’ll pick up Lucas HD this week for my next change
    Update: I swung by Auto Zone and picked up 4 jugs, only $7.99 each. Glad I decided to change it. Who ever had changed it last time didn’t quite top it off. Only 2 1/2 quarts ran out. On refilling I put in almost 4.
  16. Mar 24, 2021 at 10:20 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Yep, I went with the Lucas HD oil recently in my LSD, no chatter! :thumbsup:
  17. Mar 24, 2021 at 10:37 AM
    Professional Hand Model
    Hand Protectors
  18. Mar 24, 2021 at 12:39 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    I always used Valvoline 75w-90 and the whole bottle of the TransX LSD additive. Both from Autozone. No turning chatter with that combination for 245,000 miles, changing every 30,000 miles or so. When I only used half the bottle of additive, I had chatter on slow turns.
    G_unit3000 likes this.
