Help deciding on wheels and offset
Discussion in 'Wheels & Tires' started by MattyLite, Dec 30, 2015.
  1. Dec 30, 2015 at 8:58 PM
    MattyLite
    MattyLite [OP] New Member
    2016 Tundra SR5 Crewmax
    5% tint
    So I bought a Tundra Crewmax the other day. I am going to put a 6" lift on it sometime within the next two weeks. For tires I'm looking at Toyo 35x12.50x20 but I can't decide on wheels or an offset for that matter. If y'all could help me out, the sooner I can get this lift kit put on. Thanks
  2. Dec 30, 2015 at 9:11 PM
    Get the TRD wheels if you can! Not sure of the offset off hand, but I'm a fan of those wheels amongst a few others.
  3. Dec 30, 2015 at 9:20 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Trd wheels ar +60 offset, so you will probably want an inch and a half wheel spacer if you are doing a 6 inch lift.
    If you buy aftermarket, +20 to a 0 offset is pretty tasty. Personally, I like the zero offset on 6 inches, but +20 would look good too. Zero offset, fender flares and tow mirrors are a good combo with a 6 inch lift.
    Keep in mind, +20 and lower offsets WILL rub wheel well plastic and the cab mounts. So you will have some trimming to do.
  4. Dec 30, 2015 at 9:44 PM
    crazymanson
    crazymanson New Member
    Stephen
    2016 Tundra DBL Cab 4x4
    I went with an +18 off set, the tires stick out about 2" without fender flares.. I have a 3" lift with 33" tire.
