HELP! Cross member bolts missing!
Discussion in '2nd Gen Tundras (2007-2013)' started by BigBarney, Aug 3, 2016.
  1. Aug 3, 2016 at 6:36 PM
    BigBarney
    BigBarney [OP] New Member
    Dustin
    2011 Tundra Rock Wariorr
    Hey guys, just crawled under my new (to me) 2011 Tundra and noticed that 1 of my t-case cross member bolts is missing, one is almost out completely and the other 2 are missing nuts on the end. What size bolts are these??
  2. Aug 3, 2016 at 6:48 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Can you be a little more specific? I can look it up but I'm not intimately familiar with the terms. Are you talking about the transfer case?
  3. Aug 3, 2016 at 6:49 PM
    BigBarney
    Dustin
    The crossmember bolts you have to remove to drop the transfer case. 2 bolts on each side that bolts to the frame. Long this ones with nuts on the ends.
  4. Aug 3, 2016 at 6:54 PM
    Nor7
    This guy?
  5. Aug 3, 2016 at 6:56 PM
    BigBarney
    Dustin
    These guys
  6. Aug 3, 2016 at 7:06 PM
    Nor7
    This guy?
  7. Aug 3, 2016 at 7:15 PM
    Nor7
    Found this but doesn't tell me what size, only torque.
  8. Aug 3, 2016 at 7:20 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    weight reduction yo!
    2cID likes this.
  9. Aug 3, 2016 at 7:24 PM
    Nor7
    Best bet might be to take one of the remaining nuts off, measure the length of the bolt and size the thread at the hardware store with the nut.
  10. Aug 5, 2016 at 11:48 AM
    BigBarney
    Dustin
    So, an update for y'all! Went to Home Depot and they did NOT have the nuts that match this, nor AIH. Called my parts department and $21 my 1 bolt and 4 nuts will be here next Friday.
  11. Aug 5, 2016 at 12:14 PM
    Kind of makes you wonder how it got that way. I know my T case member bolts are still freakin tight at 9 yrs old. Maybe they worked loose but then again???
  12. Aug 5, 2016 at 5:26 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Don'the know the size but last time I had my truck serviced (at about 63,000 miles) the mechanic found the same thing on my 2011. One bolt missing, one Backed halfway out and 2 loose but not backed out. I want to know how no one spotted this before because it has been serviced every 5k miles most at the dealership.
    NewImprovedRon likes this.
  13. Aug 5, 2016 at 5:43 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I think anyone with a 2011 better check crossmember/transfer case bolts. Someone on the Assembly line back then was probably stoned.
    Black Wolf likes this.
  14. Aug 5, 2016 at 5:43 PM
    Do it like me.I check out my truck every weekend. I do my own "pre flight " check out. A hold over from my USMC aviation days. ZERO FOD!!! You aviators here know what I'm talking about.
    Ericsopa and 4x4_Angel like this.
  15. Aug 5, 2016 at 5:49 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I was a mechanic and did all my own work but age and many medical problems prevent that know. My Tundra has always been serviced at either the dealership or the tire/brake shop.
  16. Aug 5, 2016 at 5:50 PM
    Like the stoner/drunks Dodge union dudes that got caught on 60 Minutes?
  17. Aug 5, 2016 at 5:56 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I didn'the hear about that but I will bet there are some on every assembly line.
  18. Aug 5, 2016 at 5:57 PM
    You need to get your old ass here out to Boulder Creek, CO for a vacation.
  19. Aug 5, 2016 at 5:58 PM
    Google it.
  20. Aug 5, 2016 at 6:04 PM
    NMOKTundra
    NMOKTundra Mike Honcho
    Albuqeurque, NM
    2008 Grey Tundra CrewMaxx
    USAF aircraft mechanic here. Very familiar with FOD checks. and fod walks :help:
  21. Aug 5, 2016 at 6:16 PM
    Mike Tread lightly.
    south carolina
    It's time too..
    Kick the tires,, light the fires....
  22. Aug 5, 2016 at 8:20 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    time for lock washers
  23. Aug 5, 2016 at 11:25 PM
    BigBarney
    Dustin
    I will be installing those too and torquing them down to spec. Looked through the service history, no reason for anyone to drop that cross member.
    My 2011 folks, check them out!
  24. Aug 13, 2016 at 7:10 PM
    BigBarney
    Dustin
    *UPDATE*UPDATE*UPDAT*UPDATE
    So, I asked a Toyota technician about these bolts and if any issues have been brought up in the past? Not to his knowledge nor Toyota's knowledge.
    So, I went to Home Depot and bought 2 bolts. I looked around for about 45 minutes in the hardest department, and nothing (in my mind) was a permanent fix.
    So, $24 and a week later, 4 nuts and 1 of the missing bolts came into my local Toyota dealership and they are installed. IMG_0738.jpg
    T-Rex266, Black Wolf and Nor7 like this.
  25. Aug 13, 2016 at 7:17 PM
    Good to go:thumbsup::thumbsup:. Reasonably cheap $ fix is always good. (I wonder how many here went out to check their bolts? heh heh) I did.
  26. Jul 26, 2020 at 9:55 AM
    btackett30
    btackett30 New Member
    brandon
    05 tundra trd
    so you posted this looking for the size of bolt, found it and didnt post the size? hmmm
  27. Aug 12, 2020 at 4:45 AM
    biasrutus
    biasrutus New Member
    I did not lose mine, but I could not remove mine without breaking them. I ordered these parts to replace them:
    90080-10378 Rear Mount Bolt
    90178-A0035 Nut Flange
    Worked perfectly, I do not have the size though.
  28. Aug 12, 2020 at 10:38 AM
    Dr_Al
    Dr_Al New Member
    Al
    Home Depot is a lousy place to go for hardware like bolts.
