Help! Check Engine Light & No Traction Control
Discussion in '2.5 Gen Tundras (2014-2021)' started by RW-3, Jul 6, 2017.
  1. Dec 19, 2019 at 7:01 AM
    #61
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    that is why I removed the engine cover and surrounding foam. The same thing happened to my brothers mustang.
    I try and spot any rodent issue. lately I’ve been following dads old habit of lifting the hood looking around the engine bay, also checking the oil before I take off in the morning while I have coffee. I believe tomcat has a rodent deterrent spray out there might give it a shot too.
  2. Dec 19, 2019 at 8:07 AM
    #62
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Wow.. Programmer and Rodent revenge.
    Get a dog (terrier or something)
    Put down mouse traps
    Stop putting programmers on your trucks.
    Get a cheap tester
    Yes the dealership has high end scan tools that see everything, including the program history.
    You 2016 folks should have already ditched your 2015 OEM battery for AGM.
    Keep changing your fluids
    Wash her once in awhile... Wax wouldn't hurt
    Have a great Christmas and enjoy the world's most dependable truck.
  3. Dec 21, 2019 at 2:03 AM
    #63
    Bmedic50
    Bmedic50 New Member
    Brandon
    2017 TSS Crewmax
    Tifford, I tried that and failed. Once I reconnected the battery, the light came right back.
    I ran the code and it came back as the knock sensor...just like the others had said. Took it to the dealers and sure enough, a rodent had chewed the wire harness.
    $80 for a new harness and $600 for the labor. I thought of doing it myself but the intake has to be removed to get to the wire and I didn’t want to deal with it.
    I popped the engine cover off when I got home and could see where something had scratched at the foam and stacked leaves to make a bed. The dude at the dealer said that the top of our engines makes a perfect warm bed for them.
    I did some internet searches and it also appears Toyota uses an organic material to insulate the wire harness. It’s likely that the rodents are attracted to this once they get in the engine bay.
    Last thing, a lot of insurances will cover this type of damage. I didn’t mess with it but may be an option if you don’t want to fork over the $$$.
  4. Mar 20, 2021 at 7:34 PM
    #64
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    This just happened to me I disconnected the battery and it didn’t come back on so far. Anyone know what the actually cause or problem is.
  5. Mar 21, 2021 at 5:29 AM
    #65
    Tiamat
    Tiamat New Member
    Stinkin rodents!!!
  6. Mar 21, 2021 at 6:30 AM
    #66
    Trdwillie14
    Billy
    2014 trd off road
    Really. I just don’t see that where I live
  7. Mar 21, 2021 at 6:33 AM
    #67
    Tiamat
    Tiamat New Member
    It is a real issue with these trucks.
  8. Mar 21, 2021 at 6:36 AM
    #68
    Trdwillie14
    Billy
    2014 trd off road
    I just mean I live on the coast we don’t really have this issue but I’ll have to get it checked if it comes back on
  9. Mar 21, 2021 at 6:48 AM
    #69
    Tiamat
    Tiamat New Member
    Bad alternator, bad battery, or rodent damage are Usually the culprit when the instrument cluster becomes a Christmas tree.
    Trdwillie14 likes this.
  10. Mar 21, 2021 at 6:49 AM
    #70
    Trdwillie14
    Billy
    2014 trd off road
    I think it maybe the battery it’s really old I hope It is lol thanks for the help dude
  11. Mar 21, 2021 at 6:55 AM
    #71
    Tiamat
    Tiamat New Member
    I know everyone hates on oem batteries, but i paid 79.99 for a replacement battery with 7 year warranty. No issues in 2 years.
  12. Jun 1, 2021 at 10:21 PM
    #72
    Steve66
    Steve66 New Member
    2017 Tundra SR5
    I had this issue with check engine light and traction control off message. It turned out to be a dirty air flow sensor. First issue was a year ago. I cleaned it with air flow cleaner. Second time I replaced the sensor.
    Tunderhead and RW-3[OP] like this.
