HELP, Can anyone tell me what this is?
Discussion in '2nd Gen Tundras (2007-2013)' started by Nor7, Dec 23, 2016.
  1. Dec 23, 2016 at 8:19 AM
    Nor7
    Nor7 [OP] Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Can't figure out what this is, the wires sneak under the dash. This weekend I'll go exploring but wanted to see if anyone has installed this, looks aftermarket.
    I pressed it the other day and held it down to see what it would do. Now my truck chirps three quick times on the horn when I start it.
  2. Dec 23, 2016 at 8:40 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Maybe something to do with an aftermarket alarm?
  3. Dec 23, 2016 at 8:50 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    It could be a valet setting option for an aftermarket alarm. My wife has something like that on her journey, it's part of the Lojack system that was installed. Did you have the alarm installed? I would try to find a manufacturer for it and get the manual.
  4. Dec 23, 2016 at 9:06 AM
    Nor7
    Yeah, I think it's some sort of aftermarket GPS thing. It was bugging me after I posted this so I went out and snapped these pics. I'll cut the zip tie and look for a brand name after I get home tonight. I don't have any zip ties with me.
  5. Dec 23, 2016 at 9:13 AM
    Nor7
    I don't think its alarm related, the truck has factory alarm. I also realized the reason it was chirping was because I must have accidentally unplugged the button on the dash. I plugged it back in and the chirping stopped when I went to start it.
  6. Dec 23, 2016 at 9:31 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Don't press the button! Remember what happened in The Fifth Element when they pushed the little red button?
  7. Dec 23, 2016 at 9:32 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It looks like an alarm sensitivity dial? Maybe the glass breakage sensor or something?
  8. Dec 23, 2016 at 9:33 AM
    Nor7
    If it was red I wouldn't have pushed it.
    MotoTundra and joonbug[QUOTED] like this.
  9. Dec 23, 2016 at 9:34 AM
    Nor7
    I'm thinking more and more its a GPS broadcast strength adjustment. The dealer initially guessed it was a glass break sensor, but I checked Chilton and the truck already has glass break microphones in the truck. Plus I don't see any microphones on this device.
  10. Dec 23, 2016 at 9:42 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    If it is a GPS it should be in a better location, it wont get a very good signal under all that plastic and steel. It looks like it can adjust the sensitivity or maybe the volume due to the Min/Max. You can trace the wires and see where it connects to or at least figure out what wires they connect to.
  11. Dec 23, 2016 at 10:05 AM
    mudsweatngearz
    mudsweatngearz New Member
    Grant
    Arizona
    2016 Limited TRD CM 2016, Tacoma TRD Sport, 2005 Tacoma TRD Sport
    Window tint
    flux capacitor.....as soon as you hit 88 mph it turns into a.......
    CaptTyler likes this.
  12. Dec 23, 2016 at 10:11 AM
    Lowcountrytj
    Lowcountrytj Buford T. Justice
    Phillip
    SE GA
    2008 Tundra DC, SC
  13. Dec 23, 2016 at 10:14 AM
    Nor7
    That was my first guess, pressed the button at 88 mpg.. nothing. Also tried it at 188 mph... nothing again except a brown stain in my underpants.
    Backslider and joonbug like this.
  14. Dec 23, 2016 at 10:14 AM
    Nor7
    Tried it, nothing happened.
    Lowcountrytj[QUOTED] likes this.
  15. Dec 23, 2016 at 10:17 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    looks like a clifford alarm sensitivity adjuster related to vehicle motion while parked
  16. Dec 23, 2016 at 10:19 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That was my guess. Maybe PO needed to adjust sensitivity so he added an aftermarket one to factory alarm somehow?
  17. Dec 23, 2016 at 10:23 AM
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
    Exactly what it is, I have the same thing in mine, different brand name though.
    Its an "addon" to the factory alarm
